Quoting olddominion727 (Thread starter): Russian aircraft other than DHL... |
Quoting olddominion727 (Thread starter): Because it's Russian and I can't think of the last time a Western Carrier owned a Russian aircraft other than DHL... does it not have the range or clean fuel burn or range like the 757 or A321neo... one would think they'd be fairly cheep... and could get pretty quickly... just curious |
Quoting Polot (Reply 6): I don't know about range (don't have time to look it up), but the TU204 certainty does not have the fuel burn that the A321neo and 737MAX are expected to have. |
Quoting olddominion727 (Thread starter): Why are all of the carriers pushing for something with replace the 757 |
Quoting tdscanuck (Reply 8): there will never be a direct replacement because the carriers don't want one. |
Quoting homSar (Reply 11): Western airplanes have been built under license in China previously (MD80s, and A320s either already or coming up in the future). Might one of the manufacturers decide to license an existing design to be built in one of the existing Russian factories, or is their level of production support simply not there to ensure a worthwhile endeavor? |
Quoting N243NW (Reply 10): When you said airlines "want something more capable than the 757 in the future" I'm sure you meant in terms of fuel efficiency. The airlines will be able to compromise by using A319s or 73Gs on the routes that require good field performance and using A321s or 739s on the routes that require the capacity. |
Quoting tymnbalewne (Reply 5): |
Quoting tymnbalewne (Reply 5): I'll be on a TU-204 as a passenger in about 2 weeks. Can't wait! |
Quoting Trucker (Reply 24): Hope UAC's airplanes are better than it's website. |
Quoting ATLTPA (Reply 23): How cool is that? |
Quoting ATLTPA (Reply 23): Hopes for a medium-sized popular Russian twin-jet airliner are probably best saved for the MC-21, which was designed as a Tu-204 replacement: http://www.uacrussia.ru/en/models/ci...s-21/ |
Quoting olddominion727 (Thread starter): TU204 seems to be available for the build. Because it's Russian and I can't think of the last time a Western Carrier owned a Russian aircraft other than DHL... |
