Quoting crj900lr (Reply 99): |
I guess you are not a GA at a international station then. It happens often.
LAXLocal
Quoting crj900lr (Reply 99): Only in extreme situations will boarding continue under the 10 min mark. |
Quoting LAXLocal (Reply 100): It happens often. |
Quoting cmf (Reply 92): No, they failed to deliver what they sold |
Quoting sankaps (Reply 97): Adding salt to the wound is the fact the connection left early (regardless of whether the pax would have made it or not) |
Quoting capitalflyer (Reply 95): Screw the numbers. They would reap ten fold for a little courtesy from time to time. This is why airline travel sucks |
Quoting gatorman96 (Reply 94): If this same scenario happened to me, or anybody else in this thread, no one would care! Shit happens, and if you fly enough, it will happen to you and most likely already has, many times. And we all continue to fly, in most cases the same airline that "screwed us over." This is not a big deal. |
Quoting sankaps (Reply 97): I once had a situation where I was connecting with my family from a much delayed inbound CO flight on a separate ticket, to the SQ EWR-SIN non-stop. I literally had 10 minutes to go when I reached the check-in counter. The SQ staff had the BPs ready (I had called them from the CO flight), grabbed our bags. and two staff grabbed my two kids (2 and 4) and *ran with them* with us following to security, and got us on the aircraft with maybe a minute to spare. The aircraft door literally slammed shut behind us. They could have easily followed SOP, but they went above and beyond. THAT is what creates loyal customers! |
Quoting gatorman96 (Reply 94): For those of you who are actually in the airline industry, please correct me if I am wrong, but passengers miss connections everyday for various reasons. I |
Quoting sankaps (Reply 97): Adding salt to the wound is the fact the connection left early (regardless of whether the pax would have made it or not). The pax is upset. Empathize, airline people, they pay YOUR salary. |
Quoting cmf (Reply 75): Speaking generally, that is horse hockey. You do not provide good customer service by scheduling so tight that you incur delays with high frequency and don't have buffers to handle it. You certainly do not run lean that way. |
Quoting cmf (Reply 75): It never stops to amaze me how people think that well established business practices do not apply to airlines. |
Quoting cmf (Reply 78): At the very minimum they failed to communicate properly with their customers. |
Quoting capitalflyer (Reply 81): 1. Anyone who can't wait 10 minutes for some folks who are late because their previous flight was late is a jerk. 10 minutes is not that big a deal and can be made up in the air often. If you book your next connection so tight that 10 minutes breaks you, then that's your own dumb fault. If the late people are just late overall not because of a previous flight delay, then leave them behind. |
Quoting capitalflyer (Reply 81): 3. US Airways, look at you passenger manifest. If it reads Rainn Wilson, Jenna Fischer, etc. and the flight is going to Scranton, you should probably hold the flight. Idiots bought themselves a butt load of bad press which could have been easily avoided. |
Quoting sankaps (Reply 89): Sold them a connecting flight, but a delay to their own incoming flight caused them to miss their connection. So it is not like they did everything correct, even if you believe that the Scranton flight pushing 4 minutes early is not an issue. |
Quoting sankaps (Reply 89): Perhaps it is this dogmatism that needs to change. Perhaps 10 min gate close should be a guideline, especially for Dash flights where it evidently can take as little as 6 minutes from gate close to push back? |
Quoting sankaps (Reply 89): Again, perhaps this suggests some common sense needs to be used, and the 10 min rule not be applied dogmatically and blindly. |
Quoting capitalflyer (Reply 95): Screw the numbers. |
Quoting capitalflyer (Reply 95): They would reap ten fold for a little courtesy from time to time. |
Quoting usflyer msp (Reply 103): That is nice but I highly doubt SQ would have gone through all that trouble if there was another flight they could have put you on 3 hours later. |
Quoting usflyer msp (Reply 103): When a flight only operates 1x daily or less there is alot more incentive to hold flights for connecting pax... |
Quoting FlyASAGuy2005 (Reply 106): Happens every single day on almost every flight with every airline. Not making excuses. It is what it is. Are you suppose to hold every single departure for miss connections? |
