Quoting OldAeroGuy (Reply 43): Huh? 777X design work began in 2010 with customer visits the same year. |
Quoting Stitch (Reply 40): It not only ended Boeing's dominance in the VLA market, but effectively knocked them completely out of it. And as I am very confident that each of those 300+ A380-800 sales would have instead been a 747 or a 777, Airbus successfully denied Boeing tens of billions in potential revenues.They also forced Boeing to spend billions of dollars and significant engineering resources on a failed response - first Sonic Cruise and then the 747-8 - when that money and time could instead have been applied to the NSA (Y1) and NLA (Y3), putting Boeing in a stronger competitive position against the A320neo and A350 then they are now with the 737 MAX and 777X.So yes, I think it really did help Airbus. |
Quoting astuteman (Reply 51): One would expect it lasted longer than 5 minutes, OldAeroGuy......... |
Quoting JerseyFlyer (Reply 18): FWIW all I expect is a simple stretch of the 3510 initially and, if that works, a follow-on LR version, like Boeing did with the 773 and later the 773ER, |
Quoting ER757 (Reply 55): The -1000 is already a stretch of the base model, going further starts to impinge on the outer portion of the envelope for the type. It's been noted on this forum many times by others wiser than I that you start to run into problems when you try to cover too much ground with a single aircraft family. |
Quoting astuteman (Reply 51): Quoting OldAeroGuy (Reply 43):Huh? 777X design work began in 2010 with customer visits the same year. The NLR project came to an end in 2012. One would expect it lasted longer than 5 minutes, OldAeroGuy......... |
Quoting OldAeroGuy (Reply 58): It seems that at least some of the 777X and the NLR design investigations were being done concurrently. |
Quoting KarelXWB (Reply 59): I believe the point here is that this case study is not a "marketing ploy" as suggested in reply #8. |
Quoting astuteman (Reply 61): Quoting OldAeroGuy (Reply 58):It seems that at least some of the 777X and the NLR design investigations were being done concurrently. Which nicely demonstrates the point that I was making - that this isn't a marketing ploy. Quoting KarelXWB (Reply 59):I believe the point here is that this case study is not a "marketing ploy" as suggested in reply #8. It was. |
Quoting CiC (Reply 60): |
Quoting airbazar (Reply 47): That all depends on how you measure a VLA. |
Quoting william (Reply 53): Help to Airbus is based on Airbus making a profit, and nowhere did you state profit in your post. |
Quoting william (Reply 53): I hope Airbus does not make descisions based on things out of their control such as, "what a competitor may or may not do". |
Quoting Ruscoe (Reply 33): I admit to not knowing how difficult that would be, but it can't be a big challenge because Boeing did offer a wider 737 fuselage to Southwest, and also was forced to widen the fuselage of the original 707 concept. |
Quoting tortugamon (Reply 45): Quoting Stitch (Reply 40): So yes, I think it really did help Airbus. I would be comfortable saying that it hurt them less than not doing it would have. I am still on the fence in terms of how much it may have helped. I am optimistic about the future but up to this point it can't be viewed as a great success....yet. |
Quoting SEPilot (Reply 66): I think they could have found a project that would have helped the company, not just one that "hurt them less" than not doing it. |
Quoting EPA001 (Reply 56): Tell that to Boeing who are double stretching the B777 and are making the fuselage thinner to create more interior space. |
Quoting tortugamon (Reply 67): I never understood the logic on the limitations of stretches. |
Quoting NAV20 (Reply 69): As I understand it, tortugamon, the problem is that any stretch inevitably adds weight and increases wing loading - thus reducing performance. |
Quoting tortugamon (Reply 70): Its having a redesign with a new wing and that is why I don't discount the concept of a 777-10 simple stretch if the market warrants it. |
Quoting tortugamon (Reply 70): Agreed and that is why when people say that the 779 is a double stretch I scratch my head. Its having a redesign with a new wing |
Quoting Stitch (Reply 71): I'm guessing - hoping, really - that the 777-9 is 76.5m in length because that is the limit it could be stretched (I'm guessing for tail-strike / rotation angle reasons) as, IMO, it should have been 79m long if that was possible / practical. |
Quoting Nav20 (Reply 2): It's pretty clear that Boeing are planning thinner fuselage linings for the 777Xs, so that they can if necessary accommodate 10-across seating. |
Quoting jayunited (Reply 49): I believe that Airbus has made a mistake as well because although the A35J is better than the current 773ER it is not better the the future Boeing 777x. |
Quoting tortugamon (Reply 67): The 737 has been stretched 7 times since the 737-100 |
