Quoting olddominion727 (Thread starter): |
Quoting olddominion727 (Reply 2): |
Quoting point2point (Reply 5): You are so cruel............. |
Quoting kaitak (Reply 7): Will LH announce the config for the aircraft at the same time as the first route? |
Quoting UA933 (Reply 12): I was told that the first daily routing will be FRA-IAD. |
Quoting abrown532 (Reply 9): You could tell us, but then you'd have to kill us...... |
Quoting aznmadsci (Reply 17): So will it have the F bed and seat if they are now placed in the nose? |
Quoting wilco737 (Reply 15): F class in the nose, |
Quoting na (Reply 4): I am flying FRA-Mumbai at the end of March, but I think that 744-route is not prestigious enough to be the first one with the 748I |
Quoting wdleiser (Reply 16): I will bet you a full fare first class round trip ticket on the 748 that it will have 8 first class seats! |
Quoting LimaNiner (Reply 21): Ick -- just like BA. I *hate* sitting forward of the nose gear, it makes me nauseous while taxiing... |
Quote: What I can say is: It's happening in May. |
Quoting UA933 (Reply 29): Are there any airport-wise restrictions at IAD that would prevent LH from a daily 380 flight? UA and LH have a combined number of 5 flights during the summer. I assume that the 380 would work on that route aswell... |
Quoting something (Reply 30): Is there a delivery schedule for their 748s? How many will they receive in 2012? LH sure has one of the most interesting fleets of all airlines - and not 777 yet *knocks on wood*. |
Quoting wilco737 (Reply 25): I know not a lot people like it to be in the nose |
Quoting Speedbird741 (Reply 32): How is it possible that people don't prefer the nose section? It is just about as private as the upper deck, MUCH quieter than the upper deck, |
Quoting wilco737 (Reply 31): Quoting UA933 (Reply 29): Are there any airport-wise restrictions at IAD that would prevent LH from a daily 380 flight? UA and LH have a combined number of 5 flights during the summer. I assume that the 380 would work on that route aswell... Not that I am aware of. 380 is possible as well. |
Quoting YULWinterSkies (Reply 34): AF flies it to IAD, so certainly there is no restriction, assuming there are adequate gates at the terminal which is used by LH, if this is a different one from AF's. (I have never been through IAD, hence my ignorance!) |
Quoting wilco737 (Reply 35): Question is: do we need so many seats to IAD? |
Quoting SA7700 (Reply 36): Won't you have 2x daily FRA-IAD flights during the Northern hemisphere summer? |
Quoting SA7700 (Reply 36): Granted I see that LH416 will be operated by an A333 and LH418 the 744. Is it a question of frequency or capacity? |
Quoting wilco737 (Reply 37): That gives a good balance between frequency and capacity. |
Quoting jayeshrulz (Reply 41): India is out of the question. LH is seat-capacity wise restricted to Boeing 747-400 ONLY |
Quoting wilco737 (Reply 43): Quoting Roseflyer (Reply 42): The 747-8 will have fewer seats than LH's 378 seat 747-400. But that configuration hasn't been used for the last 2 years. Usually it is F8 C80 Y234 or F8 C66 Y270. |
Quoting Roseflyer (Reply 44): I was assuming that India would allow the 747-8 since it is smaller than the past 747s. Do you know what the limit on capacity to India is? |
Quoting UA933 (Reply 29): Are there any airport-wise restrictions at IAD that would prevent LH from a daily 380 flight? |
Quoting wilco737 (Reply 47): Yes, I heard that something like that is planned. But I guess what is meant here in the thread is the first long haul revenue flight. wilco737 |
