Quoting Imiakhtar (Reply 3): Does AF actually require the ETOPS 180 for any of it's routes? |
Quoting Beaucaire (Thread starter): Not a very good publicity for GE... |
Quoting Beaucaire (Thread starter): and hopes for additional A340's... |
Quoting Stitch (Reply 5): Once they get their act together again, they'll be granted ETOPS-180 so I don't see them buying/leasing more A340s. |
Quoting PHKLM (Reply 6): , this will involve longer flight times and more fuel burn, but for SCL it might become an issue as the flight will approach 7500nm. |
Quoting PHKLM (Reply 2): Will this effect any routes other than ORY-SXM (and other destinations in the Caribbean) |
Quoting Palladium (Reply 15): |
Quoting Putnik (Reply 9): How an airline lose, or for that matter obtain ETOPS certificates? How can it drop from one ETOPS to another? |
Quoting YULYMX (Reply 13): But loosing it is suprising, B777 was ETOPS certified out of Production? |
Quoting Palladium (Reply 15): What is ETOPS? I feel dumb asking this question |
Quoting Carl50mq (Reply 22):
Hello all, Hello Beaucaire, I was Starship on Radiocockpit. The loss of the certification ETOPS 180 means an increase of flight time by 25 minutes on a FDF/ORY, 15 minutes on a PTP/ORY. Carl, i'm a all new A.netter member with a low english level... |
Quoting SN-MD11 (Reply 1): I guess some people at AF Industries (maintenance) are going to be in trouble... |
Quoting Stitch (Reply 5): It's with AF's maintenance depots. |
Quoting Mmedford (Reply 23): About the ETOPS regarding the 777, if I remember correctly upon deployment to fleets. The FAA granted immediately 1080/270 ETOPS to all 777s, but the JAA only granted 120 ETOPS later upgrading to 180 ETOPS. |
Quoting AirTranTUS (Reply 7): Quoting Beaucaire (Thread starter): Not a very good publicity for GE... Not really. One engine failure after how many million flight hours? That proves that the engine is very reliable. I see AF getting 207 ETOPS back soon. |
Quoting Carl50mq (Reply 22): Carl, i'm a all new A.netter member with a low english level... |
Quoting Stitch (Reply 18): The FAA certified the 777 for ETOPS-180 from entry into service. The JAA certified the 777 for ETOPS-120 from entry into service. ETOPS-180 was granted on an airline-by-airline basis after one year of trouble-free service. |
Quoting 2H4 (Reply 24): Are long-haul pilots ever under pressure to keep running a poorly-performing engine....perhaps damaging the engine in the process....to avoid an IFSD? |
Quoting PHKLM (Reply 6): Yes, certainly. It's needed on Paris - Caribbean (operated with 777) and CDG-SCL (777), CDG-ACC (or any countries close to Ivory Coast) but no others |
Quoting AirTranTUS (Reply 7): One engine failure after how many million flight hours? |
Quoting Stitch (Reply 5): The problem is not with GE. It's with AF's maintenance depots. |
Quoting Mmedford (Reply 23): But once AF gets their MX act together, they will regain their ETOPS status. |
Quoting AirTranTUS (Reply 7): Not really. One engine failure after how many million flight hours? That proves that the engine is very reliable. I see AF getting 207 ETOPS back soon. |
Quoting Putnik (Reply 9): How an airline lose, or for that matter obtain ETOPS certificates? |
Quoting Putnik (Reply 9): How can it drop from one ETOPS to another? |
Quoting Stitch (Reply 17): The 777 has an ETOPS type certificate and Air France has an ETOPS operational certification. The FAA grants a 180-minute ETOPS type certificate to the 777 while the JAA (the EU agency) only grants a 120-minute one. In order to get a 180-minute type certificate, the operator must be trouble-free for one year. |
Quoting Stitch (Reply 17): I am guessing Air France has lost their 180-minute ETOPS operational certification, but the JAA might have pulled their 180-minute 777 ETOPS type certificate. Either way, this busts them down to 120-minutes. |
Quoting Goldorak (Reply 31): Sorry, but I don't understand the relationship with AF maintenance in this specific case. In the other thread by Beaucaire about the emergency landing in LED, there wee some pictures from a Russian forum showing that the engine was damaged may be by birds (?) so why AF should lose ETOPS180 if they are not responsible of this incident. Sorry if my question seems stupid but I'm not a specialist of that and any explanation would b welcome. thank you |
Quoting AirTranTUS (Reply 7): More doubtful than the above. One incident isn't a reason for getting different aircraft. If that were so, they would have dumped all A340's after the YYZ incident. |
Quoting Flying Belgian (Reply 37): Etihad encountered the same problems as AF with the same type of GE engines on their 777s. |
Quoting Beaucaire (Reply 38): also Malaysian has IFSD's on thier 777's . |
Quoting 2H4 (Reply 24): The ramifications of a downgrade in ETOPS certification must be expensive. Are long-haul pilots ever under pressure to keep running a poorly-performing engine....perhaps damaging the engine in the process....to avoid an IFSD? |
Quoting Worldrider (Reply 36): ans for what reason? do you remember the cause of that accident? |
Quoting CF105Arrow (Reply 42): Could somebody please clarify this for me: Is a plane specifically etops equipped? This does no longer shows on AC's website but they had a mention on the fin number's page about 2 of their A319 (previously used on YYT-LHR) |
Quoting Flying Belgian (Reply 37): As far as I remember, Etihad encountered the same problems as AF with the same type of GE engines on their 777s. |
Quoting Beaucaire (Reply 38): also Malaysian has IFSD's on thier 777's .. |
Quoting Beaucaire (Reply 40): It's nevertheless strange that incidents involving GE engines have struck 777's of Air France,Ethihad ,Malaysian .. |
Quoting Zeke (Reply 44): Not the A319, but some aircraft like the 787 require the installation of additional fire bottles if you seek to gain the higher time ETOPS approvals. |
Quoting CF105Arrow (Reply 47): Thanks for your answer Zeke, but could you please explain "Not the A319" . I am asking that because out of the whole AC A319 fleet, only two can fly with Etops approval. |
Quoting Milan320 (Reply 33): No, it just couldn't be an engine issue could it? ![]() |
Quoting Zeke (Reply 34): The 777 does not have "ETOPS operational certification", it has been "found suitable" ETOPS, but the TCDS clearly says "This finding does not constitute approval to conduct 207-minute ETOPS operations." |
