TG679 CAN - BKK.
Pic from twitter. No more info available so far.
Quoting TheRedBaron (Reply 6): Aircraft looks pretty bad.... I wonder if weather is a factor here...anyone knows the METAR ? |
Quoting KarelXWB (Reply 10): The damage is pretty obvious. Some reports on Twitter say it was a crash landing, but this has not been confirmed yet. |
Quoting kaitak (Reply 9): Good load too ... presumably that's about 282 pax and 16 crew? Still a good load factor. |
Quoting DocLightning (Reply 14): What else was it? |
Quoting KarelXWB (Reply 15): Maybe it just overshot the runway? |
Quoting KarelXWB (Reply 17): Close-up pictures of the left hand engine are coming in: |
Quoting shanxz (Reply 16): Guangzhou - Bangkok wheelbase crashed while landing at the airport. There are 14 people slightly injured passengers were taken to hospital. |
Quoting DocLightning (Reply 19): That would count as a "crash landing" in my book. It crashed during the landing. The landing isn't over until you are either stopped or safely off the runway. |
Quoting sankaps (Reply 20): Sorry to nitpick especially since I normally agree with your posts, but there is a difference, IMO. A crash landing is when the aircraft crashes into the runway -- ie the crash occurs at the point the aircraft impacts the runway. |
Quoting DocLightning (Reply 22): Quoting sankaps (Reply 20):Sorry to nitpick especially since I normally agree with your posts, but there is a difference, IMO. A crash landing is when the aircraft crashes into the runway -- ie the crash occurs at the point the aircraft impacts the runway. Is there an official or conventionally-accepted definition? |
Quoting KC135TopBoom (Reply 23): Actually there does not need to be a runway in a 'crash landing'. A crash landing occurs during a landing attempt, it can be an emergency landing out in a field somewhere, on a highway, or a ditching at sea. Although most do occur on or near a runway that the landing is attempted on. The crash of the OZ B-77E several weeks ago in SFO was actually a crash landing. A crash landing can result in damage levels from no damage at all, to minor damage, or a full write off and everything in between, to the aircraft.. There can be no injuries to fatalities to the crew and passengers. |
Quoting DocLightning (Reply 22): There are formal definitions of "accident" vs. "incident" and this definitely counts as an "accident." |
Quoting KC135TopBoom (Reply 23): Actually there does not need to be a runway in a 'crash landing'. A crash landing occurs during a landing attempt |
Quoting DocLightning (Reply 24): So assuming, for the moment (as it seems to be the case), that the aircraft crashed during the landing sequence, what would you call this? |
Quoting KarelXWB (Reply 25): As the aircraft was landing and the landing gear touched the runway, the nose gear has failed. As a result, the plane skidded off the runway |
Quoting KarelXWB (Reply 8): All 298 persons on board are safe. |
Quoting BoeingMerica (Reply 27): Sad the bird is a goner |
Quoting cloudyapple (Reply 34): Logos and rego's painted out. Pretty definitive. |
Quoting sankaps (Reply 20): Quoting DocLightning (Reply 19): That would count as a "crash landing" in my book. It crashed during the landing. The landing isn't over until you are either stopped or safely off the runway. Sorry to nitpick especially since I normally agree with your posts, but there is a difference, IMO. A crash landing is when the aircraft crashes into the runway -- ie the crash occurs at the point the aircraft impacts the runway. A runway overrun can occur even after a perfectly normally touchdown or landing, and even if it results in a write-off, it is different from a crash-landing. |
Quoting TheRedBaron (Reply 6): Aircraft looks pretty bad.... |
Quoting QatarA340 (Reply 38): Is this the first A330-300 crash? I think all the others were -200. |
Quoting SA7700 (Reply 43): Quoting QatarA340 (Reply 38):Is this the first A330-300 crash? I think all the others were -200. If written off it will be the second A333 hull loss, the first being MH (9M-MKB) which was damaged beyond economical repair when a chemical spill occurred in the cargo hold. |
Quoting frigatebird (Reply 44): Don't forget the A330-300 that crashed at a test flight in 1994, which, incidentally, was to become TG's first A330 (HS-TEA) |
Quoting KarelXWB (Reply 40): The tiles have been covered already. |
