mia305
What Airports Have Short Runways With Widebodies?
Wed Apr 24, 2013 1:24 am
What airports have short runways with widebody takeoffs and landings?
I know that LGA has 2 runways that are about 7000 feet and have 767s land and takeoff
I know in the 70s they had DC10s and I believe L1011s. When those planes land and
takeoff are they weight resticted because with a 7000 foot runway that would be
cutting it close.
Are there any other airports with short runways that have widebodies that land and takeoff?
****Sorry about the question it wouldn't fit so I had to repost it****
PITrules
RE: What Airports Have Short Runways With Widebodies?
Wed Apr 24, 2013 1:27 am
BUR, SNA, ROA courtesy of the integrators.
FLYi
timz
Wed Apr 24, 2013 1:34 am
Quoting mia305 (Thread starter):
They can't take off at MTOW, but they can take full pax on shortish trips-- LGA-ORD, probably LGA-DFW.
Tougher was KOA-SFO when its runway was 6500 ft. OGG is still 7000 ft and 767s were scheduled nonstop as far as ATL.
The A300s out of STT (5350?-ft runway) all? just flew to STX.
MesaFlyGuy
Wed Apr 24, 2013 1:42 am
PVD gets most of the sports charters, especially the UA 767s for the Jets and the DL 767s for the Pats. The longest runway is ~7300 feet.
Also, have you ever seen the Dreamlifters using 3/21 at CHS? What a sight! These are widebodies, albeit not scheduled passenger service
The views I express are my own and do not reflect the views and opinions of my company.
Viscount724
Wed Apr 24, 2013 1:48 am
Quoting timz (Reply 2):
And remember LGA has a perimeter rule that restricts nonstops to 1500 miles (except DEN which is 1620 mi., and except on Saturday). Widebodies wouldn't be anywhere close to MTOW on such short sectors.
Wardair operated widebodies, including 747s and DC-10s from Victoria (YYJ) to HNL, 2676 miles. Here's one departing for HNL from YYJ's longest 7,000 ft. runway, coincidentally the same length as LGA's runways.
http://www.youtube.com/watch?v=tbxii9qLNjg
hoons90
Dzaoudzi Airport (DZA) in Mayotte gets an Air Austral 777-200LR three times a week from RUN. The runway is 6,330ft long.
Flown: 2L 7C 9E 9L AA AB AC AF AY AZ BA BR BX B6 CA CO CP CX DL EK EY JL KE KL LA LH LX MQ NW OZ PD RW SQ TG TP TR TS US WG WN WS XE XJ
rduoodl
Wed Apr 24, 2013 3:31 am
Two years ago Duke Men's Basketball took a DL 763ER OGG-RDU Nonstop. Pretty heavy bird for 7000ft.
Previous: RDU-DTW-LAS-LAX-SYD Up Next: RDU-ATL-MEX
rfields5421
Wed Apr 24, 2013 3:36 am
Not quite that short - but the 7,700 ft runway at SXM sees a lot of wide body aircraft
Not all who wander are lost.
AR385
cutting it close.
Really? Interesting. I thought a major consideration in thier design was ops at LGA
NRT´s second runway is short and widebodies use it
AEP used to receive AR´s A310s every so often
MGA received IB´s 747s during the 70s I believe, although could have been charters.
treebeard787
Wed Apr 24, 2013 3:54 am
FX has sent A310s to SNA before and currently uses an A300 from MEM, pretty cool seeing a jet that size use the 5700ft runway.
Allons-y!
goboeing
Wed Apr 24, 2013 4:59 am
Narita!
"This message was too short"
DCA-ROCguy
Wed Apr 24, 2013 5:02 am
One time I saw a (presumably empty) FedEx A310 blast off of ROC's 10-28, which at that time (about 2004-2005) was 5,500.' Widebody ops at ROC, now mostly FedEx MD-10's, typically use 8,000' 4-22.
Jim
Need a new airline paint scheme? Better call Saul! (Bass that is)
spacecadet
Wed Apr 24, 2013 5:24 am
Quoting AR385 (Reply 8):
Mainly for landings, though. I'm not an expert on ops there so I don't know if this is done 100% of the time, but 0 of my 16 takeoffs from there have been on the short runway and 15 of my 15 landings have been.
Of course, it's kinda fun when ATC in FSX directs me to take off in a 747 from that runway   But I've never experienced it in real life.
AR385
Wed Apr 24, 2013 5:32 am
Quoting spacecadet (Reply 12):
It´s not usually, but I do know from a pilot friend of mind that he has taken off from that runway on AM´s 777 NRT-TIJ back when they stopped in TIJ on the return.
EZEIZA
Wed Apr 24, 2013 2:55 pm
CGH used to have 767's several years ago. AEP as mentioned above had A310's, but only when diverted from EZE, never as scheduled flights. AEP also used to have PU's 757 (not sure if considered a widebody).
Carp aunque ganes o pierdas ...
United_fan
Wed Apr 24, 2013 3:40 pm
Quoting DCA-ROCguy (Reply 11):
Jim
This past Saturday,when it was windy, a FX A300 landed -28. The tower once asked the MD10 if they could accept 28,and they said 'no way'.