Quoting FlyASAGuy2005 (Reply 106): Are you missing something? Because of this one example, it means US (or any other domestic US airline for that matter) never holds flights for passengers? It happens every single day. Trust me. |
Quoting LV (Reply 74): |
Quoting RyanairGuru (Reply 102): I'm sorry, but they delivered everything that they were contractually required to. |
Quoting RyanairGuru (Reply 102): These 7 passengers almost certainly could not have made it to the flight. Maybe Piedmont could have closed the door at 5:34 and pushed back at 5:40, but they most likely would still not have been on the aircraft. |
Quoting RyanairGuru (Reply 102): They're late into the hub, so you hold the flights for the connections.... and so on and so on |
Quoting RyanairGuru (Reply 102): That's what I was thinking. Today alone the same thing has probably happened with DL at MSP, UA at SFO and AA at ORD. |
Quoting FlyASAGuy2005 (Reply 106): Their flight departed late (out of LAX(...for all we know because of LATE CONNECTING or LOCAL PASSENGERS LOL. Oh the irony. Don't you see the domino effect already? |
Quoting FlyASAGuy2005 (Reply 106): Well established business practices are being used. |
Quoting FlyASAGuy2005 (Reply 106): If anything ,the fact that accountability is being drilled more than ever these days and sticking to what works |
Quoting FlyASAGuy2005 (Reply 106): AT ITS BEST SINCE REPORTING STARTED |
Quoting FlyASAGuy2005 (Reply 106): And I assure you that there are plenty of things for passengers to complain about. |
Quoting FlyASAGuy2005 (Reply 106): How so specifically. I don't follow. |
Quoting FlyASAGuy2005 (Reply 106): Happens every single day on almost every flight with every airline. Not making excuses. It is what it is |
Quoting sankaps (Reply 107): I am not missing anything. I am making the same point you are that the 10 minute rule is not cast in stone, in response to all those who are saying "10 min gate close is mandatory, tough luck if you don't like it or are too dumb to understand it". |
Quoting cmf (Reply 109): Spot on. The randomness in how things are applied is a major part of the problem. |
Quoting cmf (Reply 109): They failed to deliver the itinerary they sold |
Quoting cmf (Reply 109): So that makes is all right then |
Quoting RyanairGuru (Reply 111): No, they delivered the itinerary as contracted: they were ready, willing, and able to transport the customer from LAX to AVP. |
Quoting RyanairGuru (Reply 111): If you read the contract of carriage |
Quoting RyanairGuru (Reply 111): If you read the contract of carriage, you will see that US (nor, indeed, UA, AA, DL, BA, EK, SQ, CX etc etc) does not guarantee to carry you on the flight you booked if, for operational reasons etc. that is impossible to do. Whether or not the passenger wanted to be on that flight is not actually relevant to any discussion of whether US 'failed to deliver' Quoting cmf (Reply 109): So that makes is all right then That wasn't my point. I was getting at this happens every single day, and we don't have a thread with 110 posts on it on ANet. |
Quoting gatorman96 (Reply 110): I guarantee you this was not random. |
Quoting gatorman96 (Reply 110): it's better to just let it go and get on the next flight and arrive a little late. |
Quoting RyanairGuru (Reply 111): US had every intention of carrying the customer on the exact flights booked |
Quoting RyanairGuru (Reply 111): Whether or not the passenger wanted to be on that flight is not actually relevant to any discussion of whether US 'failed to deliver' |
Quoting RyanairGuru (Reply 111): That wasn't my point. I was getting at this happens every single day, and we don't have a thread with 110 posts on it on ANet. |
Quoting sankaps (Reply 112): Again, no wonder sometimes passengers are driven to lawyers, since otherwise everything would be excused and justified by pointing to the fine print. |
Quoting AAIL86 (Reply 114): Also, it does seem that some of us are forgetting what a departure time actually is here - a plane is supposed pushing back from the gate at that time and therefore the boarding door must be closed several minutes before departure |
Quoting Maverick623 (Reply 11): |
Quoting sankaps (Reply 15): |
Quoting cmf (Reply 115): So you speak with every gate agent... It is random because the affected passengers don't know what is happening. It comes back to communication, again. |
Quoting sankaps (Reply 107): Sure, but would US or UA or other legacy US carriers have gone through this trouble? They would more than likely just have just said "tough luck, your incoming flight was on a separate ticket, not our problem you missed this flight, now you have to buy a new ticket if you want to get to your destination since you were a no-show on the flight you were booked on". |
