Quoting LittleFokker (Reply 2): |
Quoting 777STL (Reply 6): |
Quoting longhauler (Reply 5): What the hell is she going to land on a 3200' runway, a Piper Cub? Surely none of the private jets that she would want to fly in there. |
Quoting Viscount724 (Reply 10): 3200 feet is long enough for some of the smallest bizjets. |
Quoting Pellegrine (Reply 17): Well say someone has 3000-5000+ acres, not in Bel Air obviously, but say Colorado or Iowa...how hard would it be to get approval for say a 10,000'+ asphalt/concrete runway? Cost is one thing, approval from authorities is another. Private WB taxiing to a country house? |
Quoting Rhodylee (Reply 1): Well, google says 3 acres = 130680 square feet. 130680/3200 = 40'. So, the only way it could work is if the lot was 40' x 3200', which is highly unlikely - it would also leave little room for a house, or a vineyard |
Quoting 707lvr (Reply 14): This should probably have stopped at Reply 1. |
Quoting Pellegrine (Reply 17): but say Colorado or Iowa...how hard would it be to get approval for say a 10,000'+ asphalt/concrete runway? Cost is one thing, approval from authorities is another. Private WB taxiing to a country house? |
Quoting scbriml (Reply 25): Insert Jennifer Aniston and "landing strip" gag here. |
Quoting scbriml (Reply 25): Seriously, who cares? |
Quoting AM777LR (Reply 7): I would assume it would interfere with the LAX TCA. |
Quoting AR385 (Reply 12): Can you build a runway with $1,000,000 including all the facilities and FAA compliances? |
Quoting planespotting (Reply 28): I'm guessing she hasn't checked into the very expensive insurance requirements (not to mention the maintenance and upkeep expenses) to own and operate a private concrete strip. I know of large, multinational agricultural firms who have built their own runways before realizing they were prohibitively expensive to operate as a private entity (not part of public infrastructure). |
Quoting Revelation (Reply 29): Also you'd want it to be in a place where you wouldn't need FAA clearance every time you enter its airspace |
Quoting timpdx (Thread starter): Can you just plop down a runway if you own a nice chunk of land? I can't possibly be that simple. |
Quoting DTW2HYD (Reply 20): There are communities with private airport with taxiway to villa. Can't she buy a villa there. |
Quoting glideslope (Reply 30): Quoting 707lvr (Reply 14): This should probably have stopped at Reply 1. Yup. |
Quoting Viscount724 (Reply 37): Or she can buy a closed military base and name it for herself, like this U.S. television evangelist. He bought this former Marines base near Fort Worth, Texas where his two Citations (including an X) are based. |
Quoting DTW2HYD (Reply 41): Quoting Viscount724 (Reply 37): Or she can buy a closed military base and name it for herself, like this U.S. television evangelist. He bought this former Marines base near Fort Worth, Texas where his two Citations (including an X) are based. Good idea. Also, she can buy VAB @KSC and pay per runway use. Help NASA. Or just buy a V22 Osprey and help the test program. Lot of patriotic ways to deal with middle age crisis. |
Quoting 71Zulu (Reply 23): Usually not hard at all, Texas even publishes a guide on how to do it. |
Quoting planespotting (Reply 28): I'm guessing she hasn't checked into the very expensive insurance requirements (not to mention the maintenance and upkeep expenses) to own and operate a private concrete strip. |
Quoting Revelation (Reply 29): Well, if you slap the word 'private' on it, the FAA doesn't care that much. Also you'd want it to be in a place where you wouldn't need FAA clearance every time you enter its airspace which would be the most likely case in large parts of IA or CO. |
Quoting DiamondFlyer (Reply 32): Sure, you could do it for less. There isn't much you have to do to comply with the FAA, the bigger issue is dealing with local regulations. There is no legal requirement to even tell the FAA you're building a runway. Roll some grass in your back yard for a 1000 ft STOL strip, no problem. |
Quoting Max Q (Reply 47): Funny beautiful and a good actress, she really is a ray of sunshine in a sometimes dismal world. |
