Quoting 777222LR (Thread starter): But something that bugs me about the airplane is that it somehow seems much smaller, than even an A332, almost the size of a 767 to me, at least visually, even though I know this is not the case. |
Quoting 777222LR (Thread starter): Here's what I have felt has caused my eyes to believe this. |
Quoting 777222LR (Thread starter): These things combined, make the 787 look less substantial to me. What I really need, is that one time shot of it next to an A330, 777, and 767 to get an accurate comparison. I know there is something similar here on A.net in Manchester of an Ethiopian I believe. But I guess I will not get a full feel of the size until then. Does anyone agree with what I'm trying to explain here? Can anyone provide any good pictures of the size of this aircraft in relation to other planes/objects? I'm just having a hard time figuring out the size of this aircraft in relation to space. |
Quoting ORDFan (Reply 8): The question I have been wanting to ask is what is the distance from ground to the bottom of the fuselage, especially relative to the 767 or 777. Can a man/pilot stand up straight below the 787 fuselage near the main gear?? |
Quoting 777222LR (Thread starter): These things combined, make the 787 look less substantial to me. |
Quoting DocLightning (Reply 18): Does anyone have a 777 vs 787 fuselage cross-section comparison? |
Quoting 777222LR (Thread starter): Does anyone agree with what I'm trying to explain here? |
Quoting JoeCanuck (Reply 7): The cockpit windows have always thrown me. Proportionally, they do make the plane seem like a much smaller plane but I got my eyes opened when I saw the 787 at Oshkosh last year...it is massive. |
Quoting Fiedman (Reply 25): http://pages.videotron.com/camsim/data.htm |
Quoting FlyDeltaJets (Reply 27): Does the cargo hold take 2 LD2s or LD3s side by side? The 767 can only do 2 LD2s side by side, so im assuming that based on the outlines that the 787 would be the same, if not that means the 787 is wider than the 767. |
Quoting ORDFan (Reply 8): Can a man/pilot stand up straight below the 787 fuselage near the main gear?? |
Quoting FlyDeltaJets (Reply 27): Does the cargo hold take 2 LD2s or LD3s side by side? |
Quoting FlyDeltaJets (Reply 27): im assuming that based on the outlines that the 787 would be the same, if not that means the 787 is wider than the 767. |
Quoting LH422 (Reply 26): It's not just the size of the passenger windows but the spacing that has my subconsciousness confused when looking at it from the outside. I think it's one window per economy row, whereas on any other plane it's close to two. |
Quoting 777222LR (Thread starter): almost the size of a 767 |
Quoting georgiaame (Reply 6): Looks like a somewhat stubby 767 |
Quoting jporterfi (Reply 9): until I saw this illustration |
Quoting tdscanuck (Reply 30): A dead giveaway is when you can get a shot of the flight deck windows with a pilot inside...that really gives you a sense of scale |
Quoting zkojq (Reply 2): To me the 787-8 looks rather stubby and kind-of awkward |
Quoting tdscanuck (Reply 30): A dead giveaway is when you can get a shot of the flight deck windows with a pilot inside...that really gives you a sense of scale: https://www.airliners.net/photo/All-N...6419/ |
Quoting tarheelwings (Reply 34): |
Quoting 777222LR (Thread starter): 1. The windows and cockpit windows are HUGE. Because of their size, and their wider spacing, when looking at the fuselage, they make the fuselage seem smaller and shorter than what it really is. 2. The engine nacelles have a larger "lip" on them, which makes them look less substantial than what they are. 3. The 787 has shorter landing gear when proportionally compared to the 777 or A330. 4. The vertical stabilizer is thinner than other aircraft of this size. These things combined, make the 787 look less substantial to m |
JL008 on final to Bos Rwy 27, Sep 16, 2012 |
JL008 on short final to Bos Rwy 27, Sep 16, 2012 |
Quoting Viscount724 (Reply 21): Exterior fuselage width for all Boeing widebodies: 747 - 21 ft. 4 in. 777 - 20 ft. 4 in. 787 - 18 ft. 11 in. 767 - 16 ft. 6 in. |
Quoting tdscanuck (Reply 30): A dead giveaway is when you can get a shot of the flight deck windows with a pilot inside...that really gives you a sense of scale: |
