Quoting doulasc (Thread starter): MIA and FLL will run out of room to grow some day. Do you think that a airport built to the west caddy corner from FLL and MIA could serve both Dade and Broward County someday replacing FLL and MIA? |
Quoting Miami (Reply 1): They can make the airport in Aventura or North Miami Beach. Right in between the two airports. It'll be great for the city of Miami if they moved away from downtown. It'll be able to make tall skyscrapers without the FAA giving them any problems. |
Quoting Byrdluvs747 (Reply 8): If the op is proposing closing MIA and FLL to operate a third facility, then I would say its not going to happen. MIA has spent millions on AA's terminal and will eventually spend millions more on the central concourse. |
Quoting doulasc (Thread starter): MIA and FLL will run out of room to grow some day. |
Quoting jfk777 (Reply 11): If one combined airport could get built where would it be built ? The everglades are west from Miami and FLL, there is not enough land anywhere down there for an airport that size. It was tried in the 1960's, to build a jetport west from Miami, but it got cancelled, the enviromentalists won. |
Quoting Miami (Reply 1): They can make the airport in Aventura or North Miami Beach. Right in between the two airports |
Quoting flymia (Reply 14): Both airports are undergoing or have undergone huge renovation/expansion projects |
Quoting flymia (Reply 14): |
Quoting flymia (Reply 14): Building a passenger terminal at OPF or Expanding OPF or Homestead Air Force base to be cargo only airports and allow some of the cargo space currently used at MIA to be turned into a passenger area |
Quoting Miami (Reply 15): Explain to me what are they doing at MIA RIGHT NOW?? MIA isn't doing anything at the moment. They only have plans to redevelop the central terminal. That's it. |
Quoting LittleFokker (Reply 4): You're under the impression that American aviation is still growing. Passenger traffic has been flat for the last few years, and all indications are that won't be changing any time soon. |
Quoting Miami (Reply 1): MIA is known for international, while FLL is known for Domestic. Combine the two and it'll be similar to LAX. |
Quoting Miami (Reply 15): Right now MIA needs to focus on doing an extreme makeover. Close runway 12/30. That runway is useless. |
Quoting Miami (Reply 15): Explain to me what are they doing at MIA RIGHT NOW?? MIA isn't doing anything at the moment. |
Quoting N62NA (Reply 18): 12/30 isn't useless at all. It's very useful. It's used all the time at the same time as the other 3 runways. |
Quoting Miami (Reply 15): Right now MIA needs to focus on doing an extreme makeover. Close runway 12/30. That runway is useless. Lower fees |
Quoting Miami (Reply 15): Yeah... That's not happening. Not even in a million years. |
Quoting Miami (Reply 19): Would you rather have a new expansion and close runway 12/30 (3rd longest runway) or keep runway 12/30 and leave the airport how it is? |
Quoting Miami (Reply 15): Right now MIA needs to focus on doing an extreme makeover. Close runway 12/30. That runway is useless. Lower fees. |
Quoting MIADeparture (Reply 29): It will be a very, very long time before these two airports fill to capacity. |
Quoting MIADeparture (Reply 29): At late at night it is usually more exciting than MIA traffic, with a steady stream of late arrivals past 10 pm till 11:30 or so. |
Quoting 2travel2know2 (Reply 31): However, TNT Dade-Collier plans to develop as yet another commercial airport in South East Florida, as tiny as it might be, likely would be stopped by environmentalists. |
Quoting 2travel2know2 (Reply 31): South Eastern Florida's demographics point out that HST Homestead may work as a secondary airport if a deal can be worked with the U.S. Air Force. IMHO, There are some domestic and international routes which may be sustained from that airport. |
Quoting par13del (Reply 16): Based on the money spent on the last few terminals, the new rental center and the screwed up station placement for the metro rail they need to go into hiding for a few years and let the public get over their incompetence that has cost the tax payers dearly and went way over budget. |
Quoting MIADeparture (Reply 29): Runway 12/30 is an integral part of the ops at MIA. In conjunction with Land and Hold Short (LAHSO), it allows us two independent runways (12 & 9) with ILS capability to arrive on (weather permitting). That's on an East ops. West ops, it works the same with 30 and 26R, but no LAHSO requirement. Only Cargo traffic from Cargo City, Western and Eastern U depart 9. Exceptions being Lufthansa's A388/748 and pilot requests. This allows us to use 8R as a primary departure runway, with no crossing traffic. No, keep 12/30, develop the terminals. |
Quoting MIADeparture (Reply 29): Its these reasons that MDAD will not allow OPF to develop into a mini-FLL. They barely want Cessnas and Pipers to park there...subject to another discussion. |
