PC12Fan
How Are The A380's Dispatch Ratings Doing?
Fri Nov 09, 2007 2:39 pm
Just curious to see if any bugs have popped up or if there have been any learning curve influences?
Just when I think you've said the stupidest thing ever, you keep talkin'!
scbriml
RE: How Are The A380's Dispatch Ratings Doing?
Fri Nov 09, 2007 2:42 pm
I'm guessing it's going OK. I'm sure we would have heard if anything had gone wrong!  wink
EMBQA
Fri Nov 09, 2007 2:47 pm
Quoting PC12Fan (Thread starter):
It's WAY to early to even start looking at that. What have they had... 6 or 8 flights...??? Wait till they hit 100... then you can start trend setting.
PC12Fan
Fri Nov 09, 2007 2:57 pm
Quoting EMBQA (Reply 2):
True. Like Scbriml said, if there were any big problems, we would have heard about it. Again, I was just curious.
khobar
Fri Nov 09, 2007 4:21 pm
Quoting Scbriml (Reply 1):
After all the fanfare, I highly doubt we'd hear much of anything negative about the "new queen of the skies" flagship unless something really dramatic happened.
scbriml
Fri Nov 09, 2007 4:31 pm
Quoting Khobar (Reply 4):
Are you suggesting Airbus and/or SIA would try and suppress bad news?  smile
Any new type in service is watched very closely, this one probably more than any other since the 747. I'm sure any dispatch issues (even minor ones) would become public knowledge very quickly.
khobar
Fri Nov 09, 2007 4:46 pm
Quoting Scbriml (Reply 5):
I'm suggesting that SIA and Airbus are going to wait an appropriate amount of time to determine dispatch reliability and that until that time both will have a rather narrow definition of what "bad news" really is.
[Edited 2007-11-09 08:47:55]
knoxibus
Fri Nov 09, 2007 5:08 pm
So far no delays have been reported, we have the odd teething EIS issues, mainly due to cabin items. The rest of the aircraft actually works pretty fine and SIA is quite pleased AFAIK.
Of course this is only 2 weeks into service with one A/C, and obvioulsy as soon as there will be one delay superior to 15', everybdo will hear and be screaming about it.
No matter what anybody tells you, words and ideas can change the world.
spartanmjf
Fri Nov 09, 2007 5:10 pm
Isn't it a little soon to be doing dispatch reliability? In all fairness, the A380, though delayed, is STILL a new airplane and it will have some 'teething issues.'
More importantly, given that, IIRC, there is only one in service, the statistical meaning of any dispatch number would be virtually impossible to determine.
Now, when there is a fleet of some greater number [for the sake of argument, say 10], preferably with multiple carriers, I would think that one could then BEGIN to take a look at any dispatch issues that might be repetitive and that could need to be addressed either from an engineering/maintenance or an operational point of view.
I think it is great to have the plane flying and in revenue service - the gremlins will be worked through [particularly given the good reputation that SIA has].
"Nuts to the man in 21D!"
ikramerica
Fri Nov 09, 2007 5:39 pm
Actually, it's 20 or so, and so far, it's been on time every time I've checked.
pnwtraveler
Fri Nov 09, 2007 5:43 pm
Some bugs are to be expected even with the extended 'proving' period due to the delays. Of course anything like that will be jumped on and magnified out of context. The plane is on the ground for extended periods which is smart, to give time to work on little things before they become bigger issues. When the schedule is up to speed and turns are tight is when we will see more what dispatch is like.
PC12Fan
Fri Nov 09, 2007 5:47 pm
Quoting Ikramerica (Reply 9):
A nice start.  thumbsup
autothrust
Fri Nov 09, 2007 5:55 pm
Airbus has a team in Singapore in case of some big problems. IIRC the aircraft is monitored the whole time from Tolouse. The plane should be pretty mature after the long time of testing.
Wow, didn't know it had already so many, nice.
Flown on: DC-9, MD-80, Fokker 100, Bae 146 Avro, Boeing 737-300, 737-400, 747-200, 747-300,747-400, 787-9, Airbus A310, A319, A320, A321, A330-200,A330-300, A340-313, A380, Bombardier CSeries 100/300, CRJ700ER/CRJ900, Embraer 190.
halls120
Fri Nov 09, 2007 6:02 pm
Don't you think it is just a wee bit early to be asking this question?
