Quoting catiii (Reply 3): Just to be clear, this is not a rejected landing since the main gears never touched down. It is a (very in close) go around. It's also another case of tremendously sensationalized journalism |
Quoting catiii (Reply 3): Just to be clear, this is not a rejected landing since the main gears never touched down. |
Quoting Roseflyer (Reply 5): The gear do not have to touch down to be a rejected landing. |
Quoting BostonMike (Reply 6): It would have been very "interesting" to see how that aircraft could have completed a landing in that crab. Either you fly a crosswind landing using "wing-down and top rudder" to keep the aircraft straight or you have to kick out the crab at the end. There was no attempt at straightening the aircraft out in the video. Glad they went around |
Quoting catiii (Reply 9): According to the Airbus, Boeing, and Flight Safety Foundation definitions, a rejected landing is "defined as go-around maneuver initiated after touchdown of the main landing gear or after bouncing." |
Quoting catiii (Reply 9): Airline pilots on this board can confirm, but I'm pretty sure that in a sweptwing wing-mounted engine aircraft, crabbing in a crosswind is the preferred technique so you don't have a nacelle strike on touchdown. |
Quoting 26point2 (Reply 15): You align the plane with the runway just before touchdown. Once aligned with a cross wind the plane will drift so timing is critical. |
Quoting s5daw (Reply 10): Why are flights like that even scheduled? I mean, we knew the storm was coming so what's the point? And if the wind is gusting over 40 knots perpendicular to the runway, why even bother trying to land? |
Quoting Roseflyer (Reply 5): The Dash 8 video after the 777 on that link was a far more interesting approach. The Dash 8 looked far less stable than the 777. |
Quoting Eagleboy (Reply 19): Why are flights like that even scheduled? I mean, we knew the storm was coming so what's the point? In this video, the visibility looked quite adequate. My question would be.......am I flying within the crosswind limits of my aircraft? I can never recall flying an airliner that said that the "crab method" to touchdown was preferred. A combination of the two......crab on approach.....then switching to using the rudder to align to runway heading while carefully lowering the upwind wing and touching down on the upwind mlg (usually very softly, and certainly more softly than landing in a crab) [quote=BostonMike,reply=12]Yes, crabbing may be a preferred method of flying an approach in a significant crosswind, but landing in a crab was never an option on my aircraft. |
