stuckontarmac
Delta 757-300 Winglets
Mon Jan 20, 2014 10:42 pm
Greetings, Noticed a Delta 753 at SAT today with winglets, I heard that with the Pratt engines that the Winglet was not going to be installed on the Delta fleet. Is this the first aircraft to receive them and are they being installed here at SAT. Thanks guys
DualQual
RE: Delta 757-300 Winglets
Mon Jan 20, 2014 11:08 pm
Are you sure it was a -300? Several DL 757-200s have an exit door behind the wing in lieu of over wing exits. The ex TWA airplanes I believe. They also have winglets on them. With the door config they might look like a 300 at a glance.
MSPNWA
Mon Jan 20, 2014 11:23 pm
Quoting stuckontarmac (Thread starter):
Excellent! I hadn't been paying attention and didn't realize they were in for modification. I see now that N581NW and N582NW have been there a while, and I imagine it's N582NW, which has been there longer. the Winglets became part of the plan here recently for the 753 fleet.
FL787
Mon Jan 20, 2014 11:26 pm
Yes the first pair of 300s are in SAT for a new interior and winglets. About time too, the 300 I flew recently definitely looked tired on the inside.
Yflyer
Mon Jan 20, 2014 11:40 pm
I thought I'd read here that winglets weren't approved for the 753 and likely wouldn't be since there are relatively few of them making the cost of certifying them not worthwhile. Am I remembering wrong, or did that change recently?
srbmod
Mon Jan 20, 2014 11:50 pm
Quoting DualQual (Reply 1):
The exit doors aren't how you distinguish the 753 from a 752, the length of the fuselage is the easiest way to tell the difference. There's a reason why some people refer to the 753 as a "flying pencil" (although some refer to the 752 in that manner).
753:
Photo © Royal S King
752 (Ex-TWA):
Photo © Jacobus Saayman
On the 752 above, said exit is much closer to the wing than it is with the similar exit on a 753 (which also have overwing exits).
I guess DL figures that the costs to install and certify winglets on 16 a/c are worth it long-term.
AA737-823
Tue Jan 21, 2014 12:19 am
Quoting Yflyer (Reply 4):
United's entire fleet has had them for years, but NW/DL was the only 753 customer with Pratt engines, which weren't included in the certification. Looks like it's taken place now!
FlyASAGuy2005
Tue Jan 21, 2014 2:44 am
A very tired line that i've been saying for over a year doesn't matter. Because there was currently no certification didn't mean there wouldn't be one eventaully. Delta paid for the STC quite a while ago. All 753s will get their winglets as they go in for interior mods. The entire fleet should be done by early 2015.
DocLightning
Tue Jan 21, 2014 2:54 am
It was lower priority. The majority of 757s in the world have RR engines and this is also true of the 753. The only PW 753s ever built were for NW. That said, my understanding is that once certification is done on the RR model, the PW certification process becomes easier because the differences are so minimal.
The 753s are relatively recent aircraft and DL's business model is to keep their aircraft as long as possible, so it makes sense to add the winglets. When you have decided to operate an older fleet, anything you can do to mitigate fuel costs is probably worth it.
MesaFlyGuy
Tue Jan 21, 2014 4:12 am
I think the flying pencils will look outstanding with the winglets. Every other Boeing that has had winglets added has looked better than it did before so I can't imagine these will be the exception! (The a32X sharklets look weird, ESPECIALLY the a319s, but I'll probably get used to them.)
MaverickM11
Tue Jan 21, 2014 4:23 am
Quoting FlyASAGuy2005 (Reply 7):
I'm surprised it wasn't done earlier as DL flies them on relatively long transcons and to Hawaii, where the winglets make a lot of sense.
CO777DAL
Tue Jan 21, 2014 5:43 am
The 757-300 have had winglets for a good five years now going all the way back to Continental in 2009.
Photo © Duy Tran Duc
Photo © Kevin Boydston
FlyASAGuy2005
Tue Jan 21, 2014 1:20 pm
Quoting MaverickM11 (Reply 10):
They're doing them as they go in for a specific check. And they were waiting for more money   2014 is now here. All 757s that they intend on keeping will get winglets. A good portion already have them but there were many that never got them (being flown to the desert) and others had to wait. The focus was on the international fleet.
georgiaame
Tue Jan 21, 2014 4:03 pm
What sort of range increase does the 753 get with winglets compared to the basic version? How does that compare to a 752 with or without winglets?
simairlinenet
Tue Jan 21, 2014 4:10 pm
We had kicked around the business case for many years but kept deferring it. In addition to the aforementioned certification costs that were always mentioned, I suspect the high opportunity cost of keeping the planes out of service was also a factor.
MIflyer12
Tue Jan 21, 2014 6:59 pm
Quoting simairlinenet (Reply 14):
Cost of capital is lower than it used to be but fuel cost is trending very slightly lower, too, over the last thirty months. MaverickM11 may have been on to it with increasing stage length. The 753s used to be the queens of Walt Disney World -- and still make more than a few less-than-1000-mile DTW-MCO runs.
