Quoting FL787 (Reply 43): PHL- ? |
Quoting FL787 (Reply 43): IAD- Still separate. |
At IAD and PHL, aren't FL and WN already in the same concourse?
Quoting kgaiflyer (Reply 50): At IAD and PHL, aren't FL and WN already in the same concourse? |
Quoting yx302 (Reply 52): As far as better Terminals remember that C just got renovated and a hammerhead added. If FL leaves C that would leave the newest terminal hardly used even if continental/united moved there. |
Quoting laxboeingman (Reply 47): |
Quoting zippyjet (Reply 48): On 16 Nov 1011 we begin operating out of concourse B odd numbered gates. International flights depart out of our main gates but will continue to arrive in Concourse E most often gates E-4, E-6 and sometimes E-8. |
Quoting DCA-ROCguy (Reply 59): A TSA agent I know at BWI confirms your report of adding C and reestablishing the B-C connection. |
Quoting zippyjet (Reply 60): All systems are go for us to make the move on November 16. I just wish we could have done it earlier as originally planned. We were supposed to have made the move September 20. Thanksgiving is only 8 days after we move to Concourse B. Wish us luck for a speedy smooth transition so you all won't have to read a thread about passengers having kittens. |
Quoting zippyjet (Reply 48): A tunnel/link is being developed as we speak to connect C to the A/B gates. |
Quoting DCA-ROCguy (Reply 62): |
Quoting GizmoNC (Reply 64): You must have been having a dream in STL. WN is in terminal 2 ( former EAST TERMINAL). There are only 2 luggage carousel in Terminal 1 where WN/FL flies out of. FL is at gate E4 not E8. From that post you must have had quite a trip to STL. Why would STL build another luggage casoursel in the cramped baggage area, |
Quoting kgaiflyer (Reply 63): It's a shame they can't use the old link from the days at BWI when WN used B and C and the -- at the time -- oldie moldy A concourse was under reconstruction. |
Quoting wnflyguy (Reply 58): Also WN future plans for LAX will include Mexico service. |
Quoting QANTAS747-438 (Reply 68): |
Quoting wnflyguy (Reply 69): Mexico service from the west coast with WN metal not until 2014. Next year if and when WN gets all of T1 and they finish the remodle you will see Volaris move into T1 gate 1 and 3 and expand the code share first. |
Quoting QANTAS747-438 (Reply 37): 4A is never used. In fact, management has said not to use it unless absolutely necessary. |
Quoting chrisair (Reply 70): Correct me if I'm wrong, but there is no FIS/CBP area in T1. Where are they going to stick that? |
Quoting chrisair (Reply 70): Weird. I've used it a bit in the past for all sorts of flights. I think I even was on a -700 out of that gate once. I try and avoid LAX as much as possible on WN, so I haven't been there as much as the last few years. |
Quoting irish (Reply 72): Tonight is the big move at MCO for Airtran to airside 2 to join Southwest. |
Quoting MUWarriors (Reply 74): I am amazed that they would decide to move to the D Concourse at MKE |
Quoting OzarkD9S (Reply 39): I was just in T-1 last week (from 12pm-2pm) and it is a hot mess. But a functional hot mess, I just don't see space for much more concessions. |
