Quoting rufusisgod (Reply 8): Having crew away from base for 1-2 weeks |
Quoting PhotoLPPT (Reply 5): Saw it the other day doing a tech stop in SID. Can't tell if it is a regular occurence, though. |
Quoting theobcman (Reply 16): If you choose to break your journey up with a stay on Ascension then you will be billed for the extra leg this will add to your flight. The fare for individual ‘legs’ are given below. |
Quoting theobcman (Reply 16): If you choose to break your journey up with a stay on Ascension then you will be billed for the extra leg this will add to your flight. The fare for individual ‘legs’ are given below. Fare Type Tariff BZZ-ASI ASI-FI Adult (Duty) Return £925 £645 Single £467 £330 Child/Student Return £515 £360 Single £261 £185 Group Tourist Return £1010 £1010 Single £510 £510 Standard Econ Return £1122 £1122 Single £565 £565 |
Quoting GB777 (Reply 6): CS-TQL has been doing the Falklands flights but this leaves the fleet soon and will be replaced with CS-TQY |
Quoting debonair (Reply 22): Strange, I thought AirTanker Services will take over the flights with the arrival of new A330's Voyagers. Why is AirTanker Services not flying for the MOD/RAF being a passenger airline (despite the name AirTanker)? |
Quoting rutankrd (Reply 28): Again the commercial trouping and cargo operation to Stanley will be cost benifical on a civil lease rather than with the rates air tankers charge |
Quoting finnishway (Reply 29): Voyagers to Falklands once a month or something like that? |
Quoting Bongodog1964 (Reply 31): The same will probably happen with the Falklands Airbridge, Airtankers hire rate will be far above Titan and even further above Hi Fly, so the business will go to them. |