"Suppose you were an idiot. And suppose you were a member of Congress. But I repeat myself." Mark Twain, a Biography
andessmf
Fri Nov 09, 2007 6:14 pm
Quoting Halls120 (Reply 13):
I would suggest that this question come up under (2) circumstances:
1. Length of service
2. Number of aircraft in service
The thread title should be 'How is...', since there is only one flying.
Joni
Fri Nov 09, 2007 7:37 pm
If the dispatch reliability is, say, about 99% then in order to get a reliable estimate of it we'd need to have something in the order of 2000 departures (for 20 error events, which is already indicative). If the reliability is just 90% then 200 departures would give us a similar idea of the DR.
khobar
Fri Nov 09, 2007 7:38 pm
Quoting Knoxibus (Reply 7):
Not quite true - after the inaugural flight, the return trip from Sydney to Singapore was delayed. SIA and Airbus quickly doled out money under the table, and before long passengers were told the indefinite delay was because of the weather.  Wink
Also, SQ220 has arrived late - almost an hour late in some cases. And there has been a reported problem with the IFE causing a delay.
As I said, SIA and Airbus would evaluate these and other reports to determine if any of them were bad news. Obviously none is bad news in a real sense, even to the most pessimistic, so there was no need to make the info public.
ikramerica
Fri Nov 09, 2007 7:49 pm
Quoting Khobar (Reply 16):
What's strange is that it arrives in SYD on time, leaves the gate at SYD on time, but arrives SIN late.
Like on the 9th, it left SYD gate 17 minutes late, no biggy, but arrived over 1 hour late. When 220 has been delayed, it's been like that.
Is it some sort of screw up with daylight savings time not being reflected in the system or something?
PC12Fan
Fri Nov 09, 2007 7:58 pm
If I did, I wouldn't have asked.  talktothehand
At any rate, I am asking as a fan of airliners, not to find faults or weaknesses.
flyorski
Fri Nov 09, 2007 8:55 pm
Does anyone know when SIA should be taking delivery of the second aircraft?
"None are more hopelessly enslaved, than those who falsly believe they are free" -Goethe
khobar
Quoting Ikramerica (Reply 17):
Sometimes 220 is an hour late, sometimes it's half an hour, sometimes it's only twenty minutes. It has, in part, to do with scheduling and SYD doing runway checks after A380 departures.
aussie747
Fri Nov 09, 2007 9:39 pm
Quoting Flyorski (Reply 19):
FEB 08' I am told
astuteman
Fri Nov 09, 2007 9:50 pm
 Smile
We've had some unusual weather patterns in south-east Aus this last few weeks. "Weather" that has any bearing, I don't know..  Smile
scbriml
Fri Nov 09, 2007 10:23 pm
Are they not departing at a particularly busy time from SYD? Basically, queuing to depart?
halls120
Fri Nov 09, 2007 11:52 pm
Quoting PC12Fan (Reply 18):
Quoting Halls120 (Reply 13):Don't you think it is just a wee bit early to be asking this question?
If I did, I wouldn't have asked. ÊÊ
Even as a fan, it's way too early to draw any conclusions about the dispatch rate.
ncelhr
Sat Nov 10, 2007 9:02 am
Quoting Astuteman (Reply 22):
Indeed, it's all about prevailing winds. When they blow against you they can delay you by as much as an hour on such a flight. Fly the other way and you might arrive ahead of landing time...
iwok
Sat Nov 10, 2007 9:36 am
Quoting Joni (Reply 15):
I used to work with a statistician who claimed that the "central limit theorem" says that if you measure 25 samples from a controlled batch, that your results will be very close to those achieved with larger samples. FWIW I did not believe him at all, but sure enough it did match up with what we saw. However since bugs are still being worked out, in other words process improvement is ongoing, the dispatch rate should increase.
iwok
glideslope
Sat Nov 10, 2007 12:02 pm
Let's see some Fuel Burn numbers.
2175301
Sat Nov 10, 2007 1:04 pm
Quoting Iwok (Reply 26):
iwok
That is a generalization that is often not true.
The amount of samples required to give statistically valid results depends on what kind of distribution the items being inspected follow and how accurate you want the results to be. The gentleman above who posted about the difference between needed accuracy and the number of events counted (200 to 2000) was on the right track as far as the accuracy.
