Quoting Tdan (Reply 1): This is why you can never judge a route's financial performance based on LF alone. Huge local market that is essentially 50% F/C/J traffic. |
Quoting Tdan (Reply 1): Average loads on BA out of IAH are around 60% for the full year based on HAS's traffic statistics. |
Quoting bobloblaw (Reply 3): Even if LF is not a good proxy for profits, you should still use a lower cost plane and not haul a lot of dead weight. Unless the 744 is needed for cargo. |
Quoting ely747 (Reply 11): Going back a couple weeks there were some comments in regards to 5 years since BA38 crash and to be honest I was actually surprised to find out there were only 152 pax on that 11hr flight |
Quoting raffik (Reply 12): I suppose it depends on the cargo load and more importantly, how many F/J passengers there were of that 152 people. |
Quoting bobloblaw (Reply 3): I am surprised that BA doesn't use a 777. Even if LF is not a good proxy for profits, you should still use a lower cost plane and not haul a lot of dead weight. Unless the 744 is needed for cargo. |
Quoting bthebest (Reply 6): Quoting bobloblaw (Reply 3): Even if LF is not a good proxy for profits, you should still use a lower cost plane and not haul a lot of dead weight. Unless the 744 is needed for cargo. If you have a plane to spare - I imagine all the 777s are being used on other routes that don't have the high F/J loads. |
Quoting factsonly (Reply 13): If you think 138 pax. on a B747 is low, I can tell you that I once departed IAH with just 7 pax. on a B747-200 heading for MEX. There were ten cabin crew on-board to handle just 7 pax, they literally had to search the cabin to find them. It was along time ago, but some may be able to guess the airline. |
Quoting bobloblaw (Reply 3): Keep in mind its also February. Slowest month on the North Atlantic. |
Quoting BostonBeau (Reply 26): I was on a TWA 747 red-eye once, LAX-BOS in the 1970's, and there were 12 of us passengers. The FAs were kind enough to stow armrests for us so that we could stretch out across 3 seats and sleep. |
Quoting AZA330 (Reply 29): I was on BA 197 on March 1st last year, the later of the two LHR-IAH daily flights. The 744 was just about empty, with not more than 80-90 people on board. Club was almost full both upstairs and downstairs, so I figured that was the way BA can afford these kinds of flights. However, does cargo help also? |
Quoting LH707330 (Reply 28): Why did I then still manage to spend >1k getting across? Maybe I need to book sooner next time. |
Quoting BA0197 (Reply 37): BA197 left tonight with 13 in F, 52 in J, 12 in W and 56 in Y. 133 total. BA made money |
Quoting GSTBA (Reply 24): have been full and WTP normally 80% full. That's is both on the 77W and Hi J 747. It is worth remembering that IAH is BA's 3rd highest earner for revenue across the network. With I believe only LOS and JFK making more. |
Quoting aaexecplat (Reply 42): Load factor means little. If you work for an oil company and travel that kind of flight (time), you are traveling in J or F. That is part of what we are subsidizing at the pump. |
Quoting fcogafa (Reply 41): I wonder why Virgin haven't jumped on the LHR-IAH bandwagon if the revenue is so good, that is their usual way of working. |
Quoting lightsaber (Reply 39): Is this route scheduled to go to the A380 for BA? It seems like a natural fit with 14F/97J/55W/303Y. |
Quoting IAH59 (Reply 32): Why doesn't BA fly the 744 in the afternoon and use the 777 in the evening? |
Quoting BA0197 (Reply 45): Why not though? I would think that the later arrival into LHR would reduce transit times for people continuing onto LOS, DME, SIN etc. The earlier departure is naturally suited to pax conecting within the UK and Europe. The late departure also allows for people who are finished with work on Friday to leave the US on the same day that night. |
