shufflemoomin
What Does A "base" Really Mean?
Thu Nov 10, 2011 12:32 am
After reading an article today that Easyjet was considering setting up a base in CPH, I wondered what having a "base" somewhere really means besides basing some aircraft or crew there. As a passenger, does having a base at your local airport actually make a difference?
shamrock604
RE: What Does A "base" Really Mean?
Thu Nov 10, 2011 12:41 am
Quoting shufflemoomin (Thread starter):
Not really.... it may make a slight difference to reliability because having aircraft based means chances of having a spare aircraft are higher, but that's really about it!
A base is simply aircraft overnighting and crews living locally.
YYZRWY23
Thu Nov 10, 2011 1:03 am
Quoting shamrock604 (Reply 1):
Which also helps if crew times out and they need reserve crew members. Better they are based locally instead of being flown in.
YYZRWY23
If you don't stand behind our troops, feel free to stand in front of them.
Viscount724
Thu Nov 10, 2011 1:16 am
It does if, like many business travellers, you prefer flights that leave early in the morning and return late at night.
gizmonc
Thu Nov 10, 2011 1:20 am
A base is a domicile that has pilots and flight attendants that are assigned to fly trips out of the respective city and return to the same city. STL is not a base for WN but it does have 7 overnighters ( ac that come in and terminate).
Eagleboy
Thu Nov 10, 2011 4:22 am
In normal terms I would say NO. The pax don't care where the aircraft/crew are based as they just want a flight that suits them.
However as above having crew at a base is probably a bit more reliable in times of disruption that for pax located beside/at an airline destination/outstation.
I would also query a certain level of base in regards to quantity of fleet units based there. FR has over 40 bases in Europe, however quite a number of these have less than 3 aircraft based there, should this have its own term?
AAR90
Thu Nov 10, 2011 4:39 am
In AA terms, no aircraft is "based" anywhere. They fly wherever they are scheduled and that schedule is determined partly by where the maintenance capability exists. For flight crew (pilots & flight attendants), a "base" is a "domicile." It is where the administrative support is located and where all trips begin and end. That's the basics with every airline having slight variations and even variations amongst the different "bases" of the same airline.
skidmarks
Thu Nov 10, 2011 11:06 am
When i was working for EZy, a base meant based aircraft and crews with a maintenance facility. This could be full maintenance or simple line maintenance.
So, for CPH i would think they have an agreement with a local maintenance provider to carry out regular line checks and troubleshooting/rectification.
Andy
Growing old is compulsory, growing up is optional
richardw
Thu Nov 10, 2011 11:16 am
Quoting Eagleboy (Reply 5):
FR's aircraft are registered in Ireland so their ultimate base is DUB.
shufflemoomin
Thu Nov 10, 2011 12:22 pm
Thanks for all the replies everyone. You've all pretty much reaffirmed what I already believed. I just wondered why news of a possible U2 base in CPH made the normal papers. I wondered why anyone outside of aviation would care.
AmricanShamrok
Thu Nov 10, 2011 1:11 pm
Quoting richardw (Reply 8):
Their HQ is in Dublin but their largest operations base is London Stansted.
richardw
Thu Nov 10, 2011 1:54 pm
Quoting AmricanShamrok (Reply 10):
Yep, aware of that. I was just making a comment about where the aircraft are registered, even though they operate at STN in a similar way to U2 but their aircraft are registered in EI and easyJet's in the UK.
Burkhard
Thu Nov 10, 2011 2:28 pm
I means they all depart early morning, so you have to awake really early.
Quoting shufflemoomin (Reply 9):
It means some jobs created, making taxes and other income to other business.
GLAGAZ
Thu Nov 10, 2011 2:42 pm
Quoting Viscount724 (Reply 3):
You don't need a base for that. You can night stop crew and aircraft for an early morning departure without having a 'base' at the particular airport.
Gaz
Neutrality means that u don't really care cos the struggle goes on even when ur not there, blind and unaware
Dalmd88
Thu Nov 10, 2011 9:45 pm
Quoting GLAGAZ (Reply 13):
That is usually the case in the US. The crew bases are many time at hubs. Most of the fleet overnights at the ends of the spokes and flys into the hub early in the morning. Some bases are focus cities that also see a round of early departures to the various hubs. Now a maintenance station is set up in a city where there are a lot of flights like hubs or where there are a lot of overnights. Some stations are just good deals for an airline. For DL a couple are SAV and CHS. Neither really have a lot of flights or a lot of overnights but the are cheap warm weather cities to operate a couple of 'A' checks every night out of.
