Quoting tonytifao (Reply 150): How is the location of the crash identified? Beacon data or actual visual sing of debris? |
I believe it was reported as radar data from a military base.
Quoting PITrules (Reply 71): Quoting kiwiinoz,previous thread: I don't know why people get upset about all the speculation. This is a site of aviation enthusiasts. We are not CNN. We are not accountable to fact check everything we say.i think it is perfectly normal for a group like this to bounce around all sorts of theories, (as enthusiasts on any topic would do) The thing is, right or wrong this website has actually become a pretty common 'go-to' source for the media when events like this first break. For that reason I think we should do without the wild theories and keep things within educated analysis. At least for the first few hours or days of the event. |
Quoting holzmann (Reply 84): Quoting SQ452 (Reply 83): This is starting to feel eerily reminiscent of the AF447 crash off Brazil. Hoping for the best and a positive outcome but it is unfortunately not looking good right now. Yes but AF447 flew into one heck of a storm. I think the weather at least appeared clear in this case. |
Quoting 757223 (Reply 88): It looks to me as if the reported location is in the vicinity of where FlightRadar24 stopped showing a return. Since this type of website uses ACARS data (I believe), having something there one minute and then gone the next leads me to believe that something sudden and drastic happened to stop the data from transmitting. |
Quoting dirktraveller (Reply 90): Taking into account that statement by the Vietnamese navy is correct, who would be leading the investigation into this accident? Will it be the Vietnamese or Malaysian aviation safety organisation? I would presume that Boeing and NTSB will assist the investigation process since it involved a boeing-made airframe, and I'm not sure if the Chinese would be participating since the most passengers on board were Chinese nationals? |
Quoting holzmann (Reply 103): So what is the status of this AC pitot tubes being heated? These had not been installed on AF447. |
Quoting KFlyer (Reply 147): Do we have really clarified the location where the a/c went missing? As per FR24 data, this would be around 40 mins from KUL, likely somewhere near waypoint IGARI. But multiple news reports indicate this was two hours away from KUL. |
Quoting SQ452 (Reply 149): The parallel I drew with AF447 was that this flight just 'vanished' mid-flight; we of course won't know the reasons for MH370 disappearing for some time I'd imagine (search and rescue, recovery and investigation will all take time), but the question I have is has there been any instances where the Pitot heating system failed on Boeing aircraft and in particular the 777? |
Quoting SQ452 (Reply 149): This plane has a truly remarkable safety record when you think about it; it has been in service for 20 or so years and only suffered 3 hull losses before this incident, and only 3 fatalities associated with any incidents before today. Something must have gone terribly wrong enroute and we can all only speculate at this point. |
Quoting SQ452 (Reply 149): we of course won't know the reasons for MH370 disappearing for some time I'd imagine (search and rescue, recovery and investigation will all take time) |
Quoting KFlyer (Reply 146): Do we have really clarified the location where the a/c went missing? As per FR24 data, this would be around 40 mins from KUL, likely somewhere near waypoint IGARI. But multiple news reports indicate this was two hours away from KUL. |
Quoting KFlyer (Reply 147): Do we have really clarified the location where the a/c went missing? |
Live: @HishammuddinH2O on #MH370 Incident - confirms the Malaysia has activated all its agencies to work together on the S&R rescue mission
— Malaysia Airports (@MY_Airports) MY_Airports/statuses/442185500636348416">March 8, 2014
Quoting laxboeingman (Reply 157): Do we know if the e/q squawked something unusual? |
Quoting flood (Reply 158): A lot of conflicting reports, but the last transponder position as reported by FR24 (pin) is only roughly 60 miles (yellow line) from the location as reported by the Vietnamese Navy (according to Yahoo) 153 miles south of Phu Quoc (red line) |
Quoting laxboeingman (Reply 159): I certainly hope the black boxes are easier to find than AF447 |
Quoting Bruce (Reply 160): I certainly hope the black boxes are easier to find than AF447. |
