jetblue01
JAX Center?
Tue Apr 15, 2014 2:53 pm
I have a teacher. Her nephew is ATC at JAX Center. He works in Hillard,FL. The Frequency he works is 126.35. It would not come up on liveatc, would there be any other way to listen to it?
dumbell2424
RE: JAX Center?
Tue Apr 15, 2014 2:57 pm
Quoting jetblue01 (Thread starter):
Looks like it's with Daytona Beach:
PHLapproach
RE: JAX Center?
Tue Apr 15, 2014 3:05 pm
An ARTCC is split up into "Areas" or "Specialties". So he'll work anywhere between 5 to 8 different sectors. I was able to locate a feed with that frequency. If you go to LiveATC.net and search "ZJX" on the top left. The first feed to pop up is called "ZJX Daytona Beach" and has the frequency you listed. You can also type under the frequency search below that 126.350 and it's the 2nd feed result. But like I said.. He would work many other sectors. So if you can narrow down what Area within ZJX that sector that's using 126.35 is in then you can narrow down the rest of the sectors he works and there very well may be feed coverage of those other sectors.
jetblue01
RE: JAX Center?
Tue Apr 15, 2014 3:08 pm
Quoting PHLapproach (Reply 2):
would they all be under the 126.350 Frequency? The one on the DAB page
N766UA
RE: JAX Center?
Tue Apr 15, 2014 3:15 pm
1 sector, 1 (active) frequency. Most center sectors are not available to listen to online, but some are.
krsw757
RE: JAX Center?
Tue Apr 15, 2014 3:43 pm
The sector you are referring to, is 58. which is commonly combined up with 57 (134.0) They work most east coast MCO arrivals and departures and southbound overflights below FL340. The area is South.
SPREE34
RE: JAX Center?
Wed Apr 16, 2014 5:06 pm
126.35 is located at the St. Augustine RCAG. That's about 10 miles WSW of St. Aug. 134.0 is located at the Daytona Beach airport. And yes, they stay combined a lot.
If you are anywhere near those two areas you may be able to hear the controller side aswell as the aircraft.
I don't understand everything I don't know about this.
jetblue01
RE: JAX Center?
Thu Apr 17, 2014 3:46 am
Quoting krsw757 (Reply 5):
Yeah, thats what it looked like from flightaware. I heard mostly flights into MCO and PBI and one DL from ATL-SJU
jetblue01
RE: JAX Center?
Thu Apr 17, 2014 3:47 am
Quoting N766UA (Reply 4):
thanks everyone. I think i found it.
Users browsing this forum: a2b7, AirMitko, amc737, bealinehx, carlosnunezdfw, CoThG, CV880, darloscott, Google [Bot], Ishrion, planemannyc, sfojvjets, SQ22, SXI899, Toinou, wetpantsmcgee, YQGflyer and 139 guests
