jetblueguy22
A350 Test Flights Official Thread Part 16
Tue May 06, 2014 6:47 pm
Hi All,
As the previous thread has gotten quite long part 16 has been created to continue the conversation. The old thread can be found here A350 Test Flights Official Thread Part 15 (by SA7700 Mar 26 2014 in Civil Aviation) .
Pat
Unflug
RE: A350 Test Flights Official Thread Part 16
Wed May 07, 2014 7:22 am
Quoting KarelXWB from last thread:
Apparently I was wrong, it's -54°C to +70°C.
http://www.air-cosmos.com/2014/05/06...es-essais-climatiques-extremes
This article also states "next 2 weeks" instead of "several weeks" for the duration of the stay.
KarelXWB
Thu May 08, 2014 11:26 am
A350 type certification is still on track for the end of August or early September. And the EASA will most likely certify the A350 with ETOPS 180.
http://uk.reuters.com/article/2014/0...rbus-group-a-idUKKBN0DN1FH20140507
"We are still looking at the end of the summer," Patrick Ky, executive director of the European Aviation Safety Agency (EASA), told Reuters.
Sources say EASA's certification plan calls for 180 minutes ETOPS from the outset, but the U.S. Federal Aviation Administration (FAA) may take a few months longer to consider the same level of clearance.
starbucks
Thu May 08, 2014 6:31 pm
Just read that MSN4 was at Istres to go for a swim..   (flooded runway test)
SXI899
Thu May 08, 2014 8:21 pm
Quoting starbucks (Reply 3):
Yup, positioned back to Toulouse this evening as AIB45NW. (1615Z-1702Z)
crimsonchin
Thu May 08, 2014 8:56 pm
Hope there are pics soon
KarelXWB
Fri May 09, 2014 6:13 am
Final test aircraft MSN5 went to paint this morning.
Let's go to the paint for MSN 005 ! by Jujug Spotting, on Flickr
sturmovik
Fri May 09, 2014 9:17 am
Quoting KarelXWB (Reply 6):
Is there a separate paint hangar for the A380s? To me that hangar looks like the A380 would be a tight fit in there. Also, sorry if this has been discussed before, but what livery is expected for MSN5?
817Dreamliiner
Fri May 09, 2014 9:22 am
Quoting sturmovik (Reply 7):
Same one as MSN 2.
BobMUC
Fri May 09, 2014 9:25 am
Not 100% sure, but A380s are painted in Hamburg not TLS.
starbucks
Fri May 09, 2014 2:45 pm
Quoting CrimsonChin (Reply 5):
You asked?  http://fbcdn-sphotos-a-a.akamaihd.net/hphotos-ak-ash3/t1.0-9/10338328_864856496863969_8808119610232577970_n.jpg
Via Airbus Facebook
KarelXWB
Fri May 09, 2014 2:49 pm
Part147
Fri May 09, 2014 3:35 pm
Quoting starbucks (Reply 10):
A real picture of this a.net smilie...
KarelXWB
Fri May 09, 2014 3:55 pm
CSeries FTV2 at McKinley Laboratory, Florida. This video shows what we can expect for MSN2:
http://www.youtube.com/watch?v=lYpgmgAmHZ4
crimsonchin
Fri May 09, 2014 9:16 pm
Thanks! I was trying to also find out how much water is dumped on the runway but couldn't
KarelXWB
Fri May 09, 2014 9:18 pm
There is a bit information in the press release.
http://www.airbus.com/newsevents/new...s-water-ingestion-tests-at-istres/
MSN004, travelled through troughs containing at least 22mm of water depth, at a variety of speeds, starting at 60kts, and successively increasing to around 140kts.
ek17
Sat May 10, 2014 8:46 pm
http://bit.ly/1fV4ErX - Nice video of MSN 2's cabin. That lighting!
KarelXWB
Mon May 12, 2014 1:20 pm
A fresh week, a fresh start. MSN3 just departed from TLS:
http://fr24.com/AIB42GG
JeanXFW
Wed May 14, 2014 8:37 pm
NIght work for MSN4.
Any news from MSN2?
StTim
Wed May 14, 2014 8:52 pm
It has been quite a quiet month so far for the test fleet.