Quoting 2travel2know2 (Reply 31): South Eastern Florida's demographics point out that HST Homestead may work as a secondary airport if a deal can be worked with the U.S. Air Force. IMHO, There are some domestic and international routes which may be sustained from that airport.Other than that region getting another major commercial airport, it seems neither MIA nor FLL will be forced to relocate to a brand new airport.However, TNT Dade-Collier plans to develop as yet another commercial airport in South East Florida, as tiny as it might be, likely would be stopped by environmentalists. |
Quoting cmf (Reply 33): TNT died together with B2707. The location was selected to keep the noise from supersonic airplanes away from developed areas. The site has no infrastructure. There is a single road that will cost a fortune to expand. Even so it is cheap compared to the cost of stabilizing the land required to build runways and everything else required. Just bringing out enough electricity is a major undertaking. |
Quoting OB1504 (Reply 35): Seriously, what's with MDAD's apparent distaste for light aircraft? The South Florida area is a pilot training mecca and sometimes it's like the county wants to push it all north to Broward. |
Quoting NASCARAirforce (Reply 36): TNT is way out there. That is a further drive than DEN is from Denver. If that were to be the new airport it would be the furthest main airport from a downtown area. You might as well call it the Naples International Airport (j/k). Tamiami Trail is a 2 lane road that goes by it. It would be an environmental mess that would pretty much destroy the everglades. On top of that, isn't it pretty close to both the Seminole and Miccosukee Reservations? |
Quoting LV (Reply 3): There was a proposal to build an airport in the middle of the Everglades. There is even a runway out where it was supposed to be and a small airport there. It's called the Dade-Collier Training and Transition airport. It is still open as far as I know. Here are the details : http://www.airnav.com/airport/KTNT |
Quoting NASCARAirforce (Reply 36): I think it is a safety issue. That is crowded airspace with both FLL and MIA there. Planes on downwind legs for MIA overfly OPF. How far does MIA Class Bravo Airspace extend? A lot of light GA aircraft between MIA and FLL is setting up for an incident like PSA at SAN or Aeromexico near LAX over dense neighborhoods |
Quoting FlyAAS80 (Reply 38): I was surprised to see that TNT had a 10,499ft runway! Quite a bit of concrete with a whole lot of nothing else out there. Does anyone have any info as to who utilizes this airport? States that it is closed to the public, but with all the National Park traffic, is it theirs? |
Quoting cmf (Reply 23): |
Quoting zippyjet (Reply 42): How can I say this tactfully? The area around OPF is far from being in the top rankings of South Florida or for that matter the entire Sunshine State's toniest neighborhoods. |
Quoting cmf (Reply 43): |
Quoting mia305 (Reply 45): There's no way commercial service will ever begin at the airport not even as a reliver airport. That would cost way to much to clean up and redevelop the area around OPF. |
Quoting cmf (Reply 43): When did Miami Lakes become that bad? |
Quoting zippyjet (Reply 44): When you refer to Midtown are you talking about the areas around Biscayne Blvd and Flagler St. near the cruise ship entrance to the Port of Miami? |
Quoting zippyjet (Reply 44): What are your thoughts about OPF having passenger traffic? Not as a replacement to MIA or FLL but a third alternative? |
Quoting zippyjet (Reply 42): How can I say this tactfully? The area around OPF is far from being in the top rankings of South Florida or for that matter the entire Sunshine State's toniest neighborhoods. So unless one is going to develop public housing or displace the locals and gentrify the area, OPF will still be in business. It wouldn't be a bad alternative but not a replacement for FLL and MIA. I could imagine a LCC setting up shop at OPF if allowed. OPF with commercial service would be akin to ACY. |
Quoting zippyjet (Reply 42): I still hold hope we WN/FL will break into MIA. There's enough business for us and them in additon to FLL. I hope we and MIA can make a sweet deal so we can start MIA service sooner rather than later. |
Quoting cmf (Reply 43): When did Miami Lakes become that bad? Also, things change. It isn't long ago you couldn't get people to drive thru midtown middle of the day. Now people pay good money to live there. |
Quoting zippyjet (Reply 44): I forgot who told me but, they were a Miami Beach resident and born in the Miami area and said the area around OPF was one of the bad areas of town. I could swear that it had been mentioned several times and recent regarding this area being not the greatest. I learn something new each day. |
