• 1
  • 2
  • 3
  • 4
  • 5
  • 7
moderators
OZ 777 Crash At SFO Part 3
Sun Jul 07, 2013 1:52 am
Hello all,
Part 2 became long so Part 3 is being created in order to make it easier for members to find new information and to continue the conversation.
Part 1 Can be found here OZ 777 Crashes At SFO (by FlyDeltaJets Jul 6 2013 in Civil Aviation)
Part 2 Can be found here OZ 777 Crash At SFO Part 2 (by moderators Jul 6 2013 in Civil Aviation)
Photo © Ben Wang
Our thoughts go out to all of those involved in this horrible accident,
The Moderator Crew
[Edited 2013-07-06 20:09:09]
Please use [email protected] to contact us.
Fastphilly
Sun Jul 07, 2013 1:56 am
There must be some kind of video footage of this crash. I can't believe a major airport like SFO wouldn't have security cameras covering most angles of the property.
gulfstream650
Sun Jul 07, 2013 1:58 am
There is a photo on the local SFO media - it is a dust cloud so hard to make out anything. I'm sure something will pop up.
Edit for:
[Edited 2013-07-06 19:02:16]
I don't proclaim to be the best pilot in the world but I'm safe
Gatorman96
Quoting srbmod (Reply 40):
It looks to be in the water right before the seawall, as based on the images being shown on TV, there is something in the water there that looks a lot like the top of the engine pylon. If so, perhaps it hit the jetty/seawall first, sheared off and fell into the water as the rest of the plane moved forward. The debris field starts right at the end of the runway, so it seems likely that the #1 engine impacted the jetty.[/quote]
If the left engine was sheared off by the sea wall, the outcome would've been much worse. Again, the left engine and flaps sheared off when the aircraft slammed down after the tailstrike. CNN has an image of the left engine on land
atomsareenough
Sun Jul 07, 2013 1:59 am
Quoting Fastphilly (Reply 256):
That only applied to Rolls Royce Trent 895s. GE and PW engines 777s were not affected by the mandated redesign.
Right. Presumably their heat exchangers didn't have the same design flaw as the RR engines, where ice could be trapped and interrupt the fuel flow.
A388
Sun Jul 07, 2013 2:01 am
Have those UA 744 pilots been interviewed who saw this accident happen before there eyes? Surely they must be very important witnesses...?
A388
atomsareenough
Quoting Fastphilly (Reply 1):
It's quite likely that there's some video. As I said in the other thread though, the cameras would have to have been pointed in the right direction at the time of the crash, and even if they were, they would probably be nearly a mile and a half away from the crash site.
747WanSui
This accident reminds me of Korean Air Lines flight 015, which, on November 19, 1980, struck an embankment while on approach to a runway at Seoul, broke up and caught fire, killing 15 of the 226 people on board. The cause of that accident was determined to be pilot error.
Long live the Boeing 747!
atomsareenough
Sun Jul 07, 2013 2:02 am
Quoting A388 (Reply 5):
If they haven't, they surely will be. We wouldn't know about it either way at this point.
cjg225
Sun Jul 07, 2013 2:03 am
Thanks to Cubsrule in the last topic for providing a rough transcript of the ATC feed. I am trying to learn to decipher these better, but sometimes it is way too hard for someone like me...
Restoring Penn State's transportation heritage...
chrisnh
I really hope one or both of the crew in that UA 744 were looking at that 777 coming at them. However, I fear that they might have been engaged in their checklists and might have missed it
77west
Sun Jul 07, 2013 2:04 am
Quoting Starlionblue (Reply 250):
Not quite. The fuel was not contaminated. There was icing in the fuel lines and due to the design of the heat exchanger some of the ice got into the engine.
Sorry I meant contaminated by excess water, more than normal, in the tanks, leading to excess ice, more than the heat exchanger could handle.
77West - AW109S - BE90 - JS31 - B1900 - Q300 - ATR72 - DC9-30 - MD80 - B733 - A320 - B738 - A300-B4 - B773 - B77W
gulfstream650
Sun Jul 07, 2013 2:05 am
Quoting ChrisNH (Reply 10):
And passengers.
nwadeicer
Sun Jul 07, 2013 2:06 am
As I mentioned before. That close to the water, without a doubt a seagull strike.
