Quoting Birdwatching (Reply 2): How are they "detention pods" as your title suggests? Have you made that up? |
Quoting jcwr56 (Reply 4): Would be interesting to see in the event of a fire within the terminal how these would operate, or you had to evacuate the terminal quickly. |
Quoting flyingcaT (Reply 6): so in a way a more extravagant version of a revolving door. |
Quoting Natflyer (Reply 9): I have seen a better system in Europe, f.ex in CPH. You walk through the first door, and keep on walking, and it closes behind you and the one in front opens. No delay. Simple. |
Quoting DocLightning (Reply 8): Why not use one of those revolving cage doors that only allows traffic to flow in one direction like you see at theme parks and the like? Surely if the diameter is made large enough, it will accommodate a passenger with a roll-on. |
Quoting RDH3E (Reply 11): Agreed. This seems like the simplest solution. No high-tech gadgets to malfuntion etc. It is one way and that is final! |
Quoting Cubsrule (Reply 12): And how much would a sufficiently large one weigh? |
Quoting RDH3E (Reply 13): Not that much? Why is that even an issue given these are ground based? |
Quoting Cubsrule (Reply 14): It seems to me that none of the revolving door-type exits will work for exits with large volumes of passengers. |
Quoting RDH3E (Reply 15): Have you never commuted on a subway/cta? Larger volumes of passengers use those than use airport exits. |
Quoting Cubsrule (Reply 17): First, many (most?) CTA customers use the turnstyles and wheelchair 'doors' for egress. Second, most CTA passengers don't have luggage. |
Quoting RDH3E (Reply 18): The point is, the same concept could very easily be implemented much cheaper and just as effectively as this concept that is the topic this thread was about. |
Quoting rwessel (Reply 21): If nothing else, those would approximately halve the capacity of a given width of doors (only half of the width of those can be used for people moving through). Also, the purely mechanical ones are going to be a handful for many people trying to haul several bags. Especially if you've got a cart. And while you can obviously mechanism those, you lose one of that design’s major advantages. |
Quoting fpetrutiu (Reply 22): Both sides open up and is triggered by the fire alarm. |
Quoting DocLightning (Reply 23): And there is the fatal security flaw. |
Quoting max999 (Reply 25): The point of these doors is so the TSA agent can be reassigned to a more useful post that requires more skill than sitting around watching an exit. |
Quoting RDH3E (Reply 26): I believe it's so that you can just fire that guy. |
Quoting RDH3E (Reply 26): I also think this is the first time anyone has referred to the TSA as "skilled" labor. |
Quoting Birdwatching (Reply 2): There are some jobs that are meant to be performed by machines. |
Quoting fpetrutiu (Reply 30): Not really. In case of any fire alarm being triggered, the whole terminal area is considered as being not sterile in standard SOP. In other words, no aircraft can be boarded/departing/deplaned in that area until the area is back to sterile status. |
Quoting DocLightning (Reply 31): I wonder how many people will get stuck in them when the exit doors fail to open |
Quoting Byrdluvs747 (Reply 27): Whew!! I thought the article was going to be about the TSA implementing the mini Guantanamo camps found in European Airports. |
Quoting ArmitageShanks (Reply 37): This madness has to stop. |
Quoting rmoore7734 (Thread starter): Quote from article "The new “exit” portals gulags at Syracuse Hancock Airport are bulletproof pods that are meant to make you feel like a prisoner who cannot leave." |
Quoting jpetekyxmd80 (Reply 40): What madness? Sensible design? |
Quoting DocLightning (Reply 31): If the alarm allows both doors to open at once, then there might be a way to hotwire it without the alarm actually sounding. It would take an inside job, but such things have happened before. And since the whole point is that the exit would be unguarded, then whoever is holding the "garage door opener" could get through undetected. If the solution is to guard the exit, then why have the expensive doors? |
Quoting jcwr56 (Reply 4): It appears they've timed the doors to close and open just enough you're trapped for a second or two. Would be interesting to see in the event of a fire within the terminal how these would operate, or you had to evacuate the terminal quickly. |
Quoting max999 (Reply 5): I agree, the title of this thread is misleading. The wording makes it seem like the thread starter has an agenda to push. |
Quoting jpetekyxmd80 (Reply 40): You should be embarrassed at the BS you are precipitating. I know I would be. |
Quoting DocLightning (Reply 8): Why not use one of those revolving cage doors t |
Quoting flyingcaT (Reply 6): Will this eliminate the need to have a person stand around all day to watch people leave? |
Quoting aklrno (Reply 33): As an addition to airport security I like the idea. That nearly sleeping guard at airport exits is bad security at a high price. |
Quoting Indy (Reply 45): But the completely dumb thing is that the airport has an entrance that can be used. |
