Quoting srbmod (Reply 2): They just may not have to remove their shoes, belt, jacket, laptops from their bags, or their liquids from their bag. |
Quoting PlaneInsomniac (Reply 3): Well, if I can manipulate the system to ensure that these checks do not (ever) apply to me, it becomes a security issue. |
Quoting Cubsrule (Reply 4): checks would still sometimes apply |
Quoting PlaneInsomniac (Reply 5): As far as I understand, the flag in the barcode determines whether "sometimes" is today. And if you can manipulate it, this in theory means that "sometimes" never comes... |
Quoting gegarrenton (Reply 6): That isn't how it works. You have to be in the Pre Check database to start with. |
Quoting PlaneInsomniac (Reply 3): modify any given boarding pass (under this pre-check program) |
Quoting Cubsrule (Reply 7): If the Pre Check checkpoint is not open, no one gets Pre Check regardless of what his boarding pass says. |
Quoting PlaneInsomniac (Reply 8): ...which is why I wrote... |
Quoting gegarrenton (Reply 6): Now, if you have had a back ground check and are still going to do something, well, that's a totally different conversation. |
Quoting PlaneInsomniac (Reply 3): One could simply take the electronic version of the boarding pass (e.g, the PDF), manipulate the barcode, print it out, and arrive at the airport knowing that one will not be subjected to those thorough security checks. |
Quoting TJCAB (Reply 13): hmm, the really scary part is that they feel that these secondary "random" checks are required in the first place. What does this tell us about the routine security that apply to the masses? |
Quoting chrisair (Reply 12): Quoting PlaneInsomniac (Reply 3): One could simply take the electronic version of the boarding pass (e.g, the PDF), manipulate the barcode, print it out, and arrive at the airport knowing that one will not be subjected to those thorough security checks. No you can't actually. There's a digital signature on all of the barcodes. |
