kaitak744
Delta Orders 2 More 777s
Thu Dec 20, 2007 11:58 pm
http://active.boeing.com/commercial/orders/index.cfm
Any idea which type of 777s these are? My guess is -200LR
Looks like they have another long-haul route they are interested in.
Edit:
Possible future 777 route structure:
8 777-200ER
daily ATL-TLV
daily ATL-DXB
daily ATL-ICN
daily ATL-NRT
10 777-200LR
daily ATL-JFK-BOM
daily ATL-JNB
daily ATL-PVG
?daily ATL-JFK-DEL?
?daily ATL-LAX-SYD?
[Edited 2007-12-20 16:04:52]
worldtraveler
RE: Delta Orders 2 More 777s
Fri Dec 21, 2007 12:02 am
DL is only ordering LRs.
keep 'em coming
Bicoastal
Fri Dec 21, 2007 12:20 am
Let's hope oil doesn't hit $100, the global economy doesn't tank, there isn't another dreadful terrorist attack, demand for air travel stays strong and Delta isn't stuck with a huge debt load while airlines like United are financially conservative, update what little fleet they have and get the most airtime they can out of their metal.
Time will tell which strategy works.
Airliners.net has many forums. It has spell check and search functions. Use them before posting!
FlyASAGuy2005
Fri Dec 21, 2007 12:26 am
Quoting Bicoastal (Reply 2):
Here's the kicker though. United has a very sizable 777 fleet. I think something like 30 ER's. Delta currently has 8. They need the airplanes and I think that it can only do them good.
What gets measured gets done.
GarethW
Fri Dec 21, 2007 12:27 am
Quoting Kaitak744 (Thread starter):
?daily ATL-LAX-SYD?
Don't know what advantage there would be using a 77L over a ER on this route? Is there still talk of ATL-SYD direct?
How good is it?
Bicoastal
Fri Dec 21, 2007 12:28 am
Quoting FlyASAGuy2005 (Reply 3):
But doesn't Delta have a ton more 767s than the rest of the world combined?
1337Delta764
Fri Dec 21, 2007 12:34 am
I don't think these are an addition to the eight already announced. Boeing's website previously reported that Delta had six 777-200LRs on order. These are the two that were announced several months ago, however, it wasn't on Boeing's website until recently.
deltal1011man
Fri Dec 21, 2007 12:37 am
10 777-200LR
daily ATL-JFK-BOM
daily ATL-JNB
daily ATL-PVG
?daily ATL-JFK-DEL?
?daily ATL-LAX-SYD?
ATL-PVG is going to the 772ER from the ATL-JFK-BOM-JFK-ATL......i also think that the ATL-JNB will stay on the 764 via DKR for a while (much bigger fish in Asia) i would also think ATL-BOM and ATL-DEL (without JFK) is possible
also note if DL goes to SYD it will be nonstop from ATL(why would they go to LAX and deal with UA and QF)
GCM has it 8034nm
and boeing has the 77Ls range at 9500(rounded its like 9432nm or something like that without the 3 tanks BTW)
there is also 1500nm of left over range so I'm sure it could do it) (note i dont want to here there isnt the O&D in ATL for it Delta can make it work)
edit:my bad PVG not PEK
[Edited 2007-12-20 16:59:36]
FlyASAGuy2005
Quoting Bicoastal (Reply 5):
And it's not helping them on some of their longer flights. Some routes they can't even operate because it's so out of reach, and others, make tech stops daily. There's a vast difference between the 763ER and 777ER/LR.
ikramerica
Fri Dec 21, 2007 12:40 am
True. Even in a downturn, DL needs the 777s. It would park MD80s and older 757s and 763s but continue to take delivery of the 777s, and defer some of the 738s.
flynavy
Fri Dec 21, 2007 12:47 am
Quoting DeltaL1011man (Reply 7):
ATL-PEK
When did you get the idea we're flying to Beijing? Delta was awarded ATL-PVG route authority.
We want ATL-HKG. Look for it.
Change is: one airline, six continents!
kaitak744
Fri Dec 21, 2007 12:53 am
ATL-PEK is going to the 772ER from the ATL-JFK-BOM-JFK-ATL......i also think that the ATL-JNB will stay on the 764 via DKR for a while (much bigger fish in Asia) i would also think ATL-BOM and ATL-DEL (without JFK) is possible
DL does not have the right to fly ATL-PEK. Only ATL-PVG. Also, I heard that ATL-JNB was on Delta's "wish list" for the 777-200LR, when they made the original announcement.
Quoting Flynavy (Reply 10):
Does HKG require special rights to fly to? similar to PVG or PEK?
deltal1011man
Fri Dec 21, 2007 12:56 am
shit my bad i wanted them to get ATL-PEK and ATL-PVG so i guess i just make it up lol(dont worry it will happen the next time around)
(also look for ATL-SIN DL has asked for slots to SIN,SYD,HKG and NRT) (but the other NRT is for JFK)http://atlanta.bizjournals.com/atlanta/stories/2007/04/30/daily3.html?page=3
OldAeroGuy
Fri Dec 21, 2007 12:57 am
No, three aux tanks are required for the 9430 nm full pax range. With no aux tanks, the full pax (no cargo) range drops to about 8800 nm.
papatango
Fri Dec 21, 2007 1:16 am
Quoting FlyASAGuy2005 (Reply 8):
Which flights are making tech stops daily?
SLCUT2777
Fri Dec 21, 2007 1:43 am
But why order more of a soon to be obsolete airframe? DL can only do so many routes with their sizeable fleet of 763ERs. With many of the routes you see above, larger frames with longer ranges are required.
I think that eventually this one might even go 773ER if DL decides the route does well enough to warrant it and further amending their 777 order with Boeing. ATL-PVG can be done with a 772ER anyhow. But ATL-SIN and ATL-HKG will need the 772LR as will any India Flights (BOM, DEL from either ATL or JFK). If DL does service to SYD it will be from ATL rather than LAX since California is already well covered by both UA & QF.
JFK-BOM: 772LR
ATL-JNB: 772LR eventually
ATL/JFK-CPT: 764ER fuel stop @DKR
JFK-NRT: 772ER
JFK-DEL: 772LR
Just my  twocents  worth.
DELTA Air Lines; The Only Way To Fly from Salt Lake City; Let the Western Heritage always be with Delta!