"Suspicion is a matter of opinion"
timz
Wed Apr 24, 2013 3:49 pm
Could be-- but no one was designing for MTOW takeoffs there.
lhcvg
Wed Apr 24, 2013 3:51 pm
It was, but the consideration is what was mentioned above -- using them on high-density trunk routes out of congested airports to your hubs (or large O&D destinations like FL) within a reasonable distance.
Think of it like the 757: it has incredible performance for the likes of SNA, but you can also (if it's an ER) fly a TATL flight with the same plane. Both of those usage scenarios were baked into the design because they aren't necessarily mutually exclusive.
StarAC17
Wed Apr 24, 2013 4:41 pm
Quoting rduoodl (Reply 6):
Well if it just has the team and support staff its not really that heavy. On Wikipedia it says that a 763 at MTOW only needs about 8300 ft to get off the ground.
You can change the runway  .
Also regarding shorter runways that wide-bodies use.
I have taken off in a 777 that used 9/27 at MEL (7500 ft) which was bound for AKL, also I reckon 16L/34R at SYD handles widebodies from time to time.
in Feb 2011 when the earthquake hit CHC, NZ operated 777's out of WLG.
Engineers Rule The World!!!!!
airbazar
Wed Apr 24, 2013 5:05 pm
I'm not sure I'd call a 7,000ft runway short. BOS's runway 9/27 is 7,000ft and it sees WB ops including TATL flights.
http://www.youtube.com/watch?v=0yCvfStcK5c
http://www.youtube.com/watch?v=jd-RE-hjkYA
highflier92660
Wed Apr 24, 2013 5:06 pm
Let's see...weight times arm equals moment...and how many thousand pounds of fuel did we load?
http://www.youtube.comwtch?v=_V7siBUbp4M
Princess Juliana in St. Maarten; everybody's favorite short wide-body runway in the Caribbean. Here a Corsair 747-400 uses every bit of the 7,054 foot runway and threatens to go into the 492 foot overrun. The airport enthusiasts at the adjacent beach bar restaurants are no-doubt in their glory.
roseflyer
Wed Apr 24, 2013 5:37 pm
UA's 777s into OGG's 6995' runway are always interesting. Too bad it is down to mostly 753s. The 777s couldn't make it back to ORD nonstop.
Phen
Wed Apr 24, 2013 5:43 pm
I've seen EI's A333s take off from DUB's shorter 16/34 which is 6,800ft.
flyingfool
Wed Apr 24, 2013 5:52 pm
There are a lot of British Airports with a short runway handling loads widebody's to further away destinations.
modesto2
Wed Apr 24, 2013 5:53 pm
EWR rwy 11-29 is 6,800' and operates with widebodies. I'll never forget riding in a CO 777 from PEK to EWR and doing the ILS 22L circle to 29 in strong winds. Crazy and awesome.
by738
Wed Apr 24, 2013 6:02 pm
Quoting flyingfool (Reply 23):
There are ? Guess it depends on your definition of short runway. GLA BHX and NCL would really be the only ones regularly handling long haul widebodies and they are all over 7000ft.
cannon750
Wed Apr 24, 2013 6:16 pm
Also in Hawaii, Lihue Airport (LIH) on Kauai has even shorter runways (6500 ft.) than OGG and in the summer United runs a 767 all the way to Denver on some days. Likely all gasoline and passengers with little cargo other than the luggage!
AAIL86
Wed Apr 24, 2013 6:34 pm
Quoting cannon750 (Reply 26):
Was it a 767 in the past? I see a weekly 752 in the GDS ...
SA 06JUL LIH / DEN + 4:00 HR
UA 581 F9 A9 Z9 P9 Y9 B9 M9 E9 U9 H9+LIHDEN 810P 653A+752
It doesn't appear DL operate ATL-OGG anymore - but AA operate DFW-OGG daily on a 763 ....
" Travel is fatal to prejudice, bigotry, and narrow-mindedness ... Broad, wholesome, charitable views of men and things cannot be acquired by vegetating in one little corner of the earth all one's lifetime. ” - Mark Twain, 1869
Beechtobus
Wed Apr 24, 2013 6:41 pm
While FLL's main runway, 9L-27R is 9000', it closes for mx or otherwise time to time as it did for several weeks a couple summers ago and 13-31 at 6900' is the only other choice. Pretty cool watching Fedexs MD-11s and DC-10s, Air Transats and Fedexs A300s and 310s, Condors and Deltas 767 use that.
vfw614
Wed Apr 24, 2013 6:43 pm
Quoting by738 (Reply 25):
LTN at 7.087ft. It had more WBs in the past, however. Think of Court Line TriStars, BY 767s or ZBs AB6.
olddominion727
Wed Apr 24, 2013 6:47 pm
Why can't UA 772 make it OGG-ORD, AA flew their 763 from OGG-DFW and ORD. TW flew their 763 OGG-STL
roseflyer
Wed Apr 24, 2013 7:02 pm
Quoting olddominion727 (Reply 30):
UA's 777-200s operating to Hawaii are baseline 777-200s (not ERs). With a 7,000 ft runway, depending on temperature, they are weight restricted by about 25,000 - 35,000 lbs. UA's 772s in the Hawaii configuration have 348 seats, which is a relatively heavy load excluding any cargo for a 777-200. The airplane has a range of about 2,600 nautical miles off of OGG with a full load of passengers. That's enough for OGG-SFO on the 777, but OGG-ORD is 3,600 nautical miles, so that means that they would have to block seats in exchange for fuel. Blocking seats would kill the economics of OGG-ORD since the route is depending on a high quantity of passengers since there are few high yielding premium class fares on that route.