I miss the Red Tail
cjg225
Sun Jul 07, 2013 2:07 am
We'll find out soon enough. Obviously, other pilots on the ground did a good job of keeping off the air until they knew that other flights were taken care of and only then started communicating with the tower to report what they saw.
DesertFlyer
Sun Jul 07, 2013 2:09 am
Here is flightaware data from the last few days on one graph. Seems to not be all that accurate.
http://i.imgur.com/AG4UFzQ.jpg
atomsareenough
Quoting NWAdeicer (Reply 13):
"Without a doubt"??? Couldn't have been ANY number of other things, from pilot error to mechanical failure, eh? I guess NTSB should just give you a call and close the book on it. Save themselves a trip from DC to SF.
flyabr
Sun Jul 07, 2013 2:18 am
Question: would the MLG have punctured through the wings if the plane had landed too hard? Didn't that happen on some other 777 in the past few years?? Reason for asking is I don't see any punctures holes through the wings...or any sign of the MLG in the pictures. Did the MLG get sheared off and is in the water??
atomsareenough
Sun Jul 07, 2013 2:19 am
Quoting flyabr (Reply 17):
Here's one of them way back by the tail (seems to point to the "sheared off" theory):
[Edited 2013-07-06 19:20:02]
[Edited 2013-07-06 19:20:15]
77west
Sun Jul 07, 2013 2:20 am
Depends on the direction of the forces. BA38 was a high rate of descent with minimal rearward 'dragging' forces, hence a punctured wing. This accident seems both vertical and horizontal forces, which would lead to the gear shearing off, especially the sea wall impact.
Gonzalo
This accident was much worse than BA038 and AF358, it was much more violent, the G forces involved were greater. The 2 deaths, and almost 60 injured, 10 of them in critical or very serious condition are the hardest proof. From the ATC transcript it seems they had an uneventful flight all the way until the very last moment, the pilots were calm and talking normally 7 miles away from the runway and only a couple of minutes later they crashed. Very intriguing situation....
Rgds.
G.
Gear Up!!: DC-3 / EMB-110 / FH-227 / A318-19-20-21 / B732 / B763 / B789 / B788 / A343 / ATR72-600
A388
Sun Jul 07, 2013 2:22 am
One of those UA 744 pilots must have been looking outside because when you compare that posted photo to the CNN footage you will see that the aircraft was taxiing at the time of the tail strike. The CNN footage shows the UA 744 holding at the turning point of the runway while the posted photo shows that aircraft at an earlier position when the 777 passed by with several smoke puffs indicating the moments when the 777 bounced hard while parts broke off.
A388
hivue
Sun Jul 07, 2013 2:26 am
Quoting 77West (Reply 11):
IIRC the amount of water in the fuel was WNL. The problem was that the aircraft passed through some particularly cold air at altitude and had a very smooth ride. As a result the normal little bits of ice that formed did not break up but rather grew to the point that, when they got shaken loose during landing, were big enough to clog the heat exchangers.
a380900
Sun Jul 07, 2013 2:28 am
In these times of surveillance cameras at every street corner, I can't imagine that major airports do not have several high quality cams for each runway.
Also I wonder in a case like SFO, if the airplane can't make it to the runway, wouldn't it be more reasonable to try to ditch the airplane in water. The Hudson river langing shows it can work out well. Or maybe the bigger theplane, the bigger the likelihood that it will break on impact with water?
corey07850
Sun Jul 07, 2013 2:29 am
Regarding the UA pilot holding short, here is some info from a user on reddit that is supposedly her nephew
http://www.reddit.com/r/worldnews/co...777_has_crashed_at_the_san/caxb1q9
77west
Sun Jul 07, 2013 2:30 am
Quoting hivue (Reply 22):
Either way the cold area was the biggest factor, one which was particularly unusual and has not been repeated. I was sure that excess water in the tanks at Beijing airport played a part. But if it was within limits of the aircraft, it should not have been an issue, only the cold air.
Fastphilly
Sun Jul 07, 2013 2:33 am
I'm wondering if the SFO officials are combing 28R for any related debris to the crash to possibly get that runway open if nothing turns up. An 8000 ft runway for fully fueled heavies with most passengers checking in 50lb cargo boxes/luggage (two per passenger) on trans-pacific flights makes for a "To The Cusp" take off.
codc10
Sun Jul 07, 2013 2:34 am
Re: temperatures over the Pacific Ocean, word is they were not cold enough today to result in freezing of Jet-A. OZ214 did not go polar and the temperatures en route were not unusually cold. Would be surprised if a BA038 situation was involved.
