Quoting rcair1 (Reply 74): We do not know if these corridors are defined by the last SATCOM ping, or multiple pings. |
My understanding is that the arcs published are based on the last ping at 8:11 am. All the points in those two arcs are the same calculated distance from the satellite and represent possible locations of the plane at 8:11 am. The arcs must have been constrained by the maximum range the aircraft could have flown at that point of time from the arcs of the previous ping one hour earlier. If there were not this constraint, instead of two arcs we would have a circle with each point having the same calculated distance from the satellite (and centered on the imaginary position of the geostationary satellite on the earth surface).
There must be similar arcs from the previous pings (at 7:11 am, 6:11 am etc.), but those have not been published.
Quoting rcair1 (Reply 74): It appears the north loci is considered more likely because of primary radar signals that roughly correlate |
I would say that both the corridors are of equal consideration. I personally believe on the southern arc.
