Quoting tyler81190 (Reply 6): Quoting mayor (Reply 3):WHO is AS going to use to handle their flights in SLC, above and below wing. AS seems to have a thing for Menzies Aviation... |
Quoting a380787 (Reply 12): i see AS making a play against DL's MSP hub if the bloodbath continues |
Quoting tyler81190 (Reply 1): I see a second daily SEA-MCI or a PDX-MCI, their flights have a consistent load factor of 96%+ on their one daily flight. |
Quoting BoeingGuy (Reply 15): That's interesting. MCI and SAT would have been far down my guess list of next new AS cities, but obviously they know what they are doing. |
Quoting tyler81190 (Reply 17): AS is the only carrier to SEA out of MCI now that F9 has left the market. Their fares are relatively high, but they maintain an amazing load factor! I am surprised as well. Cargo was doing extremely well for them as well in the past year, not sure what their current numbers are. I think PDX or a second daily SEA would make sense out of MCI. |
Quoting rwsea (Reply 16): PDX-MSP |
Quoting SANFan (Reply 8): Since it was said in one of the last conference calls that we should not expect any mainline growth in 2014 |
Quoting ANA787 (Reply 11): PDX-DEN |
Quoting ANA787 (Reply 11): PDX-EWR |
Quoting tyler81190 (Reply 20): They would be relegated to the "North Terminal" which is not nearly as nice as the DL terminal. |
Quoting slcdeltarumd11 (Reply 14): SLC-FLL? FLL seems really crazy at first but it would be an easy fill even if its low yielding. Its guaranteed not to loose that much since they could fill the seats pretty easily. Guaranteed route to steal customers from Delta. The route might be better than we think maybe even a redeye? |
Quoting Noise (Reply 13): SAN-RDU |
Quoting redzeppelin (Reply 24): I could see SLC-ANC, SLC-MCO, and maybe a few routes to Mexico from SLC. Mexico routes less than daily. Can one plane operate ANC-SLC-MCO-SLC-ANC on a daily basis? |
Quoting flyenvi (Reply 29): Is the assumption around here that SLC will become AS's #3 hub? |
Quoting redzeppelin (Reply 30): |
Quoting flyenvi (Reply 29): Is the assumption around here that SLC will become AS's #3 hub? I really just don't see them adding SLC-East Coast flights. I think AS's expansion at SLC is perfect for what it is now, but I have a hard time believing it will become anything larger than that |
Quoting ERJ170 (Reply 31): RDU-SEA 221 daily pax at ~$620 IND-SEA 220 daily pax at ~$524 SAN-RDU 199 daily pax at $604 SAN-IND 286 daily pax at $445 SAN-STL 394 daily pax at $397 I would say if someone does RDU-SEA, they could do RDU-SAN.. iND May have more pax but RDU is going to give you higher yields... |
Quoting redzeppelin (Reply 30): I wouldn't go that far. Maybe I should have prefaced my posting with, "If AS adds anything else from SLC, this is what I see as most likely:" I don't have a good enough feel for the larger AS network to guess at what they might add in other places, and I honestly doubt that they will add much more from SLC. But as I've mentioned in other threads, I'd personally love to see them add a few SLC-Montana routes, though I doubt it will happen. |
Quoting ANA787 (Reply 11): PDX-YYC PDX-YEG PDX-DEN PDX-JNU PDX-EWR PDX-MSP PDX-MCO |
Quoting 787pdx (Reply 28): SEA-ABQ |
Quoting cjpmaestro (Reply 40): Agree. I can't see they will add more in SLC. If there is more expansion on DL's turf, I think they may look at LAX. AS already has a decent size presence there with plenty to of FF and maybe there are DL routes that they can tap into there |
Quoting tlecam (Reply 23): I expect Delta to add east coast cities and frequencies into the mix - RDU, BOS etc... |
Quoting SANFan (Reply 26): RDU-SEA? I don't follow those numbers but my guess would be that they are fairly similar to SAN-RDU with the added factor of connecting opportunities beyond SEA that AS offers |
Quoting flyenvi (Reply 29): I really just don't see them adding SLC-East Coast flights. |
Quoting flyenvi (Reply 29): think Alaska should be the bigger man and quit this pissy fight with Delta and just do what they do and let Delta do what they do whilst still maintaining a strong competitive presence at SEA. |
Quoting ERJ170 (Reply 31): I would say if someone does RDU-SEA, they could do RDU-SAN.. |
Quoting wedgetail737 (Reply 36): SAN-TUS |
Quoting SANFan (Reply 38): SAN could also be used for connections from North Carolina, to places like Hawaii, Mexico, and even some possibilities of intra-CA destinations (like FAT, MRY, ???) |
Quoting cjpmaestro (Reply 40): If there is more expansion on DL's turf, I think they may look at LAX. |
Quoting cjpmaestro (Reply 40): DEN is a big gap. |
Quoting cjpmaestro (Reply 40): SEA-CLT (for feed with the new AA) |
Quoting cjpmaestro (Reply 40): LAX-BZELAX-SJO |
Quoting wedgetail737 (Reply 36): I think there's still hope for SAN-KOA, but just not in Alaska's attention right now. Other routes I hope for are: SEA-MRY SAN-TUS SAN-DCA SJC/SFO/OAK-MMH STS-LAS |
Quoting SANFan (Reply 43): I think SAN-TUS would be a great add for AS, and a nice swing at WN to boot. WN runs, unopposed, 3 or even 4 daily 737s in the market. |
Quoting SANFan (Reply 43): There would be lots of connecting possibilities, including PDX, SEA, Hawaii, Mexico, |
Quoting PlanesNTrains (Reply 42): That is somewhat of an understatement. SEA connecting opportunities are more than "an added factor" - they are huge. |
Quoting tlecam (Reply 23): I suspect that Alaska's moves will be calibrated to what Delta does given that Delta announced 40 new flights and 10 new cities would be coming from SEA in the first 6 months of 2014. I expect Delta to add east coast cities and frequencies into the mix - RDU, BOS etc... |
Quoting PlanesNTrains (Reply 44): Personally, I'd pick TUS-SJC over TUS-SAN because it gives you Hawaii, the bay area, BOI, and SLC, and NO WN nonstop competition. |
Quoting PlanesNTrains (Reply 44): I'm not sure that sounds like a worthy battle to fight, but I'm not in route planning either. |
Quoting UA735WL (Reply 45): I think AS could make a go out of AUS-PDX. Their only competition is WN (seasonal) , and IMO there is room for another carrier on the route...especially with the brand loyalty AS has in the PNW. |
Quoting SANFan (Reply 38): I can't help but wonder where IND is on that list? |
Quoting wedgetail737 (Reply 48): Who would have thought OMA was in Alaska's sights? |