PHX787
Sun Jul 07, 2013 2:36 am
Ok I'm late to the party and trying to sift through 3 threads is very difficult...what happened here? Such a sad day to see an OZ 777 in such a state   RIP to the 2 on board who perished
MrBuzzcut
Sun Jul 07, 2013 2:37 am
Quoting 747WanSui (Reply 7):
Also similar to Korean Air 801, which struck Nimitz Hill on approach to GUM in 1997. ILS was OTS that day, they were flying a non-precision approach (though 801 was landing in some nasty weather, unlike this flight) and undershot the runway. At least this one had a better outcome.
AA94
Quoting A380900 (Reply 23):
I would say that the landing of US1549 in the Hudson was a one-off. I think that Capt. Sullenberger did an excellent job, keeping a cool head, and doing things by the book. I'd argue that this is the exception, not the rule. It's my (layman) opinion that a water landing that was generally as "perfect" as that of US1549 isn't something that can be replicated on a re-occuring basis.
I'd assume that the larger the plane, the harder it is to control.
flyabr
Quoting atomsareenough (Reply 18):
thanks for the pic...i do see some landing gear in that photo.
Fastphilly
Sun Jul 07, 2013 2:39 am
I believe it was the sudden rise in temperature on decent that released the ice into the FOHEs when it re-solidified.
atomsareenough
Sun Jul 07, 2013 2:42 am
Quoting PHX787 (Reply 28):
Cliff's notes version:
Flight 214 evidently came in slow and steep to 28L at SFO, landed VERY short, and the tail and/or the landing gear struck the seawall at the edge of the airfield. The pilot may or may not have been trying to do a late go-around, which could explain a high angle of attack and the tail striking. The tail snapped off and the main fuselage slammed into the pavement and skidded to a stop off the left side of the runway within 2000 feet. So far, of the 307 passengers and crew, only 2 are confirmed dead and 1 is unaccounted for. Many dozens in serious or critical condition, though. Plane caught fire soon after it crashed, but almost everyone seems to have gotten off the plane before it was engulfed.
Mir
You'd have to know that you wouldn't make it early enough, which it doesn't seem was the case here. Also, you'd have to be wary of the approach light system, which extends well into the bay and would be a very bad thing to land on - likely worse than this outcome.
-Mir
NAV20
A bit of extra information. Our ABC radio got an interview with an 'eye-witness' passenger:-
"Benjamin Levy, who was on board the plane when it crashed, said he believed the plane had been flying too low as it came in to land.
"I know the airport pretty well, so I realised the guy was a bit too low, too fast, and somehow he was not going to hit the runway on time," he told a local NBC station.
"He was too low ... he put some gas and tried to go up again ... but it was too late, so we hit the runway pretty bad.
"Then we started going up in the air again, and then landed again, pretty hard."
He said he opened an emergency door and ushered people out.
"We got pretty much everyone in the back section of the plane out," he said.
"When we got out there was some smoke. There was no fire then, the fire came afterward."
http://www.abc.net.au/news/2013-07-0...s-at-san-francisco-airport/4804038
[Edited 2013-07-06 19:45:47]
"Once you have flown, you will walk the earth with your eyes turned skywards.." - Leonardo da Vinci
aviators99
Quoting AA94 (Reply 30):
I can't find the exact statistics, but a controlled water landing has a very high survivability rate (somewhere in the 90+ percent range), while a controlled off-runway non-water landing has a materially lower rate. Sullenberger and crew of course did an excellent job.
I was upset to see people evacuating this plane with luggage. This could have resulted in many more people dying.
chrisnh
Sun Jul 07, 2013 2:44 am
Somehow they managed to turn the 747 around on that taxiway and point it in the opposite direction. Talk about your 'Three-Point Turn.'
rfields5421
Sun Jul 07, 2013 2:46 am
Why should they go to that expense?
It's not like an aircraft carrier where every landing is evaluated.
Yes, it would have been useful in this instance. But in the vast majority of aircraft accidents - a runway camera is of no use. Probably $100-200 thousand for a system at SFO. $10-15 thousand a year for maintenance.
It has been 42 years since in incident at SFO where a runway camera would have captured a crash.
atomsareenough
Sun Jul 07, 2013 2:47 am
Now all 307 pax+crew are accounted for, and still only 2 confirmed fatalities, according to SF Mayor Ed Lee at the live SFO press conference.
