Quoting davidzill (Reply 2): divert field on Palau island or maybe a return to the original airport. |
Pulau = Malay/Indonesian for Island... Palau island is somewhere in the pacific :p
Quoting koruman (Reply 11): I postulated that the airliner was hijacked by Uighur terrorists shortly after it flew off the east coast of Malaysia. It then flew back west to the alleged Chinese air base on Great Coco Island north of the Andaman Islands, at which point demands were made (?release of prisoners) and the Chinese instructed the pilots to land at a remote southwest Chinese air force base (which happens to be on the northern trajectory the satellite pings still support). |
OMG!
So the Inmarsat pings are false? Their statement of "consistently moving away from the satellite" was false too?
Quoting flood (Reply 45): It's worth noting that, in an interview with CNN, an Inmarsat VP said their conclusion was peer reviewed by the industry and Boeing had contributed. |
And the satellites are probably made by Boeing too! :p
Quoting AR385 (Reply 109): With the plane at 12,000ft if this turns out to be true. Would cell phones on board have worked at that altitude? |
I received a phone call at over 20,000ft once, if I remember correctly I also received an SMS at 28,000ft... BUT! This was
over land with relatively good coverage... and if I remember correctly, the reception sucks at that altitude! I couldn't hear anything but "garbled whatever"...
I did make a call at 7000ft once, an we were circling a cellphone tower at the time too ! :p
Quoting MSY-MSP (Reply 103): At some point here in the crew realizes that the aircraft is flying too fast for the altitude. They then find that the throttles are non-responsive and the engines are just turning away. |
Why not just make a steep climb and when the speed is low enough, extend the landing gear, speedbrakes what have you... And if the engines were stuck, they'd be stuck at idle due to the dive they just did, or they would have simply disintegrated due to excessive overspeed during the dive to 12,000. Sorry... this one doesn't make sense...
Quoting MSY-MSP (Reply 103): they make the decision to basically wait the fuel out and then hope to glide to a suitable airport. The idea being that they would just circle Sumatra until such time as the fuel ran out. Once the fuel ran out the idea would be to pick the closest suitable airport and glide to it. |
Again, this doesn't make sense. They could dump fuel... or make the fuel consumption extremely high by staying low in a high drag situation. There are so many ways (uncomfortable ways) to make you bleed energy.
Plus, are you aware how many airports in Sumatra can take the 777? Let's see... we have
MES (closed) replaced by
KNO. We have BTJ, we have PDG... we have PLM... and that's about it. Circling around Sumatra to wait for fuel to run out doesn't make sense... sorry. While if they just went in a circle, they got
KUL KLIA, Penang, Phuket, Langkawi, even Butterworth
AB if they needed it, then also
KL Subang, all within a more concise area than Sumatra... then if they go south they got Johor Bharu, Singapore Changi, Singapore Paya Lebar, and Batam... This is still within a more confined area than "going around Sumatra"...
Quoting MSY-MSP (Reply 103): First is that they don't have to worry about terrain. Second it kept them close to shore, for rescue or ditching in the event that they didn't or couldn't make an airport. |
Terrain apart from Medan area and Banda Aceh Area, is largely on the western edge of Sumatra... why go around it? The water is also deeper on the west. A Malaysian with some geography education would know... while the Strait of Malacca is utterly shallow... I'd rather ditch there than the sea west of Sumatra thanks...
Quoting davidzill (Reply 112): I believe the preliminary examination of the data gave investigators a close but approximate lateral flight route, and a further analysis was able to provide investigators with a possible vertical trajectory the lead to an altitude of 0' MSL. |
If that's the case, they should have told us exactly where it went down then... they didn't. The pings were hourly... not every few seconds...
Quoting captainx (Reply 114): What explains the big final left turn to the south after passing Indonsia????? |
Enter this to your FMC: S9000.0 E00000.0