DTWPurserBoy
Tue Jan 21, 2014 7:23 pm
Quoting srbmod (Reply 5):
That is among the kinder nicknames for the 753. From the flight attendant's standpoint the only one printable in polite company is "Satan's Bowling Alley." Just flew one last week from FLL to ATL. Packed to the walls the carryon luggage situation in the aft cabin bordered on anarchy as the bins filled up. One poor flight attendant was tearing up as passengers reamed her out because the bins were full.
smittyone
Tue Jan 21, 2014 9:59 pm
Quoting DocLightning (Reply 8):
Moreso even with the 753 (70/30 split in favor of RR)...overall RR's advantage was only 60/40.
80% of operators chose RR but the ones that went PW bought a ton of them
/Cliff Clavin
Quoting DTWPurserBoy (Reply 16):
This (among other reasons) is why I couldn't be a flight attendant. If people didn't bring everything they own into the pax cabin with them like a bunch of hillbillies it wouldn't be a problem. I'm figuring I'd quickly get fired for telling somebody to walk if they don't like it, if I didn't go down the escape slide with beer x 2 first.
[Edited 2014-01-21 14:05:27]
SXDFC
Tue Jan 21, 2014 10:00 pm
Can anyone provide any pictures?
studedave
Wed Jan 22, 2014 1:42 am
Dumb question time...
Why does it matter which powerplant is hanging on the wing as it relates to 'certification' for winglets?
Side question- how did it work when Boeing (and others?) did the SUD modification on the 747s?
StudeDave
smittyone
Wed Jan 22, 2014 1:54 am
Quoting STUDEDAVE (Reply 19):
I'm not an aeronautical expert, but my guess is that the airflow around and through the nacelles 'matters' in terms of the potential for flutter etc. So the different shape of the PW vs. RR might interact with the airflow around the winglets in a negative way?
Personally I'm excited to see this...tells me that Delta is committed to running those sleek birds for a long time...
Raventech
Wed Jan 22, 2014 2:01 am
It is because it is a different model (effectively) of airplane so in theory there should be no difference but because they did not test that model, it cannot be added to the STC. Though I imagine the fact it shouldn't be different between engines means testing is more/less just confirming what we already know and would be easy (you just got to spend the money to add it)
studedave
Sat Jan 25, 2014 8:15 pm
Thanks for the answers folks.
StudeDave
questions
Sun Jan 26, 2014 5:51 am
Has carryon entitlement become worse since DL introduced fees for checked luggage?
CV880
Sun Jan 26, 2014 6:53 am
Quoting FlyASAGuy2005 (Reply 12):
#5801 now has winglets.
DocLightning
Sun Jan 26, 2014 7:29 am
Quoting SmittyOne (Reply 17):
Who ordered PW? DL, NW, EA, and UA, right? Was that it?
ha763
Sun Jan 26, 2014 8:39 am
Quoting DocLightning (Reply 25):
EA's 757s had RR engines. Below is the delivery list of 757s with PW engines from Boeing's website:
Condor - 17
Delta - 116
Ethiopian - 5
FAT - 7
Northwest - 72
RAM - 2
Shanghai - 13
Singapore - 4
TWA - 14
United - 98
UPS - 35
Uzbekistan - 3
USAF - 4
Mid East Jet - 1
ILFC - 38
AWAS - 3
Total - 432 of 1049
MIflyer12
Sun Jan 26, 2014 3:43 pm
Quoting questions (Reply 23):
IIRC, AA in May 2008 was the first of the U.S. legacy carriers to charge for the first checked bag, and carryon entitlement has gotten worse everywhere since then.
n7371f
Thu Jan 30, 2014 2:13 am
There will be some FAA work involved with these reconfigured 757-300's.
The traditional exit rows are gone - replaced by the same design on the 737-900ER (i.e. there is no exit row leg room anymore). Also there is AVOD at every seat and that requires an additional FAA certification since it's on a new type.
The new 753's are now 75Y in the system. Seating is F24PY26Y184. An increase of 10 seats.
Closet and galley between doors 1L and 1R and first class cabin are gone. Closet moved to rear of 6AB. Galley at 2R is gone completely.
srbmod
Thu Jan 30, 2014 2:31 am
Quoting n7371f (Reply 28):
I can't complain about three more really great legroom Economy Comfort seats on the 753.....
I'm sure the F/As are going to love losing that galley.....
PSU.DTW.SCE
Thu Jan 30, 2014 3:17 am
srbmod
Thu Jan 30, 2014 3:34 am
Quoting PSU.DTW.SCE (Reply 30):
New seat map is on the website:
http://www.delta.com/content/www/en_....html
Interesting how they swapped what side Row 14 is on. In the current setup, they are right across from the jumpseats. I guess that will potentially speed things up with boarding since passengers waiting tend to bunch up right in front of the current Row 14.
b727fa
Thu Jan 30, 2014 4:33 pm
I'm confused...I still see a galley at 1R and 2R.