While most people are familiar with what is known as the "standard normal" distribution; there are others out there. I don't have a clue as to which distribution most correctly fits aircraft dispatch reliability. The most common mistake is people (and even statisticians) applying standard normal statistical analysis to a non standard normal situation. That is why the common statement about statistics lying exist.
Within a standard normal distribution you need at least 30 events to achieve the best results to a 95% confidence interval. You may use less events - but then the standard deviation window gets wider.
nrcnyc
Sat Nov 10, 2007 2:33 pm
It is far too early to talk about any sort of "rate". As mentioned above, there will be teething issues. At this points in time, the theoretical dispatch rate is a moving target. SIA will be able to determine a real rate once they have a fleet of the aircraft operating many flights a day. This helps make the statistics more sound, but at that point SIA will probably hit some sort of peak ability to handle the aircraft and the dispatch rate will cease to be the moving target it is now.
Buyantukhaa
Sat Nov 10, 2007 4:00 pm
Quoting Khobar (Reply 20):
How would that affect a plane that has already taken off?!
I scratch my head, therefore I am.
knoxibus
Sat Nov 10, 2007 7:10 pm
Not quite true
I'll take your first sentence as sacarsm... Big grin
Also, SQ220 has arrived late...IFE
A delay is considered as being a "delay" when the aircraft departs 15 minutes late from original schedule, due to a tech issue (be it the aircraft or the maintenance that screwed up or did not apply the appropriate trouble shooting procedure.)
Any other delay (pax or else) is not impacted on the aircraft. I receive the daily reports from SIA as well as the Post Flight Reports, and so far (well at least up until wednesday), no delays have been reported.
IFE was impacted by something else and was therefore not to blame also, on one particular occasions.
I wonder where you get your info...
NWA742
Sat Nov 10, 2007 7:20 pm
Quoting Glideslope (Reply 27):
I've been wondering about that too. It will be interesting to see what SIA comes up with. Anybody have any info on that at this point?
-NWA742
Some people are like slinkies - not good for anything, but they bring a smile to your face when pushed down the stairs
overcast
Sat Nov 10, 2007 8:08 pm
I'm sure Knoxibus has some Fuel Burn figures, but I doubt he is able to share them.
Regarding the generally late arrival in SIN, I seem to remember that for the first couple of weeks there was going to be a Runway inspection after the A380's departure from SYD. But as the departure was a peak departure tim they were delaying the A380 so that they could minimise delays to the other operators.
The actual time of departure from the Gate seems fine, so the scenario fits the late arrival in SIN.
It should be interesting to see what happens next week, if it starts to arrive ontime in SIN then ti looks like a very nice entry into service.  crossfingers
BigSky123
Sat Nov 10, 2007 10:28 pm
I believe the second aircraft is scheduled to be delivered on January 2nd.
Stealthz
Sat Nov 10, 2007 10:35 pm
Have not heard about SIA/Airbus doling out money(and likely I would have) but take it from someone that was at SYD that afternoon and out in the weather.. it WAS weather. The ramp was shutdown for something like an hour at one of the busiest times of the week so took a little bit of time getting back to normal.
Quoting Scbriml (Reply 23):
Quoting BuyantUkhaa (Reply 30):
For a time either SACL or CASA had dictated runway checks after departure (not positive they are still doing it but possibly). Not sure why, perhaps to check any FOD issues caused by the outboard engines, SYD runways are only 45m wide.
To answer Scbriml & BuyantUkhaa, yes the departure is at a very busy time and it affects SQ220 because they try to slot it into a gap in the departure sequence where there is a natural break that allows the runway inspection which is done very quickly.
ikramerica
Sun Nov 11, 2007 12:38 am
Quoting Knoxibus (Reply 31):
A delay is considered as being a "delay" when the aircraft departs 15 minutes late from original schedule, due to a tech issue (be it the aircraft or the maintenance that screwed up or did not apply the appropriate trouble shooting procedure.)Any other delay (pax or else) is not impacted on the aircraft. I receive the daily reports from SIA as well as the Post Flight Reports, and so far (well at least up until wednesday), no delays have been reported.
Okay...
In the non-SIA world, when a plane arrives at it's DESTINATION 15 minutes or more after it was scheduled, it is LATE, and SQ220 is arriving SIN late often. It doesn't matter for what reason it is late, it is late. It is a delay.
