Quoting planiac787 (Thread starter): With the 767 slowly coming to age...what would be the ideal replacement for it... |
Quoting planiac787 (Thread starter): Here is an aircraft that was built to do the ultra long haul routes and save an airline fuel... but now with the problems its facing and a potential range cut coming there way maybe 787 is the right choice... |
Quoting ClassicLover (Reply 1): The 787, which is 30% cheaper to operate than a 767 according to reports from ANA and JAL when the 787 was operating. |
Quoting BD338 (Reply 2): I wouldn't look at it as a straight replacement for role/mission question. Airlines will look at the missions and the aircraft they need in todays environment to make that profitable. A lot has changed since many 767s were ordered and delivered, the whole dynamic of the industry has changed. So while on many routes a 787/350 could be a good choice it might be that a 739/321 (etc.) might be a better result for other flights currently operated by a 767. |
Quoting sunrisevalley (Reply 4): First, on a equal payload basis the 788 becomes more fuel efficient than the 767-300ER at sectors greater than about 1000nm. The second part of your hypothesis is nothing but conjecture. Airlines are continuing to order the type . If they believed this why aren't they ordering 332's and 359's by the hundreds? |
Quoting SonomaFlyer (Reply 3): For routes at six hours and under, the 321 or 739 works. For routes over six hours, the 788 will be the cheapest CASM for airlines given its light weight. |
Quoting planiac787 (Reply 6): I dont see an increase in the 787 order after the problems have started and only time will tell what other problem and hurdles the program has to face....With so much speculation do you think airlines will risk there money...? |
Quoting planiac787 (Reply 6): Yes but what if those are high density routes...why would airlines sacrifice on seats...Lets say a JFK-LAX...Some carriers operate wide bodies on these routes...A321 and 739 cant make them money and I dont see the point of operating 2 aircrafts on the same route at the same time..That wouldnt make sense.. |
Quoting pvjin (Reply 7): Then just put a 787 or A330 on those routes. Just because 787 can do long haul doesn't mean it couldn't be used on these routes too. |
Quoting planiac787 (Reply 8): True but what about the airlines who dont have neither or rather dont have neither to spare on those routes...Currently 767 are doing those and if 787 are not ready on time then why should airlines keep sustaining losses....Isnt boeing in real trouble here? |
Quoting Stitch (Reply 11): So the ideal replacement for the 767, per the customers who order and fly them, is the 787. |
Quoting planiac787 (Thread starter): And with the 767 still in production, do carriers order more of them? |
Quoting bmacleod (Reply 13): 788 is only 767 replacement option I can think of. The 739 will work on shorter/continental routes but that's about it... |
Quoting BD338 (Reply 2): 739/321 (etc.) might be a better result for other flights currently operated by a 767. |
Quoting rg787 (Reply 15): Quoting BD338 (Reply 2): 739/321 (etc.) might be a better result for other flights currently operated by a 767. No matter how many times you guys tell me the future of the 757 and now the 767 will be 739/A321. This doesn't make any sense, the 767 is just a lot bigger than the 739/a321 and a lot more capable and even if you put more frequency, this is going against the world. The biggest airports are already crowded and slot managed, putting thousands of frequency on them because you don't have anything between the 737/a320 series and the 787/a330/a350 just doesn't make any sense. |
Quoting ADent (Reply 12): Quoting Stitch (Reply 11): So the ideal replacement for the 767, per the customers who order and fly them, is the 787. I don't think so. AA is replacing theirs with A321. UA replaced their trans-cons 767s years ago with 757-200s. 737-900ERs are the new replacement. HA is buying A321NEOs and phasing out 767-300s. Maybe the 787 is an 'ideal' replacement for a 767-300ER used in intercontinental service, but it is not the ideal replacement for all cases. |
Quoting SonomaFlyer (Reply 10): Airlines go for frequency over a/c size. Once the 321s arrive, AA's 762 go away and that will end the wide body use on domestic flights except for the occasional substitution or re positioning. |
Quoting ADent (Reply 12): I don't think so. AA is replacing theirs with A321. UA replaced their trans-cons 767s years ago with |
Quoting SonomaFlyer (Reply 3): For routes at six hours and under, the 321 or 739 works. |
Quoting planiac787 (Reply 5): As I said some 767's are over 25 years old and will be retired soon... |
Quoting rg787 (Reply 15): the 767 is just a lot bigger than the 739/a321 and a lot more capable |
Quoting ADent (Reply 12): I don't think so. AA is replacing theirs with A321. UA replaced their trans-cons 767s years ago with 757-200s. 737-900ERs are the new replacement. |
Quoting ADent (Reply 12): HA is buying A321NEOs and phasing out 767-300s. |
Quoting planiac787 (Reply 8): True but what about the airlines who dont have neither or rather dont have neither to spare on those routes...Currently 767 are doing those |
Quoting rg787 (Reply 15): No matter how many times you guys tell me the future of the 757 and now the 767 will be 739/A321. This doesn't make any sense, the 767 is just a lot bigger than the 739/a321 and a lot more capable and even if you put more frequency, this is going against the world. |