Prost
Thu Jan 30, 2014 4:42 pm
The galley at 1 right used to be on both fore and aft of the door, amd the 'galley' at door 2 right must be a small auxiliary galley, as it is forward of the lav. Probably a trash cart amd a couple of drawers of soda, i don't know, I haven't been on this plane yet.
AirplaneFan
Thu Jan 30, 2014 10:31 pm
Quoting SXDFC (Reply 18):
Credit to Sara G
Rgds, John Anderson
MesaFlyGuy
Thu Jan 30, 2014 10:50 pm
Quoting AirplaneFan (Reply 34):
Loooooookin' good!
I think the flying pencil is one of the coolest planes in the world and, at least with Boeing, winglets seem to make everything prettier
b727fa
Thu Jan 30, 2014 11:30 pm
Ok. So they're taking out the wet galley at 2R I'd guess and making it dry. It wasn't very well laid out anyway. The 1R galley will prob have the same thing. We're not using it on long enough hauls to need all that. It's the incredibly shrinking work space that does get tiring, though.
TW870
Fri Jan 31, 2014 4:06 am
Quoting B727FA (Reply 36):
No kidding. They still run this airplane on a lot of flights with a hot first class meal. So now you will just have a plastic wall behind you when you are in the first class galley and facing forward? And so much less cart space, too. When I flew for United (in the 90s and early 2000s), people complained that our 757s were so much worse than the original layout on the Eastern airplanes, where the coach flight attendants did the service from the full mid- and aft- galleys (2 flight attendants worked out of each). I used to work the 757 on transcons all the time, and thought there was never enough tray setup space. But I can't imagine if they took the unit behind 1R out. Yikes!
Prost
Fri Jan 31, 2014 4:38 am
Flight Attendants are a crafty lot. We'll b!tch about it for a rew months, but we'll make it work. We always do.
questions
Fri Jan 31, 2014 5:51 am
http://www.delta.com/content/www/en_...t/Aircraft/boeing-757-300-75y.html
Economy Comfort
26 Seats
17.2 in/ 34 in
(44cm/86cm)
Don't you love how the old standard seat pitch, 34 inches, is now "Economy Comfort" and sold at a premium?
First Class
24 Seats
21 in/ 37 in
(53cm/94cm)
How does Delta plan to capture a larger share of HVC's with the tightest First among it's US domestic competitors and questionable catering? (Granted, DL's crews are the best)
laca773
Fri Jan 31, 2014 8:35 am
It does appear their is exit row leg room at row 40. They can't put a plug there do to the configuration, and capacity of the 753 (75Y)
Quoting questions (Reply 39):
UA's isn't much better what so ever! DL has been trying to improve their domestic first catering, and it definitely needed it!. In fact, I feel DL has better domestic F catering now compared to the slop UA serves in F. Too bad Smisek didn't keep the CO catering and instead opted for the UA slop.
LAX/SEA-HNL/OGG/KOA are good routes for the 753s as well as the longer midcon flights that could use 763s but not available. LAX/SFO/SEA/PHX/LAS-MSP/DTW/ATL.
I can see why DL sends them to Florida a lot. They use to do a lot of L10/762/763s from ATL, instead of parking a/c that were during Trans-Atlantic flights in the evening, they were able to do quick turns during the day.
I can only imagine how they are to work, espcially since they are narrowbodies.
Hats off to DL FAs for the hard work they do, and all the garbage they put up with rude passengers, demands, carry-ons.....
SXDFC
Fri Jan 31, 2014 5:49 pm
Not a bad looking 757! Although I must say the 757 would have looked even more awesome with raked wingtips!
Quoting laca773 (Reply 40):
I am sure glad all the rude pax just stick to DL! I don't know what I'd do if I had to deal with one at WN
SDFDL2MM
Fri Jan 31, 2014 6:08 pm
The DL FA's do an amazing job, are friendly, and very willing to go above and beyond. It amazes me how many of them read the manifest and make a point to say hello to Diamond and X-MM passengers.
The 753 is a very neat and unique aircraft. You see them all the time taking families to MCO. I look forward to seeing this bird in action.
MIflyer12
Fri Jan 31, 2014 6:43 pm
Economy Comfort
26 Seats
17.2 in/ 34 in
(44cm/86cm)
When was 34" standard coach seat pitch on U.S. carriers' domestic flights? Pre-1978?
Prost
Fri Jan 31, 2014 7:33 pm
Regarding the seating, catering, reduced comfort levels, etc. With economy comfort, you can buy up to have a similar experience seat wise similar towhat economy was like 30 years ago, and it is still cheaper. The economy cabin seating reflects what we pay for our tickets.
I consider the economy class seating to yogurt cups. Twenty years ago, a cup of yogurt was 8 ounces, now it is 5.3 ounces.
klkla
Fri Jan 31, 2014 9:42 pm
Have you flown any other U.S. carriers domestically? Delta far surpasses UA in catering and although they serve chilled meals on some shorter flights than AA the quality and service is better.
