Quoting psa1011 (Reply 4): Wouldn't the other cities mentioned be big on freight? |
Quoting mesaflyguy (Reply 1): believe the a330 has more cargo capabilities than the 767s, but don't quote me on that. |
Quoting g500 (Reply 5): good point |
Quoting Roseflyer (Reply 6): When DL had the 767 on the Lima route, they often had weight restrictions and bumped passenger seats for cargo. |
Quoting steex (Reply 7): Most of those other routes are also bigger on high yielding business pax, so DL tries to prioritize aircraft with a better BE product most of the time. |
Quoting yellowtail (Reply 12): With regard to LIM...nothing other than cargo drives the aircraft choice there. Every single LIM-ATL flight goes out with a full belly. |
Quoting simairlinenet (Reply 9): LIM was the only longhaul 764 destination--because it had more cargo capacity than the 763s. |
Quoting usflyer msp (Reply 15): When I flew to LIM in 2009 it was a 777, so the 330 is actually a downgauge.... |
Quoting drerx7 (Reply 17): The same reason that the first cross-fleeting at UA/CO was UA 763 on IAH-LIM...cargo. |
Quoting deltadudejg (Reply 22): With a 767 your only able to load LD-3s into the forward compartment, and cargo/bag cans into the rear because of the door configuration. The A330 allows LD-3s to be placed in both forward and rear, plus it is a little more versatile for different size LD-3s in both holds. |
Quoting juanpedro (Reply 11): Most of Peru's gold exports leave the country on Delta - not much by volume but lots by weight! |
Quoting steex (Reply 13): I don't doubt that - my comment was more aimed at the question "why not the 330 on other South American routes?" as opposed to "why the 330 to Lima?" |
Quoting deltadudejg (Reply 22): With a 767 your only able to load LD-3s into the forward compartment, and cargo/bag cans into the rear because of the door configuration. |
Quoting mayor (Reply 23): Unless I'm mistaken, you can load LD-3s front OR rear on a 767, however, they take up the space that would normally be occupied by two LD-2s, with wasted space as a result. |
Quoting DL_Mech (Reply 26): |
Quoting thenoflyzone (Reply 25): |
Quoting willzzz88 (Reply 3): |
Quoting Roseflyer (Reply 6): Grapes, Mangoes, Artichokes, and Avocados round out the top 5 exports which all need to be sent via air freight to the US. |
Quoting thenoflyzone (Reply 25): the 763 can hold 4 pallets in the front, or 16 LD-2 containers plus some bulk. In the rear, it's 14 LD-2s and/or bulk. |
Quoting thenoflyzone (Reply 20): Yes, but the 764 had balance issues out of LIM, issues the 763 didn't have, which is why it didn't last long. in the 764, large pallets are carried only in the forward bin, which are usually very heavy, explaining the balance issues. It was not uncommon to leave 25 business class seats open for the return to ATL on the 764. See: DL Out Of LIM - Why Huge Weight Restrictions? (by Transpac787 Dec 31 2009 in Civil Aviation) Thenoflyzone [Edited 2013-06-28 19:47:56] |
Quoting FlyASAGuy2005 (Reply 35): |
