Quoting LTC8K6 (Reply 50): When you look at the other flights, we only have data loss over China. Are these tracks accurate, or have they simply been assumed? |
Quoting holzmann (Reply 51): Let's assume the first rule of a hijacking is to turn off the transponder. You could still see the AC on radar but it would not be immediately identifiable, right? What kind of flight radius would the AC have had with its last known position and fuel capacity? And what airports within that radius would have a long enough runway? |
Quoting tonytifao (Reply 54): What countries have started the search? |
Quoting Starlionblue (Reply 53): |
Quoting nutsaboutplanes (Reply 59): Quoting Starlionblue (Reply 53): Watching the play-back and seeing the return for 370 disappear is heartbreaking. |
Quoting Starlionblue (Reply 53): Other flights where? |
Quoting holzmann (Reply 51): Let's assume the first rule of a hijacking is to turn off the transponder. You could still see the AC on radar but it would not be immediately identifiable, right? |
Quoting Starlionblue (Reply 57): |
Quoting LTC8K6 (Reply 61): Quoting Starlionblue (Reply 53): Other flights where? The previous Malaysian flights on the route. Their tracks are uninterrupted until they reach China. I was wondering about the difference with this flight, which seems to lose data over Malaysia, whereas all the previous flights appear to at least reach China. |
Quoting flymia (Reply 62): Quoting holzmann (Reply 51): Let's assume the first rule of a hijacking is to turn off the transponder. You could still see the AC on radar but it would not be immediately identifiable, right? It is not easy. During 9/11 they had a very hard time finding some of the airplanes high jacked which transponders were turned off. |
Quoting Starlionblue (Reply 60): Unfortunately I can't get it to slow from 12x |
Quoting holzmann (Reply 63): Thanks. If we assume from the FlightAware map that signal was lost around coordinates 5°32'07.2"N 102°11'39.3"E and we assume the 5000km radius, then we have a map like this... |
Quoting kiwiinoz,previous thread: I don't know why people get upset about all the speculation. This is a site of aviation enthusiasts. We are not CNN. We are not accountable to fact check everything we say.i think it is perfectly normal for a group like this to bounce around all sorts of theories, (as enthusiasts on any topic would do) |
Quote: UPDATE [12:37]: Tuoi Tre, a leading daily in Vietnam, reports that the Vietnamese Navy has confirmed the plane crashed into the ocean. According to Navy Admiral Ngo Van Phat, Commander of the Region 5, military radar recorded that the plane crashed into the sea at a location 153 miles South of Phu Quoc island. |
Quoting spacecadet (Reply 31): And now other people are saying this incident reminds them of AF447... both theories are statistically likely to be wrong. |
Quoting Miami (Reply 42): Signal of the 777 with 227 passengers and 12 crew members on board has been detected at some 120 nautical miles southwest of Vietnam's southernmost Ca Mau province. |
Quoting zeke (Reply 14): Normally heading out of KL on that route you are kept low as the outbound track crosses the busy Singapore inbound routes and the Bangkok Singapore route. You go from KL control to a Singapore radar on VHF, them as you get further out transfer to Singapore on datalink. Then transfer to Vietnam on datalink, often after transfer from Singapore to Vietnam you are initially out of VHF range. They should have a good idea of the location. |
Quoting SQ452 (Reply 83): This is starting to feel eerily reminiscent of the AF447 crash off Brazil. Hoping for the best and a positive outcome but it is unfortunately not looking good right now. |
Quoting manny (Reply 72): The Vietnamese Navy has, sadly, confirmed that the plane crashed into the ocean. |
Quoting holzmann (Reply 84): Yes but AF447 flew into one heck of a storm. |
Quoting damirc (Reply 85): Odd. The point 153 miles south of Pho Quoc is 360 miles from KUL. 2 hours flight time does not really fit ... |
Quoting BoeingVista (Reply 91): Not really no. |
Quoting BoeingVista (Reply 91): Quoting damirc (Reply 85):Odd. The point 153 miles south of Pho Quoc is 360 miles from KUL. 2 hours flight time does not really fit ... Yup, this does not fot the information already released. |
Quoting LTC8K6 (Reply 81): northwest off the country’s southernmost Cape Ca Mau |
Quoting LTC8K6 (Reply 81): According to a High Command of Navy statement, the plane went down at the waters between Vietnam and Malaysia, some 153 nautical miles (300km) off Tho Chu Island in Kien Giang Province. |
