Quoting Gonzalo (Thread starter): OK, confusing a Line Up and wait clearance with a take off clearance, I can understand.... but continuing the take off roll when the Tower says "STOP" is beyond my understanding capacity ( unless they were already at a very high speed...) |
Quoting Gonzalo (Thread starter): It was a China Eastern [...] |
Quoting bennett123 (Reply 7): Unless the radio or brakes failed of course. |
Quoting motorhussy (Reply 5): Mmmm wasn't the plane's fault, try blaming the pilot. Saying the A332 did something wrong kind of blemishes the aircraft when it was the human in charge of it that piloted the plane out of KIX to PVG without clearance and ignored the STOP order. |
Quoting Gonzalo (Thread starter): OK, confusing a Line Up and wait clearance with a take off clearance, I can understand. |
Quoting rjm777ual (Reply 2): They could have been going too fast without enough runway to abort. |
Quoting usafdo (Reply 15): The pilots need to be suspended immediately, and perhaps fined. |
Quoting bennett123 (Reply 4): Is there much difference between English spoken with a Chinese accent and with a Japanese accent? |
Quoting ikramerica (Reply 10): But according to the newspapers, SUVs kill people all the time. |
Quoting KC135TopBoom (Reply 16): Nope.... normal take-off performance prior to V2 should still allow to abort within the confines of the runway |
Quoting Babybus (Reply 3): I think any pilot understands the word 'stop!' |
Quoting GentFromAlaska (Reply 21): There could have been confusion or misstatement in the ATC, tower, or by the pilots on the a/c allegedly involved |
Quoting usafdo (Reply 15): The pilots need to be suspended immediately, and perhaps fined. CRM is apart of their responsibility and if they are not paying attention and "hearing things" then their capacity to continue being employed as pilots needs to be serious reevaluated! |
Quoting Gonzalo (Thread starter): OK, confusing a Line Up and wait clearance with a take off clearance, I can understand.... but continuing the take off roll when the Tower says "STOP" is beyond my understanding capacity ( unless they were already at a very high speed...) Anyone has more info about this ?? |
Quoting motorhussy (Reply 5): Mmmm wasn't the plane's fault, try blaming the pilot. Saying the A332 did something wrong kind of blemishes the aircraft when it was the human in charge of it that piloted the plane out of KIX to PVG without clearance and ignored the STOP order |
Quoting Sean-SAN- (Reply 30): dd the general poor aptitude for flying most Chinese pilots have (saved only by the extreme automation thanks to airbus), and it's easy to see how this happened |
Quoting usafdo (Reply 15): CRM is apart of their responsibility |
Quoting ac033 (Reply 25): They misunderstood line up and wait for takeoff with line up and clear for takeoff |
Quoting Navigator (Reply 32): But chinese pilots are not known for their language skills and sometimes they even have/ had? a separate radio operator onboard to help pilots operate on international routes even if they lack basic english skills. Extraordinary but 10 years ago it happened, I do not know if it still happens. Chinese airlines have a way to go to come up to international standards both when it comes to operations and communications I think. |
Quoting spacecadet (Reply 34): The phraseology really needs to be looked at here. "Taxi into position and hold" is impossible to mistake for "clear for takeoff". Even if the phrase "hold for takeoff" is used, it is impossible to mistake the word "hold" for "clear" regardless of pronunciation. |
Quoting spacecadet (Reply 34): So glad we changed the standard phraseology from "position and hold" to "line up and wait" specifically to avoid situations like this! It seems to be working perfectly! |
Quoting catiii (Reply 11): I'm not so sure I can. Even if you have basic knowledge of the English language, "China Eastern 516, runway XX line up and wait" doesn't sound a lot like "China Eastern 516, wind xxx at xx, runway XX cleared for takeoff." |
Quoting spacecadet (Reply 30): "Taxi into position and hold" is impossible to mistake for "clear for takeoff". |
Quoting spacecadet (Reply 30): Even if the phrase "hold for takeoff" is used, it is impossible to mistake the word "hold" for "clear" regardless of pronunciation. |
Quoting C680 (Reply 24): Our SOP is abort above 80 kts is only for Fire, Failure, Roll back or loss of directional control. A controller saying "STOP" requires a very quick judgement call. An aborted take off at high speed (in our case over 80 kts) is one of the more dangerous maneuvers you can do in a jet. If the crew cannot see an obstruction, imminent collision, or some other catastrophic problem, its probably best to keep going. IMHO it is much safer to continue the take off and avoid the helicopter traffic that the Japanese controler was worried about. But I don't think anyone on this forum was actually there, so this is all just standard A.NET armchair quarterbacking fun.... |
Quoting Navigator (Reply 28): After applying take off thrust and after IAS 80 knots pilots typically do not take any external orders and ATC are normally instructued to be silent until the plane is safely in the air. I think this applies even if the plane takes off without clearence as long as there are no obstacles in its way... An interuption could be a serious hazard and distraction for the pilots. When the plane has finished the take off procedure ATC comes back with frequency change or whatever but it is common sense to let pilots concentrate on the take off. I would guess that if the take off roll had progressed pilots would not have listened to any stop order. |
Quoting BlueJuice (Reply 35): In this pilot's defense, he seems to understand just fine and gets a little better. http://www.youtube.com/watch?v=3kYtl...7HD8c |
Quoting RobK (Reply 36): The ATC was just as bad as the pilot, calling him "Air China Freight seventy six heavy" for the duration |
Quoting Mir (Reply 37): Which is the correct phraseology (unless the "freight" shouldn't have been in there - I'm not sure about that, but "Air China seventy six heavy" is absolutely correct). |
Quoting RobK (Reply 38): The flight callsign is Air China Freight 1056 [Heavy]. |
Quoting spacecadet (Reply 30): The phraseology really needs to be looked at here. "Taxi into position and hold" is impossible to mistake for "clear for takeoff". Even if the phrase "hold for takeoff" is used, it is impossible to mistake the word "hold" for "clear" regardless of pronunciation. |
Quoting Mir (Reply 39): Listening to the tape again, that's exactly what he was saying. "Air China Freight ten fifty-six heavy." |
Quoting Mir (Reply 37): but "Air China seventy six heavy" is absolutely correct). |
Quoting RobK (Reply 41): but we have our own busy airspace here in the UK yet we can still manage to address all the dots on the screen correctly using their full callsign |
Quoting Navigator (Reply 43): This Air China guy is the worst I have heard so far. The Air China pilots we hear here at ARN are far better than this. This freighter guy should have stayed in China!! |
Quoting RobK (Reply 44): You should listen to the Pacific oceanic comms some time! This sort of thing is quite a regular occurence with the Chinese and Korean airlines. |
Quoting Flight152 (Reply 16): Quoting KC135TopBoom (Reply 16): Nope.... normal take-off performance prior to V2 should still allow to abort within the confines of the runway Umm. No. V2 is takeoff safety speed. The speed typically flown in the event a one engine inoperative situation occurs. You were thinking V1, the aircraft must be able to stop on the remaining runway prior to and including V1. |
Quoting Gonzalo (Thread starter): confusing a Line Up and wait clearance with a take off clearance, I can understand |
Quoting soon7x7 (Reply 48): When I have heard China Eastern over the JFK frequencies they (pilots) are very difficult to understand and JFK tower has to demonstrate extra patience with them as the A346 does not move easily around JFK. |
