Quoting strfyr51 (Reply 3): That "Official" LETTER could be a precursor to an actual Penalty. |
Quoting tp1040 (Reply 1): Does everyone who posts a video get a letter? |
Quoting tp1040 (Reply 1): That said, the rule is the rule and it is not up to the passenger to decide what rules to follow. |
Quoting tp1040 (Reply 1): more importantly, no danger is created. |
Quoting FlyBlue777 (Reply 2): This is just ridiculous, and laughable. |
Quoting lightsaber (Reply 6): The issue is the aircraft must be certified to be safe or it must be disallowed. |
Quoting lightsaber (Reply 6): The rule is to prove less than a 10^-7 chance of a serious impact. If the electronic makers want to pay to certify with each aircraft type, they are welcome to. |
Quoting mmedford (Reply 8): Isn't the ipad certified by the FAA for flight? or is that only special ones? |
Quoting 737tanker (Reply 11): From what my airline has told us the ipads used by the flight crew are built separately and have been certified by the FAA. That is one reason why the airline issues the ipads to the flight crews and the pilots just don't go out and buy their own. Additionally each airline had to demonstrate to the FAA that the ipads caused no interference when used, and the test was done on each model the airline operates. |
Quoting flightsimer (Reply 13): I'm calling BS on that one... There are multiple reasons why it makes sense for the airlines to buy then distribute than having the pilots bring there own. |
Quoting Mir (Reply 14): The biggest being that there are only certain applications that can be loaded onto the iPad |
Quoting PGNCS (Reply 9): Because you are more qualified than the certification authorities to make this judgement? Please elaborate on these qualifications. |
Quoting PGNCS (Reply 9): I have been in the cockpit when electronic devices interfered with displays, instruments, and automation. Have you? |
Quoting DTWLAX (Reply 16): Did they see any aircraft go down due to electronic devices? |
Quoting DTWLAX (Reply 16): And how did the certification authorities come up with this rule? |
Quoting DTWLAX (Reply 20): so how did they come up with the rule? |
Quoting DTWLAX (Reply 16): And how did the certification authorities come up with this rule? Did they see any aircraft go down due to electronic devices? |
Quoting flightsimer (Reply 13): Under part 91 (General flights) they are certified to be used as the sole replacement of ALL paper charts and planning. They also have a GPS component to them for use as reference only (not to be used as sole navigation) which will transpose an aircraft onto any sectional chart, Low/High enroute chart and all approach plates. |
Quoting csavel (Reply 7): Also consider that if there is a rejected take-off or similar emergency, those I-pads, Kindles what have you can go flying and really hurt someone. I sure as hell don't want someone with face stuck in a kindle sitting behind me. You might ask then why not ban books, especially hard covers. Good question!!! probably because they were grandfathered in and with a book, even a hardcover, if it goes flying the likelihood is that the covers and pages will spread out, thus slowing down the momentum. |
Quoting futureualpilot (Reply 17): I've been up front when our avionics were interfered with, and yes, it was a PED causing the interference. Until the FAA sees fit to change this rule, why risk anything? It's just a few minutes. Drop the electronic device, enjoy the view. It'll be good for you. |
Quoting kcljj (Reply 26): Disregarding all the merits of the rule, I think the FAA is right in issuing the letter. I think that even the FAA knows a good amount of people disregard the rule and have ipads, phones etc on when they are not supposed to. However, they also know that it is nigh on impossible to penalise everyone who flaunts it. In this case, it was clearly his stupidity which caused the FAA to issue the letter. If you are going to break the rules, at least do it discretely. If you start waving your arms in the air when you are breaking the rules, you should expect to be punished. By slapping his name onto the video, he pretty much incriminated himself and because he is a known figure, the FAA obviously smelt blood. |
Quoting tp1040 (Reply 1): One only has to go to youtube and see that the rule is ignored, but more importantly, no danger is created. |
Quoting flightsimer (Reply 13): I use my ipad on all of my flights with foreflight, yet I bought it off the shelf at target. The fact that I can fly any plane I want under part 91 and use an ipad for the sole means of all my navigational charts and planning and in doing so be completely legal yet the same exact ipad I'm using in my seat outside of the cockpit could cause interference is complete and utter BS... |
Quoting zeke (Reply 30): Are you sure your specific FAA part 91 approval requires no backup ? |
Quoting DiamondFlyer (Reply 31): Again, no approval required, as there is no regulatory requirement for charts to begin with. |
Quote: The FAA does not approve or endorse any particular product. Rather, they set forth guidelines that operators follow and use to seek approval with their local FSDOs and PIs. Every operation is different - different aircraft, different training requirements, etc. - and thus each operator has to seek approval independently. The FAA's guidance is holistic - the EFB hardware and software selected is just one part of the overall process of adopting and getting authorization to utilize and EFB. |
Quoting zeke (Reply 32): from http://www.foreflight.com/approved/ |
Quoting DTWLAX (Reply 16): They must have interfered with the displays, but are you sure those interferences were due to electronic devices in the back of the plane? Also can you please elaborate how a digital camera interferes with displays and automation in the cockpit? |
Quoting DiamondFlyer (Reply 24): How can a device be certified to replace charts that are never legally required to begin with. That's why one can use an iPad/whatever device to have charts for a Part 91 operation. |
Quoting Mir (Reply 35): Careful with the blanket statement - charts are legally required if you're operating a large or turbine-powered multi-engine airplane. See 91.503(a)(3) and (4). |
Quoting JQflightie (Reply 38): |
Quoting zeke (Reply 30): I would like to see you prove the comment of "no danger", there is additional risk, however very minor. For example there has been a case where an iPhone started to combust in a phase of flight where the device was supposed to turned off in Australia. |
Quoting futureualpilot (Reply 17): Is It really that hard to follow a rule for a half hour until you can get your precious electronic device back? I've been up front when our avionics were interfered with, and yes, it was a PED causing the interference. Until the FAA sees fit to change this rule, why risk anything? It's just a few minutes. Drop the electronic device, enjoy the view. It'll be good for you. |
Quoting strfyr51 (Reply 3): You might think the rule is Stupid But if you've got $10K to throw around?? Don't stop.. And when the FAA places him on a NO FLY list then it'll cost him 5X as much to get OFF of it.. |
Quoting 737tanker (Reply 11): From what my airline has told us the ipads used by the flight crew are built separately and have been certified by the FAA. |
Quoting airbazar (Reply 43): Quoting 737tanker (Reply 11): From what my airline has told us the ipads used by the flight crew are built separately and have been certified by the FAA. There's no such thing. |
Quoting airbazar (Reply 43): What is likely happening is that companies such as your airline can taylor the iPad iOS to their needs (i.e. setup restrictions). |
Quoting rfields5421 (Reply 19): The devices used in the cockpit are to be only loaded with certain programs and to not be WiFi, GPS/, or 3/4G enabled except under very specific conditions while in the aircraft. |
