Quoting photoshooter (Thread starter): Even if you don't have the cash for it, I'm sure there's a way out. |
Quoting KarelXWB (Reply 1): Perhaps Brussels Airlines needs a better business plan in the first place. |
Quoting KarelXWB (Reply 1): They could lease 787s instead of buying but the lease rates are much higher than an old A330. |
Quoting senatorflyer (Reply 3): |
Quoting photoshooter (Reply 2): I wonder if there are any available. They are currently having long haul fleet problems |
Quoting photoshooter (Reply 2): Couldn't agree more. I think the Ryanair Base at BRU will be the coup de grace for SN. |
Quoting Ab345 (Reply 4): I also have to state that at one point I was trying to book a ticket for ATH-BRU and the competition was a no-brainer. A3 was around 220€, KL was about 350€ and SN was at 450€ (at that at a discounted rate |
Quoting blueflyer (Reply 6): Brussels Airlines needs to carefully continue playing on its strength (its African network) and take advantage of possible partnerships with other airlines in the Lufthansa group. Closing one station in Africa where Swiss was stronger and funneling the traffic through ZRH in exchange for Swiss reciprocating for another destination is the kind of mutually beneficial consolidation that should be implemented whenever possible. |
Quoting smbukas (Reply 8): Brussels Airlines Africa network is not to big enough not sustain all feeder routes |
Quoting airbazar (Reply 10): Much is said about SN's African network but when you look at the details it's not that strong at all. A lot of their African destinations are served as triangular or tagged routes, and with very low weekly frequencies. |
Quoting blueflyer (Reply 6): For another, with the exception of IBZ, all the destinations Ryanair will serve out of BRU are already available from CRL. There are very few price-above-all Belgian customers for whom CRL is too far an airport, and these do not use BRU, they go to MST or EIN where Ryanair also operates instead! To be sure, Brussels Airlines will lose some low-yielding passengers to either Ryanair or Vueling and may have to adjust capacity or even close a marginal route, but I believe this is nowhere near the proverbial nail in the coffin because passengers that would fly Ryanair to these destinations were lost years ago! |
Quoting blueflyer (Reply 6): Temporary problems. One A330 is out for scheduled maintenance, another is AOG at IAD with engine troubles. |
Quoting flyguy89 (Reply 7): I can't read Dutch, but running the article through Google Translate, it seems the article the OP linked to is about possible labor action but not about SN's financial performance. I had been under the impression that SN had turned a corner and their financial situation improved, does anyone have details? |
Quoting smbukas (Reply 8): new fleet for regional network, |
Quoting smbukas (Reply 8): But they need a lot of cash to go with such strategy. |
Quoting photoshooter (Reply 12): Amen to that! They will receive financial support from the Belgian government |
Quoting flyguy89 (Reply 13): Much is said about it because it is the largest *A carrier between Europe and Africa. |
Quoting flyguy89 (Reply 13): And no, that does not amount to low-yield VFR considering Africa is by far their strongest, most profitable area of operations. |
Quoting airbazar (Reply 15): Actually, TK is the largest. SN is second by total cities served but like I said their routes are very low frequency tags or triangular routes. When you look at the details, TP has more non-stop destinations and more frequencies than SN. And I would be shocked if LH/LX didn't have more weekly seats than SN, and growing. |
Quoting airbazar (Reply 15): Quoting flyguy89 (Reply 13): Much is said about it because it is the largest *A carrier between Europe and Africa. Actually, TK is the largest. |
Quoting airbazar (Reply 15): I said low yield which they are or SN wouldn't be stuffing 272 seats in their A332's. |
Quoting airbazar (Reply 16): Well, even I was wrong. I took some time to research total African destination for each European *A carrier: TK 36 LH/LX 21 SN 19 TP 15 |
Quoting flyguy89 (Reply 17): True technically, but then you could get into that whole can-of-worms argument as to whether TK is really a European carrier or could Turkey be considered part of Europe. |
Quoting flyguy89 (Reply 17): If you're combining LH and LX and include North Africa, yes. But Brussels/Sabena's historical strength has always been in sub-Saharan Africa, the tricky area of Africa most carriers struggle with (except AF that is), and 18 of SN's 20 African destinations (I counted 20) are in sub-Saharan Africa. |
