Motorhussy
Chile Argentina Routes Question.
Sun Oct 14, 2007 2:17 am
Hola.
Are there any international routes between secondary cities to the hubs (from one country to the other), for example: COR to SCL or ANF to EZE.
Or are SCL and EZE the only international airports in their respective countries?
Gracias por su ayuda!
MH
Rivet42
RE: Chile Argentina Routes Question.
Sun Oct 14, 2007 2:51 am
... I've flown LAN Chile from SCL to the delightful city of MDZ a few years back. A quick look on www.amadeus.net shows that route to be still in operation.
Amadeus would be a good place to look for other possible routes...
Riv'
[Edited 2007-10-13 20:07:52]
Argentina
Sun Oct 14, 2007 7:12 am
You have the following routes between a HUB and NON-HUB
SCL-MDZ: LAN AIRLINES
SCL-COR: LAN AIRLINES
SCL-COR-ROS: LAN AIRLINES
SCL-IQQ-SLA: LAN AIRLINES (Summer Season)
SCL-BRC: LAN AIRLINES
SCL-PMC-BRC: LAN AIRLINES
SCL-PUQ-USH: LAN AIRLINES
As you can see, only LAN offers this kind of flights.
AEROLINEAS ARGENTINAS flies only EZE-SCL route in CHILE.
Motorhussy
Sun Oct 14, 2007 9:21 am
Quoting Argentina (Reply 2):
Gracias. I could not see any reference to these on their route maps! Why no AR flights like this?
MH
RJ_Delta
Sun Oct 14, 2007 4:54 pm
Also LAN flies the following routes to
SCL-PMC-PMY (seasonal)
SCL-PMC-PUQ-MPN (Malvinas)
SCL-PMC-PUQ-USH
LAN offers good options to fly for the interior to Argentina to many destinations of the LAN and Oneworld network via SCL. Most of the LAN ' passenger from COR, ROS, and MDZ continues to North America, México and Europe via LAN.
Quoting MotorHussy (Reply 3):
A couple years ago, AR offers flight SCL-COR-GRU with a MD88. This flight connected at GRU with AR flight to MAD. Also Southern Winds offered flights on AEP-MDZ-SCL route with three daily flights, first with a CRJ200 switching then to a Boing 737-200. LAPA also flies to SCL from AEP vía MDZ and to PMC via BRC during a very short time with a Boeing 737-200 but the bad results of the route and the finnancial problems of the airline forced to cancel these services.
By the way, the Chilean carrier Sky Airline has approved to fly from SCL to COR via MDZ but it's probably that they never operate the route.
[Edited 2007-10-14 09:59:11]
PHKLM
Sun Oct 14, 2007 5:30 pm
LA is able to tap into large population centers in Argentina and enable these pax to connect in SCL. The alternative for the Argentineans is to fly domestically to AEP, take a taxi to EZE and then fly onwards. It is much more convenient to connect in SCL. This is why LAN offers these routes and AR does not. Besides, there are not a lot of population centers in Chile that cannot be served from SCL.
Motorhussy
Sun Oct 14, 2007 7:20 pm
Thanks everyone for your input. By the sounds of things, EZE needs some domestic connex to work better as a hub for AR.
EddieDude
Sun Oct 14, 2007 7:27 pm
Quoting RJ_Delta (Reply 4):
A friend of mine has to travel constantly between MEX and MDZ and her routing of choice is via SCL with LA. Interesting that the majority of the passengers of these types of flights are connecting passengers... seems LA has found a very nice niche in Argentina.
Quoting MotorHussy (Reply 6):
I wonder if EZE has any domestic service at all. Definitely transferring from EZE to AEP or vice versa is not very convenient.
zvocio79
Sun Oct 14, 2007 7:44 pm
Does Lan offer flights from Viña del Mar (Torquemada I think it is) to any Argentinian city during the sumer ????
I know there's massive Argentinian on Chilean beaches during the sumer because of the proximity.
How about Puerto Mont and Bariloche????
RJ_Delta
Sun Oct 14, 2007 8:41 pm
Quoting Zvocio79 (Reply 8):
No. Because Viña is near to Santiago and there is good connections to Viña (good highways and bus services) all traffic flight operates from SCL. Also Torquemada (Viña del Mar' s airport) has not the facilities to attend the flights and offer a good service for the passenger.
LAN flies between Puerto Montt and Bariloche 2 times per week with an Airbus A318 and A319.
zvocio79
Sun Oct 14, 2007 11:43 pm
Quoting RJ_Delta (Reply 9):
Do you work for LAN RJ ? you seem to have good knowledge or their ops...what's the status of their 340's are they gonna bring any new ones or get rid of the ones they have?
