Quoting flyingturtle (Reply 200): This might open the possibility of MH370 being hijacked by total noobs. First up to FL 450, down to FL 230, up to 295, and then cluelessly flying around until fuel runs out.
But then, their comms knowledge would be lightyears better than their flying skills. That's the problem. |
Let's put it this way...
1. You see a target you think is a civil jet of your national carrier...
2. That jet makes a U turn back towards land...
3. It goes up and down varying speeds and doesn't maintain level flight...
What do you think is happening?
A. Is it in trouble?
B. Has it been hijacked?
4. You check the ATC, they don't see it. So you all know transponder's off...
5. You call the jet to offer assistance.
6. Jet doesn't reply...
C. It's having comms issues that's why it's not answering you?
7. Then before you realize it, it's over the strait of Malacca, turns right, and goes to FL295
8. Jet turns north west and follows a busy airway...
Well, you might only realize by this time that these guys are running away...
Point: The "appearing to be noobie" chain of events may simply have been an act to fool the military radar operators into thinking what I said above...