Quoting cmf (Reply 109): hat sounds great but it really isn't important. Certainly doesn't warrant the use of capitals. What is important is the actual numbers. Not if people report or not. |
Quoting cmf (Reply 109): sn't that telling. A person stating he is on the inside of the airlines and don't understand the communication problem. Simply put. With proper communication customers will accept just about any mistake you make. You certainly will not have them complain about them missing a flight because you sent it out early. Instead you will have them state they missed their connection because of late arrival and will soon continue to destination. It is not uncommon that a customer experience a failure of some kind become the most vocal ambassadors because of how you deal with them in that situation. Customers for whom everything goes right tend to just expect it. |
Quoting cmf (Reply 109): Sorry, but making excuses is what you do when you defend a system that generate this kind of problems with very high frequency and let it go with - it is what it is. |
Quoting mesaflyguy (Reply 116): I am not perfect, but I have little respect for people who either twist the story or fight with facts that are incorrect. US doesn't operate 20 seats but I guess a 37-seater with 7 missing isn't as dramatic as a 20 seater missing 7 people. |
Quoting FlyASAGuy2005 (Reply 119): Why wouldn't they? I've seen an agent at RDU escort a family of 4 through security to get to their gate to catch their flight to Atlanta that was scheduled to depart in 20 minutes with the TSA line being a mile long |
Quoting sankaps (Reply 120): You're right, it isn't. It is only as dramatic as 75 pax being left behind on a 777 or 747 with 400 seats. |
Quoting FlyASAGuy2005 (Reply 119): Okay. So airplanes don't break down. It never rains. It never snows. There's never ATC delays. There's never long take-off lines. Catering is on and off the a/c when they should 100% of the time. An a/c is NEVER overfueled. An a/c is NEVER underfueled. There's NEVER a disruptive pax that needs to be removed. Crews are NEVER late. So that I understand what you're saying. Where you work, everythin goes right 100% of the time, right? When a flight departs late, it is always the airline's fault, right. It can never be an outside factor completely out of their control, right. Take it one step further. Earlier, you tried to say that because of the way schedules are built and a/c are routed, there's no room for hick-ups such as these thuse people miss their flights. Well, i'm sure you'd much prefer a/c running 3 legs a day vs 6. That way, you're frequencies system-wide will drop significantly. Let's also raise fairs because there will be much less capacity (seats) out in the market. Maybe then, we'll see better operations. Oh, i'm sorry, all of the above that I stated will happen anyway. |
Quoting wn676 (Reply 122): Right, just like 500 people not making a plane with 2700 seats is equally as dramatic. Please. 75 people is a lot worse than 7, regardless of whatever ratio that works out to be. |
Quoting gatorman96 (Reply 117): How does that make it random? |
Quoting gatorman96 (Reply 117): ? We are talking about a multi-billion dollar corporation, where profit margins are slim and in a lot of cases, none. Every move is calculated and scrutinized. |
Quoting gatorman96 (Reply 117): but i think we can both agree that this event wasn't the first and won't be the last. |
Quoting gatorman96 (Reply 117): One thing I can guarantee, if Rainn spoke to the gate agents in the same fashion he took to Twitter, I hope US tells him to please find another airline. What a terrible way to handle a situation and look like a massive Dbag at the same time.. |
Quoting 802flyguy (Reply 118): But the system does work pretty well most of the time |
Quoting FlyASAGuy2005 (Reply 119): Why is it not important?? |
Quoting FlyASAGuy2005 (Reply 119): Seems to me like you know how the conversation went. |
Quoting FlyASAGuy2005 (Reply 119): customers will accept about any mistake makes me thing you do not work in a customer facing job |
Quoting FlyASAGuy2005 (Reply 119): And if you do, please tell me where you work because i'd love to have your customers |
Quoting FlyASAGuy2005 (Reply 119): I still can't believe what you said. |
