Quoting LH707330 (Reply 1): Now a 707 with GTFs, that would be cool.... |
Quoting SASMD82 (Reply 2): The 707 that is still built as 737. Very old but updated model. And still selling like hot cakes. |
Quoting anfromme (Reply 3): |
Quoting cschleic (Reply 6): This came to my mind first, too. Interesting how things go in cycles. Reduce to two engines, change the wing and landing gear, and you have a 737-900ER, complete with the new rear emergency exits like some 707's had. |
Quoting khenleydia (Thread starter): - Engines: Updated from the C-130 or A400? |
Quoting khenleydia (Thread starter): - Skin: Composite aluminium or carbon finer? |
Quoting khenleydia (Thread starter): - Landing gear: Same or somehow squeeze a 4 or 6 wheeled setup? |
Quoting khenleydia (Thread starter): - Flight deck: 2 person of course, but systems fly-by-wire or? |
Quoting afterburner33 (Reply 4): I would have thought that something like the Nimrod MRA4 would have come close to a situation like this. |
Quoting khenleydia (Thread starter): I will use the example of the Boeing 377 (based off of the B-29)... - Engines: Updated from the C-130 or A400? - Skin: Composite aluminium or carbon finer? |
Quoting LH707330 (Reply 1): One of the biggest drivers of efficiency is that planes are designed as a complete package where all components are designed to work together. Changing things afterwards typically results in an inferior result, even for the same technology level. |
Quoting SASMD82 (Reply 2): The 707 that is still built as 737. Very old but updated model. |
Quoting flyingturtle (Reply 19): |
Quoting HBGDS (Reply 20): |
Quoting exFWAOONW (Reply 13): Reducing the weight would require smaller engines, smaller wings, etc. At what point is it no longer a 377? |
Quoting Aircellist (Reply 12): Ah, my dream plane would then be a reengined or remade Lockheed L-1449 or L-1649 Super Starliner… |
Quoting FlyCaledonian (Reply 14): What sort of plane would have been a 727 twin, using the 727-100 and 727-200 fuselage lengths. and the T-tail just updated for lack of engine, with two rear mounted CFM engines? |
Quoting Revelation (Reply 22): The 737NG is radically different than the Classic. |
Quoting N62NA (Reply 28): Well then at what point does a 737 cease being a 737? |
Quoting khenleydia (Thread starter): I will use the example of the Boeing 377 (based off of the B-29)... - Engines: Updated from the C-130 or A400? |
Quoting maxpower1954 (Reply 11): The DC-8 Seventy Series (re-engined Sixty Series with CFM-56s, starting in 1981) is easily the most successful program updating a commercial airframe. |
Quoting Revelation (Reply 29): When the FAA refuses to certify it as a 737. |
Quoting RayChuang (Reply 34): And European airlines would have expressed far less interest in buying the A320, since many European airlines already flew the 727 by the late 1960's and a more environmentally-friendly 727 model would have kept the European airlines buying 727's. |
Quoting ExL10Mktg (Reply 26): |
Quoting N62NA (Reply 33): The FAA operates with strange logic sometimes (and this is one of them). I believe the FAA has given the 787 a common type rating with the 777. |
Quoting FlyCaledonian (Reply 14): One I've wondered about is the 727. I know it was replaced by the 757, but that was a jump in size from the 727-200. Now the last 727 was built in 1985, after the 737-300 was in production. What sort of plane would have been a 727 twin, using the 727-100 and 727-200 fuselage lengths. and the T-tail just updated for lack of engine, with two rear mounted CFM engines? |
Quoting panam330 (Reply 38): |
Quoting rwessel (Reply 37): A common type rating, which has to do with the requirements of the *pilot* flying the aircraft, is completely separate from the certification of two different aircraft designs, which has to do with how the requirements of the *aircraft*. |
Quoting ExL10Mktg (Reply 26): Quoting Aircellist (Reply 12): Ah, my dream plane would then be a reengined or remade Lockheed L-1449 or L-1649 Super Starliner… I too would love the concept, but I assume you mean a 1049 (the Super Constellation) not a 1449. The latter was a design study (stretched 1049 with new wing and turboprops) but none were ever built. They did, however, build 4 model 1249s -- 2 for the Air Force and 2 for the Navy. Standard 1049 but with turboprops. |
Quoting Aircellist (Reply 42): I agree that a redone Caravelle would be nice. |
Quoting antidote (Reply 23): |
Quoting N62NA (Reply 41): Which brings us right back to square one re: today's 737-900ER vs the 737-100. |
Quoting cptkrell (Reply 36): Turboprop Super Connie photo in your post brings back memories. I was lucky enough to win the Airliners International model contest in late 1990's with a kitbash of said beast, however I chose the Navy's other prototype, the R7V2 (picture the same airframe with Lockheed Electra style turbo nacelles) and dressed it in latest TWA livery. The designation of the Super Connie in your picture is YC-121F, I believe. The airframe of one of the 121-F's was actually salvaged and operated by Flying Tigers for a while (albeit without turbo prop power). |
Quoting Aircellist (Reply 42): About the 1449: sorry, I'm not home and my reference books are far away! The 1249 (or YC-121F) one you have pictured is, I believe, one of the two I had in mind. |
Quoting ExL10Mktg (Reply 46): The picture is of the R7V2. If you notice, it says United States Navy on the fuselage. |
Quoting ExL10Mktg (Reply 46): |
