http://www.singaporeair.com/jsp/cms/...K/press_release_news/ne121101.jsp.
This is good news from SIA. Then they just need to change the B777-200ER to B777-300ER
Megatop
Quoting infinit (Reply 2): Any idea how they are doing on CPH? I reckon there isn't much business travel or O&D pax between SIN and CPH, probably a lot less than AMS. But I could be wrong |
Quoting megatop (Thread starter): SIA is to increase Copenhagen services from 3 times a week to 5 times a week. |
Quoting nethkt (Reply 8): I'd say poor SK. Not only the middle eastern carriers are stealing their pax. Both SQ and TG are also doing good job increasing their flights and pax. |
Quoting ARN" class="quote" target="_blank">ARN (Reply 1): Apparently this is not the case. The Stockholm region looses 2,3 mrd SEK annually due to lack of intercontinental links, stated in a report from Stockholm Regional Council. http://www.flygtorget.se/Aktuellt/Artikel/?Id=9495 LAX, ATL, PHL, SIN, JNB are on the wish list, among others |
Quoting changyou (Reply 7): FRA and NYC are a huge financial hub for SIN and SQ. |
Quoting megatop (Thread starter): This is good news from SIA. Then they just need to change the B777-200ER to B777-300ER The B777-200ER needs a "kind hand", as they are becoming rather old in the SIA world. |
Quoting SIA747Megatop (Reply 17): SIA will soon refurbish the 77E's that plough routes such as CPH, AMS, IST, CPT-JNB with the current long haul business product (1-2-1) and these should be progressively introduced in Q1 2013. |
Quoting lax888 (Reply 18): However will they decrease the C class even more then? Currently there are 30 seats in C with a 2-2-2 layout. If they would do a 1-2-1 layout this would mean that there are only 20 seats left in C unless they reduce the Y cabin a bit. |
Quoting ARN" class="quote" target="_blank">ARN (Reply 1): Given the problems with SK one wonders why some major Swedish banks extended some loans to the Scandinavian carrier this past weekend. One scenario could be splitting SK into three new companies. Swedish business environment would probably be better served with a legacy carrier based at ARN. All those billions pumped into SAS could instead have been the start up capital for a new carrier. Lower salaries and ambitions to make ARN a hub in cooperation with Stockholm-Arlanda and Swedavia. |
Quoting SIA747Megatop (Reply 20): Correct, the new configuration on these aircraft will be 26J 236Y. Edit: So far, we're looking at a mid January EIS. |
Quoting ARN" class="quote" target="_blank">ARN (Reply 1): Possible longhaul destinations could be JFK, NRT |