Quoting FlyASAGuy2005 (Reply 119): Okay. So airplanes don't break down. It never rains. It never snows. There's never ATC delays. There's never long take-off lines. Catering is on and off the a/c when they should 100% of the time. An a/c is NEVER overfueled. An a/c is NEVER underfueled. There's NEVER a disruptive pax that needs to be removed. Crews are NEVER late. So that I understand what you're saying. Where you work, everythin goes right 100% of the time, right? When a flight departs late, it is always the airline's fault, right. It can never be an outside factor completely out of their control, right. |
Quoting FlyASAGuy2005 (Reply 119): Take it one step further. Earlier, you tried to say that because of the way schedules are built and a/c are routed, there's no room for hick-ups such as these thuse people miss their flights. Well, i'm sure you'd much prefer a/c running 3 legs a day vs 6. That way, you're frequencies system-wide will drop significantly. Let's also raise fairs because there will be much less capacity (seats) out in the market. Maybe then, we'll see better operations. Oh, i'm sorry, all of the above that I stated will happen anyway. |
Quoting FlyASAGuy2005 (Reply 119): No, they pulled an a/c out the hanger, flew it down empty to RSW and got the remaining folks that were not accommodated on the other flights to MSP. Doesn't stop there. They boarded 122 meals (total pax count after some were rebooked) on the ferry flight so that these people can enjoy a first class meal on their way to MSP. The pundits will claim that they needed to get an a/c to MSP for following flights so that's the only reason. No...the one that went mech was a 757. They sent down an MD90. But good never happens and they're always out to screw their passengers. |
Quoting wn676 (Reply 122): ight, just like 500 people not making a plane with 2700 seats is equally as dramatic. Please. 75 people is a lot worse than 7, regardless of whatever ratio that works out to be. |
Quoting wn676 (Reply 123): This isn't some sort of manufacturing process that can be controlled and manipulated to very specific degrees. Sure, those same principles are applied like they are everywhere else (because after all, it is just a complex system), but the amount of variables that go into running an airline on a daily basis is staggering, which is why certain levels of performance are tolerated where in other industries they wouldn't be. |
Quoting cmf (Reply 126): You're wrong. |
Quoting cmf (Reply 126): To the airline, sure. To the affected customers it is the same thing. This is another great example of the mentality problem. |
Quoting FlyASAGuy2005 (Reply 127): Well you must have the absolute best customers. I've seen the best and worst. From young ladies being yelled at to agents being spat on and called all sorts of names...because they missed their flight. But by your logic they are deserving because they did not communicate properly. |
Quoting FlyASAGuy2005 (Reply 127): 'm glad you do not work for my airline. |
Quoting FlyASAGuy2005 (Reply 127): You still don't seem to get that you can never please everyone |
Quoting FlyASAGuy2005 (Reply 127): I don't know how that's so hard to understand. |
Quoting cmf (Reply 128): Without a doubt the airline is deserving for what they got. They should get it daily considering how regular things like this is. |
Quoting crj900lr (Reply 129): You obviously have issues with US and really have no idea how an airline runs. |
Quoting cmf (Reply 128): You still don't get it. Customers will respond to how you're deal with things. |
Quoting cmf (Reply 130): You're obviously an airline apologist who don't understand the words customer service. Considering how bankruptcy court is the only place US airlines arrive to with any kind of regularity it is obvious the industry and their apologists are the ones with no idea how to run a business. |
Quoting sankaps (Reply 125): Quite to the contrary, the ratio is exactly what matters! How much of the pax carrying mission that the aircraft is designated for, it is being able to fulfill. Leaving behind 25% of your pax doesn't seem to be a bright idea. |
Quoting cmf (Reply 126): 39% of flights delayed averaging more than 30 minutes delay. Just about every airline having been in bk, often multiple times. Not being able to communicate with customers and constantly referring to fine print and policies when things go wrong. Doing so poorly that politicians feel forced to vote for poor passenger protection laws just to be able to say they are doing something. We have different definitions of work pretty well. |