I like LAN a lot, specially now that I can go back to SCL non-stop since JFK  Smile
RJ_Delta
Mon Oct 15, 2007 1:50 am
Quoting Zvocio79 (Reply 10):
At this moment LAN have 5 A343 (CC-CQA, CC-CQC, CC-CQF, CC-CQE and CC-CQG ex Air Canada) but actually there are only 4 in service, because the CC-CQE is under maintenance according the program:
CC-CQC from Sep 28 to October 10.
CC-CQE from October 08 to October 31
CC-CQF from November 1st to November 24
CC-CQA from November 25 to December 12.
Only after December 12, LAN will operate again its five A343 offering daily flights to MAD-FRA and AKL -SYD and probably resume the A343 service to LAX (non stop flight).
During the next year LAN will receive another 3 A343 ex Air Canada to upgrade its longhaul fleet in a short term. The "new" LAN A343 will be:
msn 170 A340-313(X) ex C-FYLD
msn 273 A340-313(X) ex C-GDVW
msn 278 A340-313(X) ex C-GDVZ
Best Regards,
Motorhussy
Mon Oct 15, 2007 9:40 am
Quoting RJ_Delta (Reply 11):
Hola RJ_Delta
Do you know what cabin configuration the new A343's will have? The same as the existing fleet or like the upgraded 763 fleet?
MH
RJ_Delta
Mon Oct 15, 2007 3:38 pm
Quoting MotorHussy (Reply 12):
By the end of the 2008 A343 will have the same cabin configuration of the B763, with the new Premium Business and new Economy. Actually the CC-CQA has received new seats for Economy class, but still the old Business and First Class seat and the new one (CC-CQG) hasn't PTV in Economy Class.
IberiaA319
Mon Oct 15, 2007 3:55 pm
Quoting RJ_Delta (Reply 13):
CC-CQG has been on the SCL-AKL-SYD flights and on the SCL-MAD-FRA route. Those are long flights without PTVs in Economy, the frequent travellers might be surprised about this.
pzurita1
Mon Oct 15, 2007 4:29 pm
No offense to my Argentinian friends, but, why a flight from Santiago to Mount Pleasant, Malvinas is considered as a Chile-Argentina route?
SCL-PMC-PMY...
What is PMY????
RJ_Delta
Mon Oct 15, 2007 4:47 pm
Quoting Pzurita1 (Reply 15):
SCL-PMC-PMY...
What is PMY????
PMY= Puerto Madryn
PHKLM
Mon Oct 15, 2007 7:25 pm
Is isn't. Well, it shouldn't. The only way to reach MPN is with LAN via Chile or with the RAF via London / Ascuncion.
But in South America it is very common to depict the Falklands / Malvinas as Argentinean territory (along with a large chunk of Antarctica). So, I think in Chile and Argentina those flights are considered Chile - Argentina flights. If you are told often enough the Malvinas are Argentinean, you start believing it one day.
No offense intended at all for our Argentinean friends!
TBCITDG
Mon Oct 15, 2007 9:32 pm
LA has been very smart to tap into the Argentine marjket and offer better connections via SCL rather than have to transit via AEP/EZE. If I am not mistaken AR offers direct services from Ushuaia to EZE and at times there where also flights to and from COR.
How different things would be for AR if all operations where moved to EZE!
SJOtoLIR
Tue Oct 16, 2007 12:27 am
Quoting TBCITDG (Reply 18):
AR 1892 EZE-FTE-USH-EZE. Daily with 735.
FTE = El Calafate.
Motorhussy
Sat Oct 20, 2007 11:55 pm
Quoting PHKLM (Reply 17):
What do the people of Las Malvinas / The Falklands consider their islands to be part of I wonder? Perhaps that's the most important belief.
MH
zvocio79
Sun Oct 21, 2007 2:38 am
you are mistaken, every one South America knows that those are British island, and they rub it on their faces (argentinians) when ever they can, but that's for another forum.
May be they called a Chile-Argentina flight because of the proximity, perhaps the flight stops in Ushuaia before it goes to Mount Pleasant..........perhaps RJ can answer that question...
Motorhussy
Sun Oct 21, 2007 3:50 am
Quoting Zvocio79 (Reply 21):
I don't understand. Who do you say rubs their faces in it (or on it)? Falklanders or The British?
OO-VEG
Sun Oct 21, 2007 6:58 am
Not to forget, Argentina has a lot more big cities then Chile has. AFG is after SCL the biggest city and it has only about 300.000 inhabitants, so the catchment area for flights to Argentina would not be that interesting as with big cities like COR en MDZ.
RJ_Delta
Sun Oct 21, 2007 4:33 pm
Quoting OO-VEG (Reply 23):
I try to understand that AFG is Antofagasta or ANF (IATA code)?
Well the 3rd city in Chile is Concepción after Santiago and Valparaíso. In relation with air traffic IQQ has the second place in terms of airport traffic (pax and cargo).
