Quoting falkerker (Reply 1): on a more serious note (is it?), yet another nail in the coffin for the 747-8 |
Quoting kaitak (Reply 2): I'm not sure I'd put it quite so strongly; certainly, things aren't looking well for the 747-8F, but as was pointed out on another forum, most of the current line of freighters - A332F, 772LRF and 74N - have been experiencing a sales drought recently. |
Quoting falkerker (Reply 1): yet another nail in the coffin for the 747-8 |
Quoting rotating14 (Reply 6): This cancellation is not really the 748's fault. I f they could afford it they would buy it but because of the Real Estate bussiness they so heavily depended on went south, so did other investments predicated on the RE aspirations. |
Quoting francoflier (Reply 10): The is nothing out there that can replace the 744F, and there are a lot of those still around which will need replacing eventually. Event accounting for a contraction in overall air freight, a large chunk of that fleet will be replaced by 748s. |
Quoting francoflier (Reply 10): The 748F will keep picking up orders for some years to come. |
Quoting JoeCanuck (Reply 8): With the huge investment in the 748 |
Quoting Ronaldo747 (Reply 3): Why? The 747-8F still stands on its own without competitor but struggles because of the weak cargo market. With better times ahead the 8F will get new orders. But I suspect it will take another two, three years before the cargo business is picking up again. |
Quoting JHwk (Reply 7): It's nearly 10% of the 747 backlog, or 3 months production. I would think it would force Boeing to drop from 1.75/month to 1.5/month to try and buy time if nothing changes soon. |
Quoting boeingguy26 (Reply 9): with DLH operating the 748i, I wonder what the actual numbers are in regards to operation; better, worse or at the specs that Boeing stated? |
Quoting francoflier (Reply 10): The is nothing out there that can replace the 744F, |
Quoting JoeCanuck (Reply 8): My guess it will last until around 2020. |
Quoting frigatebird (Reply 12): It will IMO last longer: at least until a 777-8F would be in service, I don't expect this to happen in another 10 years. |
Quoting frigatebird (Reply 12): It will IMO last longer: at least until a 777-8F would be in service, |
Quoting Asiaflyer (Reply 15): What is stupid with that? Airbus builds planes that kills 772 and 747, so what shall Boeing do? Sit and watch? |
Quoting Ronaldo747 (Reply 14): the 777-8F might replace the 744BCF/BSDF but payload-wise it cannot replace the 747-8F. |
Quoting KarelXWB (Reply 11): Competition or not, if Boeing cannot keep the line open it's game over. But we're not there yet. I suppose Boeing can keep the line open even at a rate of 0.5 frames per month. |
Quoting francoflier (Reply 10): The is nothing out there that can replace the 744F |
Quoting na (Reply 13): In a few years sales will rise again, the market will grow and many old freighters gone means new planes. |
Quoting na (Reply 16): So Boeing only reacts? I still dont really get what they are doing. Why didnt they develop the 77E further instead of spending 10 billion+ on a new plane then when they needed to replace the old 767 in the first place? Soon Airbus builds a 77W killer. And here suddenly Boeing doesnt build an all-new plane where it would make more sense (as an all-new 777/747 successor could beat A350 AND A380). |
Quoting Revelation (Reply 20): The main reason we have all new A350 and B787 is the manufacturers wanted to change the fuselage width. |
Quoting na (Reply 13): 2025 perhaps. I doubt Boeing is eager to build a plane that is a serious threat to its flagship. |
Quoting frigatebird (Reply 17): Probably not, but a 777-8F could so much more efficient it may very well offset a bit less payload |
Quoting JHwk (Reply 7): It seems like the 747 basically needs to be priced to match the 777 to have a life left, and I doubt that would be profitable. I fear the Queen's day's are numbered. |
Quoting Danny (Reply 18): They'll shut it once new, larger variants of 777 become avaliable. |
Quoting WesternA318 (Reply 25): The 747-8 has no coffin for it |
Quoting PanAm1971 (Reply 24): Listen to all this panic. The 747-8F will be just fine. There really isn't a true competitor for it. |
Quoting falkerker (Reply 28): The 747-8I does, and when the entire market of a frame depends almost entirely on the freight market, it will eventually be shut down. As many have stated, the 777-8F will steer freight companies away from the 747-8 |
Quoting WesternA318 (Reply 30): Would the proposed 777-8F have the same payload capability of the 7478? |
Quoting frigatebird (Reply 17): Probably not, but a 777-8F could so much more efficient it may very well offset a bit less payload... Like the 77W vs the 748i. Difference in payload would be bigger in the 778F - 748F case, but also the difference in efficiency would be (much!) bigger. |
Quoting FlyingAY (Reply 19): What is it that the 744F or even 748F can do that the 77F cannot? |
Quoting babybus (Reply 26): the 'new' 747 was a mockery |
Quoting rampbro (Reply 32): The on-board experience is different, the plane is longer and sleeker, the wing is entirely different, the engines are different. |
Quoting babybus (Reply 26): the 'new' 747 was a mockery and even its own marketing blurb never made convincing reading. |
Quoting boeingguy26 (Reply 34): if it aint Boeing I aint going |
Quoting falkerker (Reply 33): It didn´t bring anything new to what matters most, fuel efficiency and comfort. |
Quoting Stitch (Reply 37): I'd love to know what the trip cost differences are between the 777-300ER and 747-8 Intercontinental for an airline like KE that will operate both. That is likely going to determine whether or not the 747-8 Intercontinental has any real future. |
Quoting JoeCanuck (Reply 36): It seemed to me to be too big of a job for too little gain. |
Quoting Revelation (Reply 42): And add to that two more years and millions more dollars than you intended to spend on it and you're in real hot water... |
Quoting JoeCanuck (Reply 38): Very good point...KE and LH are well aware of the advantages and disadvantages of every aircraft type and they wouldn't have bought the 748i if there was no advantage to do so. |
Quoting boeingguy26 (Reply 40): Where/When will this data be available? |
Quoting KarelXWB (Reply 11): Let's hope so. |
Quoting frigatebird (Reply 12): There will still be a market for a large freighter. |
Quoting PM (Reply 44): And now they are all cancelled. |
Quoting KarelXWB (Reply 45): But LH is not operating the 77W so the 747 fits perfectly in between the A346 and the A380's despite of those "disadvantages". KE on the other hand does operate to the 77W. |
Quoting PM (Reply 44): On 31st December 2007 DAE ordered... 15 x 787-8 10 x 777-300ER 5 x 747-8F And now they are all cancelled. |
Quoting EPA001 (Reply 46): I agree, but currently the cargo market is weak. |