Quoting ryu2 (Reply 169): Subang (guessing they mean Lumpur) |
Quoting ryu2 (Reply 169): If they had crashed at the point that FR24 or the place that Vietnamese navy was reporting (around waypoints IGARI or BITOD), then that should have been no more than 45 minutes flight time from KUL. |
Quoting DIRECTFLT (Reply 175): |
Quoting airportugal310 (Reply 176): It doesn't seem to work on my iPad. What is the depth in and around the area that we are talking about? |
Quoting Starlionblue (Reply 173): Flights can spend a lot of time getting "on course" while climbing out due to winds and traffic patterns. |
Quoting poolkeeper (Reply 174): The "black box" should also transmit a radio signal which has limited reach under water but if they get close, they will find it fast. |
Quoting laxboeingman (Reply 153): Do you think the e/q just - literally - dropped or do you think it would have slowed down while moving forward, like a normal landing, but because of the force of impact, it crashed into the ocean? |
Quoting laxboeingman (Reply 153): Will the black boxes even be found, so we can know what happened? If they are not found, we will never know. |
Quoting Starlionblue (Reply 154): Pitot systems do fail from time to time but two things are worth remembering in context: - There are at least three independent air data systems on large airliners. The likelihood of them all failing is infinitesimal. - Even without valid speed data, AF447 would have landed safely if the pilots had followed the checklist written for just such a situation. The pitots were out for less than a minute. In fact, dozens of A330 flights had had similar problems and landed safely. To quote SlamClick: Basic pitch and power, how many times does it have to save your life before you value it? |
Quoting Bruce (Reply 160): I realize its speculation but I'm going to put this out there. I think it was sabotage. The plane simply vanished during a level and routine part of the flight in fairly calm airspace. Also keep in mind the ETOPS system redundancy, if they had an engine or electric bus go out they would not have vanished. The 777 is a good plane. I can't think of any other reason the ELT beacon would not have gone off other than it was suddenly and violently ripped apart. |
Quoting Starlionblue (Reply 173): I'm pretty sure it is Subang Control Area. |
Quoting UA787DEN (Reply 171): MAS said in their most recent conference that the site of lost contact is near the one given by flightradar24. So...if you discount the whole 2 hour number it works. |
Quoting NZ747 (Reply 184): Very sad news. It does seem the search and rescue effort took a long time to initiate. Seems like MAS were planning for the best and not the worse, relying on unconfirmed reports the aircraft went to Nanming rather that putting together a swift search. If I had hundreds or aircraft at my disposal I would have at least sent some to the last known location and track to look. |
Quoting 7BOEING7 (Reply 178): Quoting Starlionblue (Reply 173): Flights can spend a lot of time getting "on course" while climbing out due to winds and traffic patterns. Define "a lot", shouldn't be more than 10 minutes in the worst case. Flight profile to altitude/position is very similar to prior flights. |
Quoting zeke (Reply 181): Quoting Starlionblue (Reply 173): I'm pretty sure it is Subang Control Area. KL radar control to Singapore radar, Singapore area, then Vietnam. |
Quoting vegas005 (Reply 187): feels very frustrating that the incorrect reports of lost contact after 2 hours has made that Flightradar24 data of lost contact after 40 minutes, has been ignored for so many hours. |
Quoting fiscal (Reply 188): Quoting trex8 (Reply 179): or another MH 124 flight control anomaly Wasn't that due to some tape over the pitot? If I remember Perth Control assisted them to land safely back in Perth. |
Quoting fiscal (Reply 188): Quoting trex8 (Reply 179): or another MH 124 flight control anomaly Wasn't that due to some tape over the pitot? |
Quoting trex8 (Reply 189): Plus the SAR capabilities of the relevant authorities are not exactly what one may characterize as the most robust in the world. Though they are also not close to non existent as in some other parts if the world! |
Quoting LO231 (Reply 197): OMG, I didnt read previous posts, hope they are ok and well... |
Quoting pilotaydin (Reply 196): I wrote my thesis on automation learning methods and failure training...many cases show a clash between what is practiced versus what happens |
