Quoting Bond007 (Reply 1): Top of this list: http://icarus.red1aviation.com/jsp/accident.jsp Jimbo |
Quote: DAMAGE TO THE AIRCRAFT SUBSTANTIAL, CHICA |
Quoting Bond007 (Reply 1): |
Quoting AndrewUber (Reply 6): Delta Cargo 757?? |
Quoting QF108 (Reply 5): |
Quoting QF108 (Reply 5): There's an ATC recording of this incident from liveatc.net http://www.liveatc.net/forums/index.....html |
Quoting Midway7 (Reply 10): What do you click on at the liveatc website to play the audio? I've tried several links, but for some reason cannot listen to it. Do you have to be a member? |
Quoting BoeingBoy (Reply 9): The NTSB does not investigate HARD Landings |
Quote: TITLE 49--TRANSPORTATION CHAPTER VIII--NATIONAL TRANSPORTATION SAFETY BOARD PART 830_NOTIFICATION AND REPORTING OF AIRCRAFT ACCIDENTS OR INCIDENTS AND Subpart B_Initial Notification of Aircraft Accidents, Incidents, and Overdue Aircraft Sec. 830.2 Definitions. As used in this part the following words or phrases are defined as follows: Aircraft accident means an occurrence associated with the operation of an aircraft which takes place between the time any person boards the aircraft with the intention of flight and all such persons have disembarked, and in which any person suffers death or serious injury, or in which the aircraft receives substantial damage. |
Quote: Sec. 830.15 Reports and statements to be filed. (a) Reports. The operator of a civil, public (as specified in Sec. 830.5), or foreign aircraft shall file a report on Board Form 6120.1/2 (OMB No. 3147-0001) 2 within 10 days after an accident, |
Quoting RFields5421 (Reply 8): 9/29 - ATA B737 bird strike on departure collapsed windshield with minor injures to one cockpit crew - rtn to PHL |
