Quote: Quoting NAV30 (Reply 332): On present (recent) evidence it seems increasingly likely that the crew and passengers were unconscious or dead (probably due to a decompression) quite early in the piece, and that the autopilot then flew the aeroplane on a straight course (a bit east of south) until it ran out of fuel? |
Quoting noflies (Reply 2): Can someone please explain how you get back to your home airport with no communications? |
Quoting nupogodi (Reply 3): Squawk 7600 and hope they're not mad when you bust their airspace? Losing all comms and the transponder just shouldn't happen to a 777. |
Quoting Finn350 (Reply 1): On the contrary, to me the pilot suicide theory is much more plausible than terrorism or cascading technical failures. |
Quoting noflies (Reply 4): I'm also assuming you don't "bust airspace" when you have no means to identify yourself. |
Quoting nupogodi (Reply 6): You don't really have a choice if you're a 777 |
Quote: Malaysian authorities moved to reassert their role in the search for the missing Malaysia Airlines jetliner over the weekend and announced the creation of an investigation team. On Saturday, Hishammuddin Hussein, Malaysia’s defense and acting transport minister, noting that the search for Flight 370 has been “difficult, challenging, and complex,” said that the country will continue to lead the investigation. In accordance with International Civil Aviation Organization standards, the country will appoint “an independent ‘investigator in charge’” to lead the investigation team.... |
Quoting noflies (Reply 7): I do feel like a bit of an intruder because I'm not in the industry, but I hope my questions aren't too stupid. |
Quoting Starlionblue (Reply 9): Agree and i understand. But what about 500 miles apart? That isn't possible. 10 or 50 miles apart; certainly, if the aircraft broke up in mid-air leading to a large debris field. That is the reason i asked the question. |
Quoting Pihero: Secondly, our poster has a very different definition of *track* that you and other pilots, and I for that matter, heve. In fact I'm still trying to understand what that definition is. Quoting WarrenPlatts (Reply 295): The inertial model I first used incorporated a 110 knot crosswind as well--it was able to replicate the 400 knot Inmarsat track exactly. I'd like to see your demonstration because that would be a seminal find ! |
Quoting Pihero: Quoting p51tang (Reply 301): 1/ Is it possible with the 400kt track,that sometime between 23.11 UTC 'but before' 00.11 UTC that one engine was shut down to conserve fuel? That's not a good way : one has to come down to a lower altitude and one has to have power to counter the extra drag of the windmilling engine and the flight controls. |
Quoting BackSeater (Reply 11): Isn't flying a triangular racetrack pattern (counter-clockwise?) the way to indicate lost with no comm, at least for week-end flyers? Of course you have to fly high enough for a radar to see you. |
Quoting alfons (Reply 19): Once the plane/pilot said goodbye to their present air controllers, what's happening exactly on the screen of the air controller? Is the 'blip' simply disappearing from the screen, because the pilot changed the comm? If the blip is not disappearing right away (as it's a radar or whatever else not bound to the comm), shouldn't have the air controller find it strange that the airplane seems to make a sharp turn which is not consistent to its travel goal? |
Quoting WarrenPlatts (Reply 18): But should we expect both engines to flame out nearly simultaneously? E.g., if the left one burned out first, that could cause it to deflect to the east, and slow it down, causing it to cross the last ping arc more to the northeast than one might initially suppose. |
Quoting WarrenPlatts (Reply 17): As opposed to your comments regarding the Toronto mayor, eating hats, whining about CNN and the Malaysian authorities? |
Quoting WarrenPlatts (Reply 17): The people in charge of selecting search areas, if they're doing their due diligence, are monitoring the internet for new idea |
Quoting BackSeater (Reply 22): As a metter of fact, does anybody know the composition of the official Malaysian investigative team(before the announced reorganization) ? |
Quoting Starlionblue (Reply 20): I never learned this as a weekend flyer or a commercial pilot, but then again perhaps I was not the best student |
