Quoting cosmofly (Reply 2): The products are more or less the same |
Quoting TOMMY767 (Reply 4): Aside the 735 and some of the older 757s, what airplanes are in need of replacement? |
Quoting washingtonian (Reply 11): If they are ordering 100-200, I'd say it's inevitable... |
Quoting gingersnap (Reply 15): There appears to be a sweet spot, where the 738 MAX & A321 NEO should work well together. |
Quoting washingtonian (Reply 8): It seems like the current ideal line-up would be A-319NEO, A-321NEO, and 738RE...And perhaps Embraer or C-series to replace the 737-500s and provide a mainline lower-capacity aircraft. |
Quoting ukoverlander (Reply 21): Having been a Continental Frequent flyer for almost 20 years I have to say I enjoy the opportunity to fly the United A319 and A320's from the passenger standpoint |
Quoting kgaiflyer (Reply 23): Oddly, the CO 738s with the borrowed AS seats are some of the roomiest 737's CO has. The total absense of IFE with those seats may be an issue for some. |
Quoting gigneil (Reply 10): I'm also curious to see how fast PMUA 757s get moved from ORD and DEN and reallocated to SFO, LAX, IAD and EWR to be replaced by 737-900ERs in the middle of the country. |
Quoting gigneil (Reply 9): To be fair, I really don't expect many if any of the A320s to get replaced. |
Quoting CALTECH (Reply 26): Rumor is only 13 of 96 to be saved. |
Quoting seabosdca (Reply 30): There are 16 ETOPS and 13 p.s. (which aren't ETOPS). If they're talking about keeping 13, I assume it's the p.s., especially since they are about to overhaul the interiors of those birds. |
Quoting seabosdca (Reply 28): So only the p.s. birds. Wonder what they'll use DEN-Hawaii, especially with the conversion of the domestic 763s? |
Quoting displane (Reply 22): When UA ordered new planes in the late 90s, it was mostly based on politics- making it look good for Europe and the US. |
Quoting seabosdca (Reply 30): If they're talking about keeping 13, I assume it's the p.s., especially since they are about to overhaul the interiors of those birds. |
Quoting seabosdca (Reply 28): Wonder what they'll use DEN-Hawaii, especially with the conversion of the domestic 763s? |
Quoting Drerx7 (Reply 33): more than likely the 753 |
Quoting washingtonian (Reply 36): That was my thought too. Do you know the age of the PS 757s? |
Quoting gigneil (Reply 38): They're expecting at least 3700nm-ish from both. That 800nm should be enough for ETOPS reserves across a 2900nm sector, shouldn't it be? |
Quoting gigneil (Reply 38): The A321neo will have no problem from Denver, and I doubt a 737-9 will either. They're expecting at least 3700nm-ish from both. That 800nm should be enough for ETOPS reserves across a 2900nm sector, shouldn't it be? (I'm really asking) |
Quoting scorpy (Reply 39): Since they already plan to refurbish the PS aircraft, I wonder if it makes sense to referb the best of the |
Quoting seabosdca (Reply 43): The only issue is that they have been equipped with winglets and most of the rest haven't. |
