Quoting mgm414 (Reply 1): Well, Based on what I read somewhere previously, the messages they got required no actions for the pilots to return to the airport |
Quoting blink182 (Reply 4): Seeing as EK is neither a US company nor did this flight touch US territory, what jurisdiction does the NTSB even have over this? |
Quoting mgm414 (Reply 1): Based on what I read somewhere previously, the messages they got required no actions for the pilots to return to the airport. |
Quoting 3rdGen (Reply 8): Pilots are more afraid of what the airline will do to them than the what the plane might do. |
Quoting Transpac787 (Reply 2): The article said following one of the loud bangs on takeoff one of their EICAS messages was thrust asymmetry warning meaning the damaged engine was producing significantly less thrust than the good engine. Such an EICAS message following a loud bang *should* be cause to turn back, as the engine was obviously damaged. |
Quote: The report does not discuss what procedures the Emirates crew followed after hearing the bang and receiving the AHM annunciations or whether the aircraft should have been returned to Domodedovo. |
Quoting BluemoonUK (Reply 12): Quoting 3rdGen (Reply 8): but the engine keeps performing as expected But it didnt because they got a thrust asymmetry warning. Bluemoon |
Quoting bonusonus (Thread starter): NTSB: EK 777 Continued Flight With Damaged Engine |
Quoting 3rdGen (Reply 10): The NTSB is often asked to come in to help with investigations, they often go abroad to help with accident/incident investigations, however its only ever done at the request of the Country in charge of leading the investigation. |
Quoting Revelation (Reply 15): What is confusing me is that if NTSB is just helping the local authorities, why are they releasing a report? |
Quoting Max Q (Reply 18): Still don't understand why the NTSB is involved in this. It may be an American Aircraft but it is operated by a Dubai based carrier operating between two points outside of the US. Does the NTSB's remit cover the world now ? ! |
Quoting Max Q (Reply 18): Does the NTSB's remit cover the world now ? ! |
Quoting Mir (Reply 20): If they're going to get involved in every accident with US-made aircraft, engines or avionics...pretty much |
Quoting Max Q (Reply 21): I don't think that will happen. The most likely explanation is, as Larshjort says, that they were asked to participate. |
Quote: In accordance with established international arrangements, the National Transportation Safety Board (NTSB) of the USA, representing the State of Design and Manufacture of the aircraft, appointed an Accredited Representative and was supported by a team which included additional investigators from the NTSB, the Federal Aviation Administration (FAA) and Boeing; Rolls-Royce, the engine manufacturer, also participated fully in the investigation. |
Quoting cubsrule (Reply 22): They were asked because the safety body in the country of origin is supposed to be asked. AAIB probably says it best (this is from the preliminary report on BAW38) Quote:In accordance with established international arrangements, the National Transportation Safety Board (NTSB) of the USA, representing the State of Design and Manufacture of the aircraft, appointed an Accredited Representative and was supported by a team which included additional investigators from the NTSB, the Federal Aviation Administration (FAA) and Boeing; Rolls-Royce, the engine manufacturer, also participated fully in the investigation. |
Quoting ltbewr (Reply 23): it protects those USA companies from frivolous lawsuits being brought in the Plaintiff friendly USA court and civil legal system even if the incident occurred with no other connections to the USA. |
Quoting CODC10 (Reply 7): The NTSB doesn't have "jurisdiction" over anything, really |
Quoting Revelation (Reply 15): But none of this would make me expect we'd have NTSB issuing its own report. |
Quoting ltbewr (Reply 23): Part of the reason for the USA's NTSB to want to participate is to make sure if any liability goes back to Boeing, the USA based a/c's maker or if any component was made in the USA that may have contributed to the incident, it protects those USA companies from frivolous lawsuits being brought in the Plaintiff friendly USA court and civil legal system even if the incident occurred with no other connections to the USA. |
Quoting BluemoonUK (Reply 12): But it didnt because they got a thrust asymmetry warning. Bluemoon |
Quoting Transpac787 (Reply 2): the damaged engine was producing significantly less thrust |
Quoting ThrottleHold (Reply 28): |
Quoting Max Q (Reply 18): Still don't understand why the NTSB is involved in this. |
Quoting bonusonus (Thread starter): I'm not a pilot, but I can't imagine that continuing on after having this kind of issue at takeoff would be a good idea |
Quoting mgm414 (Reply 1): Well, Based on what I read somewhere previously, the messages they got required no actions for the pilots to return to the airport. |
Quoting Transpac787 (Reply 2): The article said following one of the loud bangs on takeoff one of their EICAS messages was thrust asymmetry warning meaning the damaged engine was producing significantly less thrust than the good engine. |
Quoting ThrottleHold (Reply 28): What the crew received was a series of STATUS messages. STATUS messages on the 777 are for crew info only and require no action. They are mainly an engineering function. |
Quoting kaiarahi (Reply 30): Where does it say "significantly"? The actual EICAS messages were: THRUST ASYM COMP ENG EEC C1 R ENG EEC MODE R ENG R EPR BLANKING TURB OVHT SNSR ENG R |
Quoting CX Flyboy (Reply 34): They might have not encountered any EICAS warnings, cautions or advisories following the bang and takeoff (Although Thrust Assym Comp message is normally not a Status level message). |
Quoting CX Flyboy (Reply 34): In all likelihood, they would have spoken to someone in engineering back at their headquarters to discuss the issue with their engineers able to access real-time engine data to deduce that the engine was indeed running properly and not necessarily about to suffer a failure and basically that's what it is about. Is the engine going to fail en-route? |
Quoting tdscanuck (Reply 32): It's up to the NTSB whether or not the want to participate. |
