Quoting ADent (Reply 6): So DEN-MKE will be all WN (the one FL flight is switching to WN). |
Quoting GSPSPOT (Reply 8): Didn't WN ABANDON their former MO?? What's up with these announcements?? |
Quoting Atrude777 (Reply 9): MO? |
Quoting GSPSPOT (Reply 10): = Modus Operandi. You know, WN used to go in "under the radar" to under-served airports near other more major metro areas. I thought that model had (very sadly) gone the way of the Dodo Bird. |
Quoting Atrude777 (Reply 4): A lot of WN's West Cities into ATL will have some flights go back to Air Tran due to the integration issues with the code-shares. |
Quoting Atrude777 (Reply 11): ECP, GSP, CHS, are all small markets by defintion and not the "big city/player stations". |
Quoting skymiler (Reply 17): ECP got service when WN was paid quite handsomely to do it by St Joe corp (the land developers). |
Quote: The St. Joe Company is off the hook to Southwest Airlines, at least for now. The land development company has released its 2010 annual financial report and will not have to reimburse Southwest, in accordance with a deal worked out to bring the low-cost carrier to Bay County. Southwest began operating daily non-stop flights to four major cities from the Northwest Florida Beaches International Airport (ECP) in May. “There were no reimbursements to Southwest Airlines during 2010; no losses were incurred per the agreed upon services,” according to St. Joe’s required 10-K filing with the U.S. Securities and Exchange Commission. St. Joe agreed to reimburse Southwest for revenue losses for at least two years in order to snag the carrier’s much-ballyhooed decision last year to operate from ECP. |
Quoting DCA-ROCguy (Reply 21): DAY and CAK will have both WN and FL aircraft running at their FL stations? That means they'll need to get WN number-boarding posts installed in their departure lounges? |
Quoting DCA-ROCguy (Reply 21): Also, does this mean that other FL stations that have flights into big WN stations will see WN metal replacing FL metal before the airlines are integrated? |
Quoting DCA-ROCguy (Reply 21): And does this suggest that these stations could get MDW flights before integration, whenever that will be? |
Quoting swatpamike (Reply 18): Quoting skymiler (Reply 17): The agreement covers 2 years and it remains to be seen if WN sticks there when the contract expires. They will be out of there in a flash. Cheers Mike |
Quoting Atrude777 (Reply 1): DAY-DEN will begin on Southwest Metal. |
Quoting Atrude777 (Reply 4): New STL-ECP |
Quoting knope2001 (Reply 3): DSM-MDW |
Quoting tjwgrr (Reply 26): I predict WN initially will add MDW (2x) and DEN (1x) to GRR based on what's happening in CAK, DAY, and DSM. |
Quoting LoneStarMike (Reply 19): St. Joe off the hook to Southwest, for now |
Quoting sdoyon (Reply 29): Hinting at moving ATL-ORF/SDF to FL metal possibly? |
Quoting OzarkD9S (Reply 30): The way things are looking, WN could replace all FL non-ATL flying before the code-share comes online while FL maintains a viable ATL hub until such time as the two systems can realistically integrate. FL is already gaining back some ATL frequencies as it appears that without the online connectivity the two networks must stand alone at this point. |
Quoting knope2001 (Reply 3): CAK-MDW CAK-DEN |
Quoting knope2001 (Reply 3): DAY-DEN |
Quoting Atrude777 (Reply 4): New PDX-AUS |
Quoting iowaman (Reply 27): I must admit I would of bet wrong in guessing WN would of needed at least some subsidies to keep going. Kudos to ECP and WN for working out so well. |
Quoting DiamondFlyer (Reply 34): They don't call it the Redneck Riviera for no reason. And by what the traditional clientele of WN has been, they go hand in hand, IMO. |
Quoting SurfandSnow (Reply 32): For now, CAK still has its FL nonstops to BOS and LGA. I wonder when those scarce LGA slots will be reassigned for a more important WN market (BNA, ATL, HOU, and/or MCI, if I had to guess), |
Quoting SurfandSnow (Reply 32): This is a first - a WN station with just one daily flight! Moreover, there is no access to a vast chunk of the canyon blue network (WN typically offers every market it serves the ability to reach virtually every other station in 2 stops or less). |
Quoting knope2001 (Reply 3): CAK-DEN DAY-DEN |
Quoting John (Reply 40): Does WN plan on adding ATL from BDL, MHT and PVD? |
Quoting bjorn14 (Reply 38): Those routes started with the usual WN strategy of 6-8 daily flights. |
Quoting jfklganyc (Reply 43): What a bizarre mess this merger is turning into. And I don't say mess in a horrible way...just a messy way. |