KarelXWB
Wed May 14, 2014 9:15 pm
MSN4 today:
From my living room... by Jujug Spotting, on Flickr
BobMUC
Thu May 15, 2014 6:37 am
We will see a visit of MSN4 to the ILA Berlin Air Show next week:
ILA Berlin Air Show 2014: Airbus to showcase cutting-edge products and innovations
First display of A350 XWB test aircraft at German Air Show
• Airbus’ all-new A350 stars in opening day, underlining widebody leadership
• Customer A380 and A400M complement fleet on display
http://www.airbus.com/newsevents/new...ing-edge-products-and-innovations/
KarelXWB
Thu May 15, 2014 8:19 am
Quoting StTim (Reply 19):
> MSN2 went to Florida for weather test so no flight activity for several weeks
> MSN4 did water tests for a few days so no flight activity
> May 8 was a holiday
Ground certification tests means less flight activity, nothing to worry about.
BobMUC
Thu May 15, 2014 9:14 am
Not today! GiGi (AIB43GG) was already in the air and NW is flying right now as AIB47NW.
KarelXWB
Thu May 15, 2014 10:00 am
Both aircraft are doing quite some laps.
starbucks
Thu May 15, 2014 10:21 am
MSN3 stopped again after one circuit...
First time she went up as AIB43GG, she climbed to 8000ft, second time she did one circuit at 4000ft before landing and returning to the flightline.
Maybe some tech issue? *speculating*
MSN4 is doing circuits as well, 4 left-hand, a stop & go, and just finishing their 3rd right-hand. If they do the same as the first four then I guess since MSN4 is used for crew training, they are doing the circuits required to finish a Type Rating...
//Edit, disregard, just as I pressed Post message MSN4 vacated the runway..
[Edited 2014-05-15 03:22:55]
bikerthai
Thu May 15, 2014 1:11 pm
Never noticed it before, but the unpainted fuselage shows primer green for the cockpit section. Does that mean that the cockpit (section 41) is aluminum?
bt
starbucks
Thu May 15, 2014 1:26 pm
Quoting bikerthai (Reply 26):
The cockpit sections is made of a Alu alloy indeed, I believe it was because the metal better withstands a direct birdstrike
mjoelnir
The cockpit section is indeed aluminium. Strength issues because of bird strikes.
bycac
Thu May 15, 2014 2:08 pm
MSN04 on red pattern this morning :
https://farm8.staticflickr.com/7437/14004484660_6d44e6cf31_c.jpg
https://farm8.staticflickr.com/7402/14187838601_7b35c8a1f6_c.jpg
KarelXWB
Thu May 15, 2014 4:16 pm
You can see some red stuff underneath the engine:
AIB143GG 15/5/2014 by A380_TLS_A350, on Flickr
bobdino
Thu May 15, 2014 4:39 pm
Quoting bycac (Reply 29):
Forgive the ignorance, but what is 'red pattern' ?
redflyer
Thu May 15, 2014 4:42 pm
Quoting KarelXWB (Reply 30):
And the grid pattern on the underside near the tail...related to VMU testing?
bigsmile
Fri May 16, 2014 3:17 pm
The black and silver grid is protection from the VMU tests and the red (you might also notice what looks like very white section on the underside of the wing) this is aero paint.
[Edited 2014-05-16 08:18:46]
KarelXWB
Fri May 16, 2014 3:22 pm
Quoting bigsmile (Reply 33):
this is aero paint.
Thanks, similar like the A380 engine test.
Take-off msn1 F-WWOW 20/6/2013 by A380_TLS_A350, on Flickr
ek17
Fri May 16, 2014 4:16 pm
MSN 4 has just taken off as AIB50NW
http://fr24.com/AIB50NW
GG has landed after another circuit.
[Edited 2014-05-16 09:18:44]
ek17
Fri May 16, 2014 4:23 pm
Quoting KarelXWB (Reply 34):
Also visible on the tail today...
https://farm8.staticflickr.com/7390/14198165575_7573e60de9_o_d.jpg
What is this 'aero paint' used for?
starbucks
Sat May 17, 2014 9:29 am
Just on Twitter:
#AvgeekAlert: Airbus 350-900 F-WZNW as AIB351 expected to be making a go-around in Geneva on Monday afternoon! Someone please make a video!
Account is from a Geneva Air Traffic Controller.