KirkSeattle
Sun Jul 07, 2013 2:48 am
CNN just showed a video from a passenger. It's amazing how many people took time to get their bags. That's so scary that people would take time for material things that could be replaced where life cannot.
AirlineBrat
Sun Jul 07, 2013 2:49 am
Not much analysis from me. Been following media reports, the threads on Airliners, listening to the ATC recordings and everything else. To see that most of the passengers and crew survived is a blessing. I am humbled by how the SFO ATC handled this event, how the emergency crews responded and how Boeing engineering designed an aircraft to hold up to an event such as this. My thoughts are with those who passed away, those injured and those who were able to walk away.
I'm leavin on a jet plane. Don't know when I'll be back again....
KBUF
All souls now accounted for according to San Francisco's mayor.
"Starting today, the Buffalo Sabres' reason for existence will be to win a Stanley Cup."-Terry Pegula, February 22, 2011
aviators99
Quoting Kirkseattle (Reply 40):
Including the lives of others they are impeding.
Gonzalo
Sun Jul 07, 2013 2:53 am
Quoting corey07850 (Reply 24):
He says his aunt was flight crew on the UA 744, and I quote :
"She witnessed the entire thing"..."she's pretty shook up and I don't think has time to communicate any information, she has some photos though I may be able to upload soon.."
Let's see if this lady has some good reliable information to share with the investigators....
Rgds.
G.-
AirKorea
Sun Jul 07, 2013 2:54 am
Latest Information or spelucations
OZ 214 was manufactured in 2006 and is 7 years old.
2 passengers are in death while arounf 60~70 in hospitalised. among them around 10 got seriously injured.
The possibilitiy that tails hit seawall and the around getting high. Passengers told that the plane flew too low, and suddenly the plane rotated and then felt the rear part hit somewhere.
Slcpilot
Sun Jul 07, 2013 2:56 am
I don't think this has been brought up.
It doesn't matter what METAR or ATIS you have, I know what the winds were doing at the accident site just afterwards! Look at the smoke plume! It suggests a wind from the south east. Now the wind is obviously not strong, but a descent through a shear can leave a crew on the back side of the power curve if they're not paying attention.
Thoughts?
SLCPilot
I don't like to be fueled by anger, I don't like to be fooled by lust...
rfields5421
Sun Jul 07, 2013 2:58 am
Reviewed thread two and saw this one at the end
Korean media is reporting that OZ214 landed on 28L, which was "closed" due to navigational equipment (Presumably ILS) issues. Was 28L in use at the time of the accident?
28L was in use. Both 28L and 28R did not have the ILS operational. This was known to pilots via NOTAMs.
The runways were fully operational.
In the weather at SFO Saturday local time - if a pilot can't make a visual landing - he/she has no business flying anythin bigger than a C-172 - certainly not a B777.
You have to ditch soon enough to know your aircraft is not going to hit that seawall embankment. The Lion Air landing short of the runway at Bali recently hit the water about a thousand feet short of the runway.
A bigger issue at SFO is that airport has long approach light structures extending 3,150 feet out into the water. Those structures to hold the lights are strong enough to rip apart an aircraft (see PanAm 1971 takeoff incident info on Wikipedia).
At SFO, the pilot would have had to make the decision to ditch and come down into the water a mile to three-quarters of a mile from the end of the runway.
Quoting aviators99 (Reply 36):
I'd love to see the statistics, because my understanding is that water landings have a very low survival percentage compared to off runway setdowns.
fpetrutiu
Sun Jul 07, 2013 2:59 am
Latest info from press conference:
2 dead > R.I.P.
182 transported to area hospitals if which 5 in critical condition > wishing them speedy recovery
123 with no reported injuries or very minor > buy a lottery ticket, seems to be your lucky day
This seems to account for all 307 passengers.
Florin
Orlando, FL
mark2fly1034
Sun Jul 07, 2013 3:00 am
Quoting Gonzalo (Reply 44):
I don't know much about the 747 but on most planes they don't have a great view of the outside and she should of been seated as they were about to take off. Here is ATC recording if no one has posted it yet
http://soberbuildengineer-com.s3.amazonaws.com/AAR214-KSFO-Crash.mp3
  • 1
  • 2
  • 3
  • 4
  • 5
  • 7