The 777-200ER would be able to make ORD without limiting passengers. The 767-300ER doesn't have the same payload/range curve as the 777 and can typically operate out of shorter runways than a 777-200 economically.
slcdeltarumd11
Wed Apr 24, 2013 7:11 pm
Just so funny to read in 2013.........
EZYAirbus
Wed Apr 24, 2013 7:21 pm
Quoting vfw614 (Reply 29):
Also El Al 767/777 operate daily, MNG Cargo A300s, DHL A300s
Remember the BA 747-400 divert a few years back too!
http://www.glenneldridgeaviation.com
virginson937
Wed Apr 24, 2013 7:34 pm
BRS at some points of the year can have a Thomson/First Choice 767 operating charter flights to SFB.
The runway length is 6,598 feet.
Will
konrad
EPKK Kraków is 8300 ft and used to have 763 service to KORD. It was a 10 hour flight, with weight restrictions most of the time.
Rdh3e
Wed Apr 24, 2013 7:49 pm
Quoting Roseflyer (Reply 31):
Hence the ORD-OGG-KOA-ORD routing of the flight.
Boeing744
Wed Apr 24, 2013 8:02 pm
Quoting Viscount724 (Reply 4):
Great video! Thanks for posting.
My first flight ever was on a Wardair 747 (not sure if -100 or -200) from YYJ to Honolulu, just like that! I was about 9 months old. I wonder if this was even the same flight, as I assume they did not do this very often. According to my parents, though, shortly after take-off they were forced to land in YVR due to gear issues. The flight continued on to HNL after that though.
BoeingGuy
Wed Apr 24, 2013 8:21 pm
Quoting mesaflyguy (Reply 3):
Same with Boeing wide-bodies taking off from PAE and BFI and PDX (were some go for painting). Boeing test, ferry and customer flights are relatively light weight and they use un-derated takeoff thrust.
You should see the 777-200LR and 777-300ER go. One pilot time it and said the 777-300ER was airborne in 17 seconds after break release. That's what 115,000lb engines can do with a light airplane and no takeoff derates.
Viscount724
Wed Apr 24, 2013 8:30 pm
Quoting EZEIZA (Reply 14):
Also A300s. I landed at CGH on a Varig A300 once in the mid-1980s. The flight operated EZE-CGH-GIG.
prchan
Wed Apr 24, 2013 8:41 pm
TR operated 767s in CGH and VP operated A300s. I believe last regular flights were flown late 90s.
https://www.airliners.net/photo/VASP/...d=1fc1752edfaaf2e20f894b21f7f98801
Motorhussy
Wed Apr 24, 2013 9:00 pm
WLG is 2,081 metres or 6,827 feet long.
Photo © Bob Leask
Photo © Hugh M
come visit the south pacific
71Zulu
Wed Apr 24, 2013 9:14 pm
This is the Duke DL 763 charter, it was pretty light but still quite a long flight.
http://flightaware.com/live/flight/D...8/history/20111125/0200Z/PHOG/KRDU
Phen
Wed Apr 24, 2013 9:26 pm
Quoting BoeingGuy (Reply 38):
See here http://www.youtube.com/watch?list=FL...dI&feature=player_detailpage#t=70s
Amazing.
cannon750
Wed Apr 24, 2013 11:26 pm
Quoting AAIL86 (Reply 27):
I've seen the 767 evening departure the last few years we've been there in the summer, but perhaps the demand isn't there this year--it definitely used almost all 6500 ft for take-off though, and like in Orange County the pilot rev'd those engines up pretty high before releasing the break...
STT757
Wed Apr 24, 2013 11:37 pm
EWR's runway 11/29 at 6,800ft, seen 747s, A340s, 777s etc. using that crosswind runway plenty of times.
Airplanebrain
Wed Apr 24, 2013 11:54 pm
The old Austin Mueller airport had a 7,200 ft runway and AA did fly a DC-10 there occasionally with weight restrictions. That is no longer a problem with the B-52 runway at the new Bergstron airport.
timz
Why?
Quoting STT757 (Reply 45):
Landing-- but never taking off?
STT757
Thu Apr 25, 2013 12:05 am
Quoting timz (Reply 47):
The biggest aircraft I've personally ever seen taking off would be MD-80s, 737s. Has it happened though I do not know.
kgaiflyer
Thu Apr 25, 2013 12:47 am
Slightly off topic, YLW's runway is 8900 ft and receives (four engine) An-124's
http://www.youtube.com/watch?v=gVNcJ0XBtso
[Edited 2013-04-24 17:49:50]
