Quoting crapper1 (Reply 5): How does the md11 handle slow and dirty compared to the DC-10 ? |
Quoting crapper1 (Reply 5): What are the typical things you can do in large aircraft that will get u in trouble on the 11? |
Quoting flyer737sw (Reply 7): The MD-11 is tougher to control at lower speeds since pilots have a tendency to input to much control. This is directly related to the horizontal stabilizer being 40% smaller than the DC-10 This design has been an obvious flaw to the MD. Initially it was made smaller to hope for faster cruise speeds and a little improvement on fuel burn. |
Quoting Reply 8): I assume you meant to say vertical stabilizer. Even if you did, this doesn't make much sense as below a certain speed (as in this case) lateral control is made by the nosewheel tiller. |
Quoting beechnut (Reply 10): The MD-11 issue is pitch control at lower airspeeds, which ends up causing hard landings especially in gusty x-wind conditions. The aircraft has a high wing loading, longer fuselage than the DC-10 it was derived from, and less pitch authority due to the smaller horizontal stabilizer, which makes it a handful in certain conditions. |
Quoting Viscount724 (Reply 12): KLM has been flying the MD-11 for almost 20 years in all weather conditions all over the world and I can't recall any incidents. Why haven't they had any problems? |
Quoting fleabyte (Reply 11): I don't think that this bird will ever fly again |
Quoting Viscount724 (Reply 12): KLM has been flying the MD-11 for almost 20 years in all weather conditions all over the world and I can't recall any incidents. Why haven't they had any problems? Video of landing at YUL in a very strong crosswind. Landing looks fairly smooth. |
Quoting Spacepope (Reply 14): I think it will be repaired. It's not too different than another Centurion gear collapse on the MD-11 from 2009 in Montevideo. http://aviation-safety.net/database/...020-0 |
Quoting Viscount724 (Reply 12): KLM has been flying the MD-11 for almost 20 years in all weather conditions all over the world and I can't recall any incidents. |
Quote: A brazilian pilot holding short of rwy 15 described the event as a bounced landing with the gear colapsed on the third bounce. |
Quoting prebennorholm (Reply 20): The MD-11F is certified to carry 200,000 lbs payload, almost identical to the much larger B744F. |
Quoting Spacepope (Reply 14): It's not too different than another Centurion gear collapse on the MD-11 from 2009 in Montevideo. |
Quoting AirlineCritic (Reply 17): Interestingly, the avherald comments say this might be the same aircraft. Dunno, the regs do not match. But I don't know if they would change in some cases. |
Quoting andrefranca (Reply 25): According to my friend at AZUL, she's supervisor (VCP is Azul's base), only 244 flights cancelled so far! |
Quoting voar (Reply 31): Aircraft still has not been removed and looks like it will take much longer to do so. Over 400 flights have been cancelled so far out of VCP. Airport has been closed for over 40 hours now. |
Quoting wjcandee (Reply 33): Ugh. AvHerald is filled with complaining about this "dangerous" aircraft. Point out that "only KLM" still operates it in pax configuration. |
Quoting wjcandee (Reply 33): Oddly, the near-disaster smash-it-on-the-runway World accident at BWI a couple of years ago involved a DC10, which according to the posters in this forum is so-much-more-stable. In that one, after smashing the airplane onto the runway, they went around with, instrument-wise, pretty much the whiskey compass. And then greased the second landing. And then the aircraft was written off. So...it isn't that simple, folks. |
Quoting SCL767 (Reply 37): Brazil’s civil aviation authority (ANAC) has issued a warning to Centurion Cargo that, "it will take “appropriate measures” against Centurion, which could include fines, restrictions on operations and even a suspension of the airline in Brazil." |
Quoting SCL767 (Reply 39): Aren't both government entities? |
Quoting incitatus (Reply 38): |
Quoting incitatus (Reply 40): |
Quoting Max Q (Reply 34): By ANY standard it has a very poor safety record. |
Quoting Viscount724 (Reply 44): I think you should differentiate between cargo and passenger operations. Ignoring Swissair 111 where the aircraft type wasn't a factor, I believe there have only been 5 fatalities in 2 events in MD-11 passenger operations in 22 years of service. |
Quoting Max Q (Reply 46): Quoting Viscount724 (Reply 44): I think you should differentiate between cargo and passenger operations. Ignoring Swissair 111 where the aircraft type wasn't a factor, I believe there have only been 5 fatalities in 2 events in MD-11 passenger operations in 22 years of service. Whether it has boxes in the back or people it has a very bad record. |
Quoting Viscount724 (Reply 47): How many accidents involving passenger MD-11s are you considering? As mentioned, I only see 2 with 5 fatalities (plus Swissair 111). Many other types have far worse records in passenger service. |
