Quoting gilesdavies (Thread starter): I'm just curious why the airline chose to purchase the LR version? |
Quoting Stitch (Reply 1): Also, the 777-200LR is a more efficient airframe than the 777-200ER on long-haul missions and it can carry a full load a fair bit farther than a 777-200ER. |
Quoting Jean Leloup (Reply 2): I guess the question is, then, are they making used of this extra capability? Are they actually lifting more (cargo+pax) to HKG than they could if they just had teh 777-200ER? If not, then it still seems like a waste. But given the fact that they previously operated the A340-500 on the route at a time when the 777-200ER was available, I'm thinking that there is indeed a heavy and profitable cargo load that takes advantage of the capability. |
Quoting Jean Leloup (Reply 2): Are they actually lifting more (cargo+pax) to HKG than they could if they just had teh 777-200ER? |
Quoting yyz717,
There is commentary in a recent thread that AC is considering long term leases on additional 77L's from Air-India that the Indian carrier is planning to remove from service. reply=5: |
Quoting Viscount724 (Reply 9): AC has to carry all their cargo on passenger aircraft. |
Quoting Kermode (Reply 10): Precisely, and if I'm not mistaken AC had ordered 2 777F's before they cancelled them and took other passenger versions. Could be wrong about what they took in return or if anything at all but I know they had ordered 2 freighter versions. |
Quoting XT6Wagon (Reply 4): You are also forgetting that the 772LR is in the same family as the 773ER, so it makes far more sense to pay a bit more upfront to get the 772LR over the 772ER if you are going to operate the 773ER. |
Quoting cat3dual (Reply 11): All 777s are in the same "family". |
Quoting Kermode (Reply 8): **Note Air Canada ordered their 777-200LR's with the 3 optional fuel tanks boosting fuel capacity from 181, 280 L (47, 903 US gallons) to 202, 570 L (53, 515 US gallons) |
Quoting ghifty (Reply 13): Is it easier and/or more cost effective to train between the 77L and 77W because they have the same wing and (almost) engines, than say, the 77L and 77E (-200ER)? |
Quoting cat3dual (Reply 16): A 777 is a 777, training-wise. Load planning is an entirely different animal, but even that is all computerized anyway. |
Quoting cat3dual (Reply 16): No. Here at Delta, we have two 777 flight simulators. One -232ER, one -232LR. The pilots train between them. There is only difference training between the subtypes. A 777 is a 777, training-wise. Load planning is an entirely different animal, but even that is all computerized anyway. |
Quoting XT6Wagon (Reply 17): Not for MX. The 777LR family is quite a bit different than its 777ER brothers. While its closer than a completely differing plane, its still enough to keep many airlines that COULD use a 772LR on some routes from buying said frames and mixing them into thier 772ER fleets. |
Quoting seabosdca (Reply 15): Are you sure about this? I hadn't previously heard this, and it wouldn't make a lot of sense given their route network. |
Quoting Kermode (Reply 19): |
Quoting Kermode (Reply 19): I just made a deduction based on info from Air Canada and Boeing. Air Canada's website ( http://www.aircanada.com/en/about/fleet/77L.html ) has fuel capacity listed as 202,570L and according to Boeing ( http://www.boeing.com/commercial/777family/pf/pf_lrproduct.html ) three additional fuel tanks provide 202,570L. Which led me to that conclusion. |
Quoting Darksnowynight (Reply 20): it does sort of look as though it was cut/pasted from Boeing |
Quoting Stitch (Reply 21): I don't believe any 777-200LR operator has chosen to install additional fuel tanks. |
Quoting longhauler (Reply 22): But looking at the AOM's for our Triples show a fuel capacity of 181,270L in three tanks for both the -233 and the -333. |
Quoting Kermode (Reply 8): Also YYZ-YVR-SYD was operated with a 77W before they received their 77L:s and if I remember correctly there were some payload restrictions. |
Quoting pnwtraveler (Reply 24): Lower volume routes get the 763 or 333. |
Quoting seabosdca (Reply 28): The 333 has exactly the same useful hold volume as the 77L, and should be able to use all of it on YYZ transatlantic routes. |
Quoting Stitch (Reply 34): Quoting 135mech (Reply 33): However the 333 has a siginificantly less amount of range: With a 45t payload, range is ~3900nm for an A330-300E (per the Airbus ACAP), which puts much of Western Europe within range of |
Quoting 135mech (Reply 33): However the 333 has a siginificantly less amount of range: |
Quoting LHCVG (Reply 31): OTOH, is the 77L pretty similar to the 77W for mx? I'm curious to know if having all those 77W parts offers significant mx commonality. |
Quoting DocLightning (Reply 37): AFAIK, they are very similar. A 77L is basically a 77W shrink. It cost Boeing next to nothing to develop (especially given that they were going to develop the 77F). The engines are 100% physically identical between the L/W models other than a software plug. In fact, I'm not sure that there are any parts that the 77W has that the 77L doesn't except for those directly related to the fuselage length. |
Quoting XT6Wagon (Reply 38): yup. The 777F, 772LR, and 773ER are the same family. The 772ER and 773 are the same family. |