But it's dispatching fine, and this thread is about dispatch reliability.
jetjeanes
Sun Nov 11, 2007 4:07 am
Im sure the team probably found a few bugs, that will help out on future frames comeing out. Every new Line has quirks
regardless of the manufactuer, The dc-10 was plagued. Im just curious is Airbus has a couple of maintaince guys on board
looking for things in flight and any repairs at Syd.
i can see for 80 miles
SOBHI51
Sun Nov 11, 2007 4:15 am
Not quite true - after the inaugural flight, the return trip from Sydney to Singapore was delayed. SIA and Airbus quickly doled out money under the table, .
Can you prove that? If not then please
[Edited 2007-11-10 20:21:00]
swallow
Sun Nov 11, 2007 6:05 am
Quoting JetJeanes (Reply 37):
No, there are no engineers on board the plane but it is monitored 24/7 from the Airbus Technical AOG (aircraft-on-ground) Center (AIRTAC) in Toulouse. Engineers are also on standby 24/7 with at least 30 Airbus staff in Singapore at a dedicated A380 control center. There are spares available in SIN and SYD in case it goes tech and suppliers are on standby if any other parts need to be sourced at short notice.
For now there is an Airbus pilot on the flight deck, but this is considered normal for a new type entering commercial service.
http://www.flightglobal.com/articles...nd-airbus-a380s-service-entry.html
The grass is greener where you water it
Ants
Sun Nov 11, 2007 6:33 am
As usual Knoxibus, thanks for providing us the interesting info you have access to.  thumbsup
One thing that is great about Airliners.net is the fact that we have members like Knoxibus who have direct knowledge of how a programme is going, rather than always having to rely on media reports  Smile
knoxibus
Sun Nov 11, 2007 12:03 pm
Quoting Ikramerica (Reply 36):
Of course, of course, we both agree on that. As you mentioned and since I did not make myself very clear, I was talking about technical delay impacting DR obviously, my bad.
It's purely professional vocabulary intrusion on my side, that's what a delay (or better called Operational Interruption) is for us.
Quoting Swallow (Reply 39):
Sometimes there is, SIA just has to ask, and they did that a couple of times already, only on the cabin items side.
Can't remember who asked, but FYI, MSN005 should be arriving at TLS (if not done already) in a couple of days. I'll
check on Monday.
Transfer of Title should be on 31st December and SIA should fly it home on 2nd January IIRC.
col
Sun Nov 11, 2007 12:23 pm
What route will no 5 cover?
Asiaflyer
Sun Nov 11, 2007 1:56 pm
Quoting Col (Reply 42):
Hi Col,
MSN 005 will do SYD-SIN-LHR to begin with.
khobar
Sun Nov 11, 2007 1:57 pm
As I said previously, Airbus and SIA have a specific definition for various things, and with their current definition for "bad news" or "delay", almost nothing counts (and, for the time being, I agree). So you arrive at the result you reported.
As for the "Not quite true" statement, I wasn't being sarcastic. It was meant as "tongue in cheek" since even the most pessimistic would have a hard time elevating any current issue above "minor".
From an "on-time" performance standpoint, anything over 15 minutes is fair game. Which begs the question: how is the A380 performing against other aircraft flying the same route? Is the A380 arriving on time more of the time or less of the time?
col
Sun Nov 11, 2007 4:07 pm
Quoting Asiaflyer (Reply 43):
Hi Col,
Asiaflyer,
Thanks for info, this means that one of the 744 routings to LHR will partially get replaced by 380?
Term 3 almost up and running, had the trains running around the system the other day when I was there. I think some flights are going in on the 12th for testing. There does not seem to be many parking gates at T3, I would have thought they may have extended out further with some pier system like T2.
Col
Asiaflyer
Mon Nov 12, 2007 5:16 am
Quoting Col (Reply 44):
T3 will have 28 aerobridge gates, which is an increase of 43% in terms of total numbers of gates at Changi.
That should be enough for some years ahead.
The distance between T3 and the runway is abit narrower than between T2 and the runway on the other side, so there isnt room for making piers of the same size as at T2.
If they want to build some piers at T3 , they will have to remodel the taxiway, but still not get piers of the size as T2.
CoolGuy
Mon Nov 12, 2007 3:28 pm
The A380 certainly had a long test period. Were there any technical issues that came up then that were resolved (excluding production delays)?