Quoting wn676 (Reply 132): Say you miss 3 people on a 37 seat plane and 20 on a 400 seat plane. Do you say you did a better job missing the 20 just because it's a lower percentage of the total seats on the plane? |
Quoting cmf (Reply 126): When customers have no idea what the outcome will be then it is random to the people paying the bills. |
Quoting cmf (Reply 126): That certainly isn't reality. |
Quoting cmf (Reply 126): Which is why airlines should figure out how to communicate properly. |
Quoting cmf (Reply 126): The affected passengers should have been informed already before they landed in PHL. |
Quoting sankaps (Reply 134): The thing is if you take the ratio into account and have a do-not-exceed number, the total number of pax needing re-accom will also decline, meaning a win-win. |
Quoting sankaps (Reply 134): Think about it. You call a taxi for 4 people, where each person pays an individual fare. The taxi driver insists on leaving early or on time with 1 person because the other three are held up a bit, saying "its only three people, not a big deal". Wouldn't be great for his business, would it? |
Quoting wn676 (Reply 136): there is another taxi following shortly with 3 open seats, then what is the best course of action in absolute terms? |
Quoting silentbob (Reply 131): That's not true at all and anyone that has to deal with the public knows that full well. There is always a subset that is petty, childish, self absorbed and abusive. |
Quoting 802flyguy (Reply 133): Not quite sure where you got those number (and DOT tracks sked to 15, not 30). Latest US on time numbers: |
Quoting Maverick623 (Reply 135): You can argue that perception matters more than reality, but you can't change reality. |
Quoting Maverick623 (Reply 135): I'm a little confused. In one sentence, you say that airlines are constantly in and out of bankruptcy, and in the next you say that the profit margins aren't "slim to none"? Which is it? |
Quoting Maverick623 (Reply 135): You know, I hear this a lot, and I always fail to see where there was a lack of communication. If you'd care to point it out, that would help in solving this argument. |
Quoting Maverick623 (Reply 135): Yep, because there just a whole boatload of time from the inrange call to landing for the crew to both receive a list of possible misconnects, and for the flight attendant(s) to go through and notify each and every passenger in danger of misconnecting that they may or may not make the flight. After all, there's nothing better for them to do than to tell 200 people things they already know. |
Quoting Maverick623 (Reply 135): those decisions are made by operations personnel who have way more information than most people think exists. |
Quoting rcair1 (Reply 140): Okay - lots of speculation (LOTS of speculation) - 139 posts. Really? |
Quoting cmf (Reply 128): |
Quoting rcair1 (Reply 140): So - - The plane seats 45, not 20. Strike 1 Mr. Office |
Quoting gatorman96 (Reply 141): Pretty amazing it's lasted this long, eh? There are a select few in this thread who don't want to accept that airlines actually do care about the customer and that more people are flying than ever, even though situations like this happen everyday! |
Quoting FlyASAGuy2005 (Reply 142): I gather that you were there and you know the agent didn't do and say exactly what you're suggesting. But your point is tha because he went on a childish tirade, he/she couldn't have because "if you communicate properly with customers" they'll understand. |
Quoting rcair1 (Reply 140): 4302 is a Dash 8 - it seats 9 rows of 5 - so 45 people, not 20. |
Quoting rcair1 (Reply 140): - The plane seats 45, not 20. Strike 1 Mr. Office |
Quoting 802flyguy (Reply 144): Not to nitpick an otherwise good post, rcair,but the DH8-100/200 has 37 seats. (The -300 has 50). But at PDT, the |
Quoting rcair1 (Reply 140): According to the US it 'departs' at 1730. According to flight aware - on May 3, US airways flight 4302 - Was scheduled to depart at 17:34. It departed at 17:36, 2 minutes post plan |
Quoting 802flyguy (Reply 144): I know that I am likely to get flamed here, but it can be tiresome to see armchair experts, who have never worked in the industry, pontificating about an airline should run. |
Quoting ckfred (Reply 148): The problems with not holding a flight for potential misconnects are that the released flight is leaving with empty seats (not good), and the misconnects have to be accomodated on later flights. If weather is causing a number of flights throughout the day to arrive late at a hub, letting flights depart on time with empty seats due to misconnects just makes it harder and harder to deal with an increasing number of misconnects. |
