KarlB737
63% Support Name Change For YNG
Tue Jan 10, 2012 10:30 pm
625 individuals particapated in a poll to decide whether the name of the airport at YNG should be changed. This poll was conducted through the local support group called YNGAirPartners. The group unoffically bridges the gap between local fliers and new directions the airport may or potentially be seeking. I think it is a good idea in that it keeps a connection from the community and the local airport.
As was noted in an earlier thread nobody is stating that a name change will assist the airport in acquiring additional flight service however this poll was put out just the same.
Currently the airport is called Youngstown-Warren Regional Airport. The new suggested name from the poll is Northeast Ohio Regional Airport.
YNGAirPartners:
http://yngairpartners.org/
Press Release Regarding Name Change:
http://www.yngairpartners.org/files/NameChangeSurveyPressRelease.pdf
YNG Airport:
http://www.yngairport.com/
YNGguins
RE: 63% Support Name Change For YNG
Wed Jan 11, 2012 1:33 am
Results By Name:
36% - Northeast Ohio Regional Airport
19% - Youngstown-Warren Regional Airport
10% - Mahoning Valley Regional Airport
10% - Other (Traficant - Black Hole, etc lol!)
8% - Ohio-Penn Regional Airport
7% - William H. McKinley Regional Airport
6% - Northeast Ohio Regional Airport - TechBelt Field (Tongue Twister!)
4% - Western Reserve Regional Airport
I am PROUD to live in the greatest country on earth: The United States of America!
ssteve
Wed Jan 11, 2012 3:32 am
I think "YNG" should be changed, because I always think it must be in Canada.
kpitrrat
Wed Jan 11, 2012 6:07 am
Im all for the Traficant Idea.....
But seriously, what is this change in name supposed to do? I have not been catching up with WKBN27 lately so I am not sure if this name change is to go along with some type of deal between YNG and the drilling companies? Maybe for renovation/some type of expansion?
If this is really intended go along with the whole gas and oil deal, I would imagine G4 needs to expand their market outside of vacation destinations in order to make this work a little better.
Also, I heard that all drilling has been halted because of the recent frequency of earthquakes happening in the area. There any substance to that?
ajhYXE
Wed Jan 11, 2012 7:22 am
Quoting SSTeve (Reply 2):
While I have known for quite some time "YNG" is actually located in Youngstown, Ohio it may cause confusion for some. Changing this might be difficult as authorities (IATA/ICAO/FAA) seem reluctant to make changes like these.
GO RIDERS!
PezySPU
Wed Jan 11, 2012 5:54 pm
Good point! When I saw the title of this thread I thought it was about some Canadian airport.
KarlB737
Thu Jan 19, 2012 10:55 pm
Quoting KarlB737 (Thread starter):
The story linked below provides a good update regarding the proposed airport name change issue as well as additional flights by Allegiant.
Courtesy: Tribune-Chronicle
Regional Airport Sees Travel Growth
"The Youngstown-Warren Regional Airport posted a second straight year of strong passenger traffic in 2011, but travelers will have a wait a bit longer to find out if the airport will get a name change."
"Dickten said the airport also may be able to get an Allegiant flight to Fort Lauderdale, Fla., starting in May, although that route hasn't been "discussed thoroughly."
"The board tabled a motion to pursue changing the name until commissioners of Trumbull and Mahoning counties, along with the Warren and Youngstown mayors and others, can be consulted."
http://www.tribune-chronicle.com/pag...t-sees-travel-growth.html?nav=5021
KarlB737
Thu Jan 19, 2012 11:04 pm
Here is another writeup on this issue at YNG:
Courtesy: The Vindicator
Name change for Youngstown-Warren Regional Airport?
http://www.vindy.com/news/2012/jan/1...oungstown-warren-regional-airport/
YNGguins
Fri Jan 20, 2012 2:56 am
From the YNG Facebook Page:
We are extremely excited to announce that 70,243 total passengers flew in and out of the Youngstown-Warren Regional Airport in 2011, a 34% increase over 2010! This was the best year at YNG since 1999 when 80,529 total passengers chose YNG. We would like to thank you for your support as we strive to make flying easy for travelers across Northeast Ohio and Western Pennsylvania!
yyz717
Fri Jan 20, 2012 6:59 am
haha I thought YNG was in Canada also, when I first saw the airport code years ago.
Yes....please change the code. Airport name....whatever.
I dumped at the gybe mark in strong winds when I looked up at a Porter Q400 on finals. Can't stop spotting.
bayareapilot
Fri Jan 20, 2012 10:57 am
There are a few other airports in the US besides YNG starting with Y:
YAK - Yakutat Airport, Yakutat, Alaska
YIP - Willow Run Airport, Detroit, Michigan
YKM - Yakima Air Terminal/McAllister Field, Yakima, Washington
YKN - Chan Gurney Municipal Airport, Yankton, South Dakota
