Quoting cipango (Reply 3): I have flewn FR through STN countless times and NEVER used a jet bridge. |
Quoting kl911 (Reply 7): Quoting cipango (Reply 1): AFAIK They are required to use a Jetbridge in MAD What is the reason for this? |
Quoting GT4EZY (Reply 8): Primarily it is down to the speed of turnaround. I personally, as crew, prefer airbridge and i don't think boarding is that much slower because of it. |
Quoting Pelle (Reply 2): Well I know for sure that they use jetbridges in STN, and I'm prette certain that they dont use jetbridges i BUD. |
Quoting Viscount724 (Reply 9): I expect safety considerations are a factor. Having passengers wandering around busy airport ramps, especially where both front and rear doors are used for boarding/deplaning, is less safe than keeping passengers and ramp operations totally separated as they are when bridges are used. |
Quoting lightsaber (Reply 10): Does FR use two sets of stairs too? |
Quoting Byrdluvs747 (Reply 13): Are we talking about boarding from the front and the rear of the plane? Otherwise, I don't get it. How do jetbridges slow down boarding. Its not like using the tarmac allows pax to board any faster than sequential. |
Quoting MCO2BRS (Reply 12): Yes, we have the built-in stairs under L1 and mobile stairs at L2. It makes turn around so much easier. |
Quoting Pelle (Reply 2): I have flewn FR through STN countless times and NEVER used a jet bridge. |
Quoting Burkhard (Reply 16): This had never worked with jet bridges. For me, jet bridges are one of the most stupid inventions in aviation, cost the industry millions and block any progress. |
Quoting Burkhard (Reply 16): Yes, always, and that makes boarding SO quick. I have the following story to share: I was on an FR flight HHN-STN departure 6:30 some weeks ago, plane was boarded in time. At 6:28, I saw two mechanics enter the plane and the cockpit, and that was no good sign for an in time departure. At 6:35, the pilot told us they decided to change plane, we should go over to the neighbor plane ( which was scheduled to go to Spain at 7:30), so we all 186 people + crew left the plane through the 2 exists, went around it, to the other plane, boarded through the two stairs, and the last passengers entered the cabin I looked on my clock at 6:43, so 8 minutes for a complete debarking and boarding. We then left at 6:55, which I must say was an extremely good outcome... This had never worked with jet bridges. For me, jet bridges are one of the most stupid inventions in aviation, cost the industry millions and block any progress. |
Quoting offloaded (Reply 21): Back to FR though, I am sure they must pay for usage otherwise why, at airports such as FAO, they pull right up to them and then use the aircraft stairs, a 50m walk, then up the stairs at the back of the airbridge and into the terminal. |
Quoting kl911 (Thread starter): i'm wondering if FR also uses them at Budapest T2 |
Quoting AirbusA6 (Reply 24): Then the front stairs are out of action, as the person is raised on a special lift, and everyone has to go through the back staircase. |
Quoting MCO2BRS (Reply 4): The only Spanish airports we don't use them at are GRO, REU, MJV. |
Quoting skipness1E (Reply 26): Industry standard is high lift vehicles use the starboard side. |
Quoting idlewildchild (Reply 20): This became a big issue at ALC where FR has decided to pull many flights because they are forced to use jetbridges now, costing them time and money. |
