YVRLTN
Aurigny Trislander Replacement?
Tue Jun 04, 2013 2:01 am
I saw in the last Airliner World magazine Aurigny Air Service will begin to look for replacements for their venerable PBN Trislanders, the youngest of which are now over 30 years old.
While not a huge order for any OEM exactly, this is a very unique aircraft which is pretty much synonymous with GR and has never really operated in any numbers or length of time any where else.
I guess I should get down to the CI's next time Im over.
What would a good replacement be? Viking Twotter? 4 more seats than the Trislander and the whole idea was the pistons would be cheaper than turbines, assume this would still be the case, despite being one less of them.
Follow me on twitter for YVR movements @vernonYVR
breiz
RE: Aurigny Trislander Replacement?
Tue Jun 04, 2013 12:26 pm
Indeed the Viking Twin-Otter should be the main contender. She is 1t or so heavier with 2 to 4 more seats (depending on out-fitting of both ac).
The PZL M28 Skytruck is a real alternative (19 pax, about same weight and performances), but she is barely newer than the Trislander.
Going single, there are the Cessna Caravan and the Pilatus PC-12, but they are smaller (9 pax).
vfw614
Tue Jun 04, 2013 12:37 pm
Aurigny has operated Twin Otters in the past and apparently it did not work out very well.
PlymSpotter
Tue Jun 04, 2013 12:38 pm
I suspect this will be for second hand aircraft, the cost of new builds would put a lot of pressure on the carrier. They have a good range of options:
DHC 6-300
Do 228-200
Let 410
Dan
93Sierra
Tue Jun 04, 2013 12:59 pm
Maybe the TECNAM aircraft Cape Air is going to use
Aesma
Tue Jun 04, 2013 1:07 pm
I was thinking a stretched remotorized Islander could do the trick (same stretch as Trislander without the tail engine) but it would need a pair of 500HP engines, that's where turbines are preferred usually.
TC957
Tue Jun 04, 2013 3:25 pm
I recall the main reason why the DH6 wasn't a success last time they used a couple many years ago was the frequent hot engine starts and excess maintenance that resulted. Their main JER-GCI route is only 25 or so miles, normally 12 - 15 mins. It'll be interesting to see which type they do end up selecting.
ukoverlander
Tue Jun 04, 2013 3:56 pm
I grew up flying on those Aurigny Trilanders around the Channel Islands. It'll be a sad day to see them go (but my eardrums wont miss them   They could give you some wild rides during the winter with heavy winds whipping in off the Atlantic. They must surely be the smallest tri-engine aircraft flying.
BMED
Tue Jun 04, 2013 4:55 pm
I guess the Viking would be the only plane that could replace in terms of capacity and runway abilities. Shame to see the Trislander's depart.
Living the jetset life! No better way to be
93Sierra
Tue Jun 04, 2013 9:24 pm
Maybe the same replacement that cape air
Is looking at from tecnam
TempestDriver
Tue Jun 04, 2013 11:25 pm
I don't know if scheduled flights in IFR are legally possible in the UK but if they are I would be inclined to suggest the 10-seat Gippsland Aerospace GA10. If a twin is required then the Gippsaero GA18 might fit. Both are turbine powered using the same make and model engine. The GA10 is currently in test flying and the GA18 will fly next year. The Viking Twin Otter would also be viable I imagine, if the other two suggestions are.
YVRLTN
Thu Jun 06, 2013 1:18 am
Quoting 93Sierra (Reply 9):
A lot smaller - it depends if they need the size of the Trislander still. I know back in the day they carried freight, newspapers and mail as well as pax.
Quoting TC957 (Reply 6):
This is what I was thinking, and PBN developed the Trislander with three piston engines from the Islander for this very reason. Not only that, but I think it still ended up cheaper than operating turbines too despite the additional engine.
Quoting Aesma (Reply 5):
There is the Allison (now RR) 250 powered Islander called the Defender.
Quoting ukoverlander (Reply 7):
Ugly, but a very unique machine, will indeed be sad to see them go.
sierra3tango
Thu Jun 06, 2013 5:54 am
Remember daily commuting between GCI/JER on these and Islanders.
After a couple of weeks asked if I could have the seat next to the pilot & duly did
The minute I got in he said "don't touch anything". But it was great to get a pilots eye view from the (not so) hot seat
Remember you had to be weighed on check in and were duly assigned seats to distribute weight
Is it still like that ?
jrn216
Thu Jun 06, 2013 6:19 am
I believe the Dornier 228 is the main contender to replace the Trislander. Of course it will be sad to see the aircraft eventually disapear from the skies around the C.I., but it has been in service for 30 years so a replacement is required soon.
Given the competition Aurigny now faces from Blue Islands and its ATR42 on flights between Guernsey and Jersey, a more passenger friendly aircraft is perhaps needed more than ever. Having said that, with the prospect of Aurigny taking on jet aircraft to operate the Gatwick route from Guernsey, I now wonder whether the Trislander replacement is the main priority.
[Edited 2013-06-05 23:20:00]
MHG
Thu Jun 06, 2013 7:18 am
I´d expect despite the - understandable - reluctance to employ turboprops for the short interisland hops they will finally end up with a 19-seater turboprop.
My guess is they´ll be looking into the DHC-6 or LET-410 (the latter being cheaper on the second hand market)
Possibly they need to look into getting permission (if neccessary) to keep engines running idle during unloading/loading at GCI and fly back to JER immediately after loading/boarding is completed.
This would cut the hot starts by half !
Flying is not inherently dangerous but it is very unforgiving in case of carelessness, incapacity or neglect.