Quote: RADAR ALERTING MANOEUVRES: 1. When lost or in distress and unable to make radio contact, attempt to alert all available radar systems as follows: (a) activate IFF/SIF to EMERGENCY; (b) guard emergency frequencies; (c) fly two triangular patterns as depicted, resume course, repeat at 5 minute intervals. 120deg turns a stight as practicable clockwise if only RX working, counter clockwide if TX/RX not working TAS 300 Kts or less - fly TWO minute legs TAS more than 300 Kts - fly ONE minute legs 2. If distressed aircraft is flying at night or in limited visibility, landing lights, navigation lights should be turned on to assist the interceptor. 3. If radar contact is established, a rescue aircraft will be dispatched for intercept. 4. Upon successful interception the interceptor and the distressed aircraft should attempt radio contact. If this is not possible, the following visual signals should be used. NOTE: If flying at a low altitude an attempt should be made to climb, as the greater the altitude of the aircraft, the better chances of its being detected. NOTE: For more detailed information on radar coverage see TC AIM, SAR para 4.5 |
Quote: “But the area of highest probability we think is now probably in the southern part of the area pretty close to where Haixun 01 is operating"... |
Quoting PanAmPaul (Reply 28): |
Quoting United727 (Reply 27): How long has it been since a fully loaded passenger jetliner has gone missing and either never found or there was a significant amount of time before the wreckage was found (excl. AF). |
Quoting United727 (Reply 27): god forbid it's not ever located, what lessons could be learned from a disaster of this caliber w/o having any knowledge of how, what, where, when and why (how to prevent such an occurrence from happening again)? |
Quoting United727 (Reply 27): How long has it been since a fully loaded passenger jetliner has gone missing and either never found or there was a significant amount of time before the wreckage was found (excl. AF). I understand that this situation is indeed precedent setting in the airline industry, but god forbid it's not ever located, what lessons could be learned from a disaster of this caliber w/o having any knowledge of how, what, where, when and why (how to prevent such an occurrence from happening again)? |
Quoting BackSeater (Reply 11): Isn't flying a triangular racetrack pattern (counter-clockwise?) the way to indicate lost with no comm, |
Quoting PanAmPaul (Reply 28): I'm a bit lost as to where the new info of "highest probability" is coming from. Another reanalysis of satellite data? |
Quoting Pihero (Reply 32): That was in another era, before secondary radar and transponders... Unfortunately, I seem to be the only one who could remember it. |
Quoting NAV30 (Reply 5): Thing is, though, they'd BOTH have had to die - otherwise the First Officer could and would have taken over and landed safely? Surely a 'double-suicide pact' is utterly improbable? |
Quoting Pihero (Reply 32): That was in another era, before secondary radar and transponders... |
Quoting MD11Engineer (Reply 36): Frederick Forsythe wrote about this method in his book "The Shepherd", |
Quoting wilco737 (Reply 34): They report something about the routing as well. They avoided the Indonesian airspace and then headed south. But why? |
Quoting WarrenPlatts (Reply 18): But should we expect both engines to flame out nearly simultaneously |
Quoting nupogodi (Reply 21): No, it would not deflect if the autopilot was holding a heading. It would not be typical for them to quit at the same time. Someone tried it in a sim. TAC (thrust asymmetry compensation) would kick the rudder out and keep it on course. |
Quoting PW100 (Reply 42): Is TAC independent of autopilot, or is it an embedded autopilot function? Wouldn't autopilot disconnect in case of engine failure? I believe this is what happened in the Helios accident. Autopilot disconnect after one engine failed. The other engine thrust send the aircraft in an uncontrollable spiral dive. The 777 should be more modern, so may not be the case here. |
Quoting United727 (Reply 27): How long has it been since a fully loaded passenger jetliner has gone missing and either never found or there was a significant amount of time before the wreckage was found (excl. AF) |
Quoting rc135x (Reply 45): Examples of large jets lost, cause unknown, no evidence ever discovered: |
Quoting PW100 (Reply 42): In this case, as the flight had already left Malaysian ATC |
Quoting alfons (Reply 19): Is there an air controller here in the forum which can explain this process, once there is a handover or quit, what happens to the dot on the screen and the attention of the air controller? |
Quoting PW100 (Reply 42): Do note that the aircraft's transponder (was) shut off after this (but before the turn). When the transponder is shut off, all secondary radar data will disappear from the ATC screen (flight number, aircraft type, altitude heading, etc). However depending on signal strength, signal characteristics, primary radar capabilities and filtering logic in the ATC radar set-up, the primary signal may remain on the screen, |
Quoting peterjohns (Reply 48): Given their last Pos. that implies to turn back towards Langkawi!!?? |