Quoting Stitch (Reply 65): I measure it the way Boeing and Airbus measure it - "747 sized and larger". For sake of argument, let us say larger than 400 seats in a three-class OEM configuration, which would include the 747-400 (416 seats), 747-8 (467 seats) and A380-800 (525 seats). |
Quoting tortugamon (Reply 74): I think Boeing wants to appeal to all 773/77W/A346 operators with the 779 and I don't think a high percentage of 9-abreast 77W operators and A346 operators can handle the jump from 365/380 seats to ~437 seats even if the economics are better. |
Quoting airbazar (Reply 80): Personally I would listen to the airlines more than B&A's marketing and put the 77W in the VLA segment and with that picture I wouldn't say that Boeing has lost the VLA market. |
Quoting Stitch (Reply 81): All Nippon Airways, for example, configures some of their 777-300ERs with 213 seats. |
Quoting tortugamon (Reply 77): block fuel burn should be about 90t (vs 84t on a 779) for about ~460 seats compared to an A380 with 525 seats burning 150t. This hypothetical 777-10 would then burn 18%+ less fuel per sq m of cabin floor space per km than an A388 with ~50% more cargo volume. |
Quoting Stitch (Reply 81): I see the 777-8 as being aimed at 9-abreast 777-300ER operators |
Quoting Stitch (Reply 81): I do not believe the 2.5m stretch is sufficient to attract 9-abreast 777-300ER operators away from the A350-1000. That would need the full 6m (of a 79.5m stretch) to provide a sufficient capacity gain, IMO. |
Quoting tortugamon (Reply 83): But I don't see that as very realistic. Your average 9-abreast operator is not looking for the 9knm aircraft so they will be looking at the -9. |
Quoting tortugamon (Reply 83): I think it is sufficient if they are willing to make the change to 10-abreast which I see many doing. |
Quoting tortugamon (Reply 13): I think this is another important sentence from the article: "An NLR project would also likely end any A380 reengining effort, which is seen internally as extremely challenging in terms of engine/wing integration and aerodynamics." I wonder if this is because likely engine replacements are bigger and therefore more difficult to incorporate? |
Quoting EPA001 (Reply 56): Tell that to Boeing who are double stretching the B777 and are making the fuselage thinner to create more interior space. And that is the same company where they are going from the B787-8, via the -9 to the -10. It is a double stretch too though it could be argued that the B787-9 is the baseline model, which I do not really believe since so much redesign has gone into the B787-9. |
Quoting Ab345 (Reply 62): One company fills the gaps the other leaves in order to secure the money and the market share. |
Quoting mjoelnir (Reply 48): Why should Airbus spend billions to "kill" a competition? |
Quoting OldAeroGuy (Reply 63): The only way we'll know that it isn't a marketing ploy at this stage is if Airbus tenders it to the customers |
Quoting Revelation (Reply 85): but perhaps the data they gathered showed the mating was not very good. |
Quoting 2707200X (Reply 86): I wonder of when Airbus will release the visual concept of the mega-twin as we know from the article that the MTOW is just shy of 892,000 lbs. |
Quoting racercoup (Reply 87): Airbus spent many billions just to beat out the 747. |
Quoting 2707200X (Reply 86): we know from the article that the MTOW is just shy of 892,000 lbs. |
Quoting racercoup (Reply 87): Boeing will eventually have a 400 frame lead they will probably never lose. |
Quoting NAV20 (Reply 90): that strongly suggests that Airbus intends to 'do the right thing' - go for a bigger twin-engined 'flagship' and keep the lead in terms of aeroplane size. |
Quoting NAV20 (Reply 90): Which strongly suggests that Airbus already realises that increased engine power, allowing over-400-seat 'big twins,' is likely to 'obsolete' not just the B748 (except maybe freighter versions), but also the A380. |
Quoting Revelation (Reply 85): but perhaps the data they gathered showed the mating was not very good. That's another complication of the four engine a/c, any mistake you make in this space gets multiplied x4 instead of x2. |
Quoting Stitch (Reply 84): |
Quoting Revelation (Reply 85): |
Quoting racercoup (Reply 87): |
Quoting NAV20 (Reply 90): |
Quoting PHX787 (Reply 94): No matter how much capacity you make it, and no matter if it is a twin or not, nothing over 400 seats will sell anymore. |
Quoting PHX787 (Reply 94): It simply cannot make money for the airline. |
Quoting astuteman (Reply 52): Net A350-1000 sales last year were 59. 777-300ER sales were 45. |
Quoting Stitch (Reply 84): Of course, Boeing does not require customers to purchase the 777-8 at the maximum certified operating weights... |
Quoting racercoup (Reply 87): Which not only has does nothing but cost them money but put them (4) years behind Boeing in the 787/350 battle. |
Quoting N14AZ (Reply 95): You know that this is not correct and I really wonder why you posted it (I usually read your contributions with attention). So you have knowledge that airlines such as SQ, LH, BA, KA, EK etc are loosing money with their 748i's and 380's? |
Quoting N14AZ (Reply 95): So no more sales for the 779? |