Will be the ferry flight to Berlin and the ILA show.
KarelXWB
Sun May 18, 2014 9:37 pm
More aero paint, this time underneath the right-hand wing:
A350 003 AIB46GG with red liquid under right wing by Jujug Spotting, on Flickr
crimsonchin
Sun May 18, 2014 10:04 pm
So it should be 2 weeks in a few days that the A350 has been doing the extreme weather tests. There's no news at all?
Part147
Mon May 19, 2014 7:09 am
It's the calm before the storm... airshow season is almost here and we'll be getting updates on every programme out there!
KarelXWB
Mon May 19, 2014 8:59 am
Quoting starbucks (Reply 37):
Alive right now:
http://fr24.com/AIB3
Ruscoe
Mon May 19, 2014 12:10 pm
Quoting EK17 (Reply 36):
I'd like to know also. I only know what I have read, and may have it wrong. I would have expected a plethora of replies to this one.
From what I can find out it is used for at least 2 purposes, and possibly a lot more.
First it is ultra-thin, ultra-smooth and ultra-light. Painting a 747 with it would save about a ton in weight, and looks great on a race car.
Second, it is used to study air flow over the surface. I presume the paint moves with the air flow, and "things" can be worked out from this.
In regard to the 350, the aero paint does not look ultra- good so I am presuming it is being used for the purposes of aerodynamic refinement.
Ruscoe
KarelXWB
Mon May 19, 2014 12:23 pm
MSN4 is airborne right now http://fr24.com/AIB351
speedbored
Mon May 19, 2014 12:39 pm
Quoting Ruscoe (Reply 42):
Well I'm no expert but my understanding of it matches yours.
Aero (or "Flow Visualisation) Paint is used for testing and fine-tuning aerodynamics. It is basically a coloured liquid, similar to paint, that is mixed in various viscosities for different purposes, and which takes a very long time to dry. In normal use, it will either be removed from the surface again before it has dried, or will be formulated in a way that does not bond well to the surface if it does dry. It is used for a similar purpose to those stick-on tufts of string, but provides a much finer level of detail, closer to the surface.
Once the paint has been applied, the airflow is added (either via a wind tunnel, or by flying the aircraft, or driving the car) and what then happens to the paint is analysed to determine whether or not the airflow is behaving in the expected way. Often, the movement of the paint is videoed. Very detailed analysis will be done on where the paint ended up, how it moves, and whether or not it becomes "textured". Analysis is a very skilled job - most of us would just see a mess.
To oversimplify, I believe that the direction and length of streaks in the paint will indicate speed and direction of airflow, texturing will indicate turbulent flow, and patches of paint that remain unaffected indicate that the airflow is detaching from the surface.
My understanding is that when it comes to aircraft, flow visualisation paint is primarily used these days to test and refine laminar flow, especially around the engine nacelles, and on critical areas of the wings and control surfaces.
But as I said, I'm no expert. I'm sure that there are far more knowledgeable people here who can provide a lot more detailed/accurate information.
KarelXWB
Mon May 19, 2014 12:41 pm
Perhaps this url might help:
http://www.formula1-dictionary.net/flow_viz_paint.html
BobMUC
Mon May 19, 2014 2:35 pm
Quoting KarelXWB (Reply 43):
Has landed in Berlin SXF at 14:25 UTC.
KarelXWB
Mon May 19, 2014 2:43 pm
HighflyGLEX
Mon May 19, 2014 3:01 pm
Following this website for ages and especially the A350 development forums, I decided that today was my turn contributing to the discussion.
Of course, I've to thank people like KarelXWB, Starbucks, Bycac, Pihero and so many other contributors for making this forum so interesting and complete in terms of info and pictures. I almost have the feeling working by Airbus and following the A350 its development from the inner
Today, on its way to Berlin, MSN4 F-WZNW made a little apperance at LSGG/GVA as AIB351 with a high pass first and then a go-around. This aircraft, which it was my first encounter with, is as described here, graceful and silent.
Here are a few pics from the go-around, sorry, mobile phone quality
Once again, thumbs up for all of you guys making such an incredible job keeping us all posted about the A350!
Ruscoe
Mon May 19, 2014 3:15 pm
Thanks KarelXWB - usefull article
Ruscoe
