Quoting kmot (Reply 43): These threads are moving so quickly. Can someone give an updated with what we know... what we think... and so on? |
Check the thread starter there's a summary
Quoting flyenthu (Reply 52): didn't the WSJ report establish the ACARS (data transmission) was shutdown at 1:07am |
Quoting LTC8K6 (Reply 45): What does "Chinese" have to do with anything? |
Quoting flyenthu (Reply 52): What?!? Unless I missed something, didn't the WSJ report establish the ACARS (data transmission) was shutdown at 1:07am and then 14 mins later the transponder at 1:21am? |
Quoting davidzill (Reply 53): Runway 29, IXC, the aircraft was on a course to intercept a final approach course for the runway |
Quoting tomlee (Reply 30): Technically the spot beams overlap and if you look at the signal strengths of multiple fixed beams you could narrow down the position with just one sat. (Sounds sort of like triangulation but I don't know if that is possible or not) |
Quoting davidzill (Reply 61): The aircraft is at the bottom of the sea, no one has any idea where to look, black boxes will stop transmitting after a month, and it will take YEARS to find it, if we ever do. |
Quoting RJAF (Reply 32): It would be great to know how much SAR capabilities have advanced (mainly in terms of high tech etc..)since the AF447 loss in 2009? |
Quoting davidzill (Reply 53): Runway 29, IXC, the aircraft was on a course to intercept a final approach course for the runway. The airport does not have published procedures, and is probably a day/VFR field, and it has refueling capabilities (80, Jet A, 100). I'm sure it has been checked out already. |
Quoting huxrules (Reply 63): Looking at that runway at IXC. It's plenty long you could land a 777 there do a hot fuel up and take off again without getting near the terminals. You would need help of course. Of course there is the noise and the impossibility of it all. And if that doesn't sound like a Clancy book you would be right - I think Dan Brown had a B-52 steal kerosene from the Russians in one of his books! Oh and it thought of a way you could tell if a 777 landed there- just measure the width of the skid marks. |
Quote: SEPANG, Malaysia — Malaysia Airlines Flight 370 experienced significant changes in altitude after it lost contact with ground control, and altered its course more than once as if still under the command of a pilot, American officials and others familiar with the investigation said Friday. Radar signals recorded by the Malaysian military appear to show the missing airliner climbing to 45,000 feet, above the approved altitude limit for a Boeing 777-200, soon after it disappeared from civilian radar and made a sharp turn to the west, according to a preliminary assessment by a person familiar with the data. The radar track, which the Malaysian government has not released but says it has provided to the United States and China, then shows the plane descending unevenly to an altitude of 23,000 feet, below normal cruising levels, as it approached the densely populated island of Penang, one of the country’s largest. There, the plane turned from a southwest-bound course, climbed to a higher altitude and flew northwest over the Strait of Malacca toward the Indian Ocean. Investigators have also examined data transmitted from the plane’s Rolls-Royce engines that shows it descending 40,000 feet in the space of a minute, according to a senior American official briefed on the investigation. But investigators do not believe the readings are accurate because the aircraft would likely haven taken longer to fall such a distance. “A lot of stock cannot be put in the altitude data” sent from the engines, one official said. “A lot of this doesn’t make sense.” |
Quoting hamiltondaniel (Reply 59): According to Malaysian military radar (presumably now interpreted by the US and China), just after the transponder disappeared the aircraft apparently climbed to 45,000 ft while banking to the west, then lost altitude and crossed the peninsula erratically at 23,000, then regained altitude as it went out over the Indian Ocean. Whatttttt...... |
Quoting BackSeater (Reply 101): Primary radar pings west of Malaysia with no transponder response make total sense. The plane is flying like a commercial airliner over standard routes but with a failed transponder. ATC does not see it, military probably think it is a civilian aircraft with a problem and ignore it. |
Quoting spacecadet (Reply 3): It's not our place to do that. Imagine if there was a plane crash in Iowa and when our investigation stalled, Russia instead just started holding press conferences about it and announcing their findings. How offensive would that be? |
Quoting flyenthu (Reply 72): OK it is "preliminary assessment of data." We know where some initial analyses usually lead. How can frame integrity be maintained at 45000? The pressure difference between inside and outside will be huge. |
Quoting enilria (Reply 44): Pilot suicide makes no sense to me and he seemed pretty upstanding |
Quoting enilria (Reply 44): To me it has to be terrorist related. It makes no sense to try to kill everybody and hide the crash site. I don't think that makes any sense. |
Quoting hamiltondaniel (Reply 59): According to Malaysian military radar (presumably now interpreted by the US and China), just after the transponder disappeared the aircraft apparently climbed to 45,000 ft while banking to the west, then lost altitude and crossed the peninsula erratically at 23,000, then regained altitude as it went out over the Indian Ocean. Whatttttt...... http://www.nytimes.com/2014/03/15/wo....html |
Quoting flyenthu (Reply 72): How can frame integrity be maintained at 45000? The pressure difference between inside and outside will be huge. |
Quoting LTC8K6 (Reply 83): Could the 45K be to rapidly kill everyone with a depressurization? |
Quoting enilria (Reply 44): 4) Terrorists want the airplane to use as a weapon later and found somewhere to land it and execute the passengers |
Quoting hivue (Reply 25): |
Quoting ADent (Reply 82): They claim to have some detail from the radar and they also claim to be matching that data from RR Engine data. |
Quoting hamiltondaniel (Reply 80): Per the NYT article above (http://www.nytimes.com/2014/03/15/world/asia/malaysia-military-radar.html) |
Quoting Shanwick1011Z (Reply 89): Could the captain have been training any one or two passengers on that aircraft on his home flight simulator? |
Quoting ADent (Reply 82): also claim to be matching that data from RR Engine data. |
Quoting hamiltondaniel (Reply 85): If I understand correctly on Helios the passengers were out, but not necessarily dead; the Greek F-16s saw people moving around inside. |
