Quoting AF340 (Thread starter): YYZ charges you per bounce for landing fees. Is this true |
what?????? wasted space.
landing fees are based on weight of the aircaft.
Quoting Jetdeltamsy (Reply 55): what?????? wasted space. landing fees are based on weight of the aircaft. |
Quoting Phoenix9 (Reply 52): Don't forget the you need quite sensitve Bounce Rate Enchanced Augmented Stress Trackers (BREASTs) to make sure the your STIFF landing can actually be transmitted visually to the pilots. |
Quoting Jetdeltamsy (Reply 55): landing fees are based on weight of the aircaft. |
Quoting IADCA (Reply 41): The automated billing system kept double-counting landings that were right on the centerline, as (the best explanation I can give lacking technical knowledge) because the sensors were multi-directional and actually would sometimes detect perfectly centered nosegear as being two separate sets of gear. They had to solve this with a work-around camera called the centerline image transmitter which runs a digital shot of the gear through a simple computer and compares it to various types to basically automatically determine through some sort of automatic comparison whether the plane bounced or not. |
Quoting Bond007 (Reply 59): we just have the imaging system offset a little from the centerline, and also have a +/- limit for measuring nosegear on the centerline, since most pilots try and avoid the exact center for the same reasons. |
Quoting CWUPilot (Reply 64): Taking another slot is rarely approved by ATC. Any Air Traffic Controller that does approve said manuever is extremely cool. |
Quoting Bond007 (Reply 9): At some of the other airports, like BTV (Burlington, VT), they actually have pressure sensors on the runway that not only count the bounces, but also weigh the aircraft . |
Quoting 474218 (Reply 40): That is when the most stress will be put on the parking aprons, taxiways and runways. |
Quoting IADCA (Reply 61): CHO |
Quoting N1120A (Reply 62):
It turns out their biggest outstanding liability leading up to the Chapter 11 filing was unpaid bounce fees at JFK. |
Quoting N766UA (Reply 71): The original poster |
Quoting Threepoint (Reply 72): OK, good. I thought I'd laid mine on pretty thick. The lowest form of wit, that's me to a tee. |
Quoting AA61Hvy (Reply 74): What happens if there is a cross wind landing? Do they have a like a combo pack or something..Land here get 4 wheels down for the price of two...? |
Quoting Phoenix9 (Reply 78): With years of committment of these contracts, constant upgraded fees, appearance enhancement ,ATC radio always on etc. charges added in...its better to pay the extra landing fees and land the way u want |
Quoting 2H4 (Reply 49): The consequences of improper preparation for a dry runway can also be severe: |
Quoting 2H4 (Reply 49): See, in this case, some form of lubrication would have minimized the heat and friction. Proper and liberal application of lubricant will minimize damage to both the aircraft and the runway. In these examples, foam was the preferred lubricant: |
Quoting BooDog (Reply 77): Bond, Threepoint and I tried to have a serious discussion about the PMS and TAMPON systems. |
Quoting WildcatYXU (Reply 82):
deployment of the TAMPON system makes STIFF landings really problematic |
Quoting BooDog (Reply 81): I got a call from a buddy of mine in Florida. He said that PNS is shut down due to hazardous conditions. Apparently they're out of their normal foam lubricant, but they got some coming in from SDF. As soon as their lube arrives from KY, they will be open again. |
Quoting BooDog (Reply 77): Good lord. Why can't posts EVER stay on topic? Bond, Threepoint and I tried to have a serious discussion about the PMS and TAMPON systems. |
Quoting Aircellist (Reply 85): So, I guess you are hiding something to us. Like the plan to test the new TAMPON system at Winnipeg's new Terry Francis airport (WTF) |
Quoting Aircellist (Reply 85): On any "normal" thread, the three of you would already have been asked "source, please?" about twenty times, and here, no one bothered, so... |
Quoting Bond007 (Reply 19): Well, OK I stand corrected, but AFAIK the German company sold the product to one of the large US firms ... Lockheed Martin perhaps? |
Quoting Snaiks (Reply 58): Quoting Phoenix9 (Reply 52): PS: I vote this to be the 'best thread of the year'!! I second that Motion |
Quoting AirTranTUS (Reply 10): Quoting AA737-823 (Reply 6): Go to your hanger and bring me back about one hundred feet of flightline. Hint: It's next to the propwash. |
Quoting AF340 (Thread starter): |
Quoting Gregarious119 (Reply 95): I just checked the thread after leaving work yesterday and I had 69 unread messages. Coincidence? I think not. |
Quoting BooDog (Reply 81): He said that PNS is shut down due to hazardous conditions. |
Quoting JetMech (Reply 96): Didn't you know that the whole purpose of tyre smoke is to hide the number of bounces to incur less landing fees? Michelin has actually developed a tyre that puts out more smoke for this very purpose, the "Le smokeur de Extraodinaire". |
Quoting Freshlove1 (Reply 2): I believe landing fees are based on the weight of the aircraft. I have never heard of that before about the bounces. I am sure he was just joking. |
